Can Beta Decay Occur to a Ground State in Nuclear Physics?
In summary: ThanksThe W in this case is "virtual". Energy and momentum are conserved, but the mass of a virtual particle is generally not the same as the mass of a "real" particle. Particle physicists often use the jargon "off the mass shell" for virtual particles, where "on the mass shell" means "having the mass that you see in the standard tables."Thanks jtbellI think smk wants a definitive answer to the conservation of angular momentum issue ;)If electron and neutrino spins must be aligned, then that suggests the proton must have the opposite of the spin of the initial neutron.And another question arise here that as we know that in nuclei prot
smk
What is difference between beta particle and electron? I mean in spin, mass or other properties.
Nothing.
Thanks
No worries - conceptually a beta particle comes from a nuclear disintegration, so it is a handy shorthand.
Saying I detected a beta particle from some atom is a bit different from saying I detected an electron from that atom.
Given a free electron, there is no way of telling if it came from a nucleus or an electron shell or pair production even.
You need some other information - like the presence of a beta-unstable radio-isotope, and shielding.
Historically, beta rays were named before they were identified with cathode rays and so with electrons.
Technically beta particles may be positive or negative - but we would usually specify "beta-plus" if the positron is intended.
It's all good fun.
Thanks alot
Thanks I m confused when I studied that in beta decay W- decay into electron and antineutrino. when we see the spin of w- then it is -1.this is TRUE only when electron and antineutrino both have spin half (down).sir this is my own thinking may be I m wrong.thanks
Beta decay is a process by which a beta particle - which is an electron - is produced along with an antineutrino as a proton converts into a neutron. Yes, this terminology is somewhat confusing... It came about for historical reasons, because the radiation was observed and given its name before the particles involved were identified and the process understood.
Thanks
##p^+ \to n^0 + e^- + \bar \nu_e## does not conserve charge?
You mean: ##n^0 \to p^+ + e^- + \bar \nu_e##
To conserve angular momentum, the electron and neutrino spins need to be aligned - you are thinking.
The usual sin-up/spin-down terminaology only applies in an external magnetic field like that of the nucleus of an atom on in a Stern Gerlach apparatus. There is no "up" or "down" in space.
Odd things can happen in the virtal particle transition though - consider, is total energy conserved as the W -> e+nu. ?
Sir you mean that here we cannot consider spin?sir what do you think energy is conserved here.since we know that W is havier .and if we try to re combine electron and antineutrino then what happen?
D'oh... Yes, of course.
Thanks jtbell
Thanks
And another question arise here that as we know that in nuclei protons and neutrons occupy definite levels in nucleonic shells.now question is that when neutron transformed into proton then where the proton goes? I mean it will stay in the same level as that of neutron or jump into another level? Thanks
In strict language, yes there would be a small jump(due to coulomb potential). The nucleus itself can change.. but in general and simple models this doesn't happen, because the strong force doesn't distinguish between neutrons and protons (isospin symmetry).
Thanks
To be small, you need very special nuclei like Tritium.
In general, neutron and proton numbers in a nuclei are so different that the most high-energetic occupied neutron state and the available unoccupied proton states have different quantum numbers.
hmm... Do for example the higher atomic number mirror nuclei differ much from each other?
Mass of 24Na: 23.99096 u
Mass of 24Al: 23.99994 u
A difference of 8.4 MeV, and this is just the exchange of 2 neutrons <-> 2 protons in a relatively light nucleus. Both decay to 24Mg (23.98504 u), with a half-life of 15 hours (sodium) / 2 seconds (aluminium).
14 MeV decay energy... that's so much the Al sometimes emits a proton or an alpha particle in the process (Isotope list).
Does it mean that in general, beta decay cannot occur to a ground state of a daughter nucleus, but to such an excited state of the daughter nucleus where the daughter proton is on the orbit vacated by the mother neutron?
This will in general depend on the decaying nucleus. It is very common that beta decay is to an excited state of the daughter nucleus and is followed by gamma emission as the daughter goes to the ground state. In some cases (such as 60Co - 0.12% is still a branching ratio :wink:), the mother can decay into different excited daughter states (meaning different beta energy) resulting in several different gamma lines.
No, and I don't see how you got that idea. A decay to the ground state is always possible. In some cases it is quite unlikely.
Often that's not even possible (especially in beta+ decays).
1. What is beta decay?
Beta decay is a type of radioactive decay in which a nucleus emits a beta particle, which can be either an electron or a positron, and transforms into a different element. It is a process that occurs in unstable atoms in order to become more stable.
2. What causes beta decay to occur?
Beta decay occurs due to the imbalance of protons and neutrons in the nucleus of an atom. In order to achieve a more stable ratio, the nucleus will emit a beta particle in the form of an electron or positron.
3. What are the different types of beta decay?
There are three types of beta decay: beta minus decay, beta plus decay, and electron capture. In beta minus decay, a neutron in the nucleus is converted into a proton, emitting an electron and an antineutrino. In beta plus decay, a proton is converted into a neutron, emitting a positron and a neutrino. Electron capture is when an electron from an inner shell of the atom is absorbed by the nucleus, resulting in the emission of a neutrino.
4. How does beta decay affect the stability of an atom?
Beta decay can either increase or decrease the stability of an atom, depending on the specific type of decay. In some cases, beta decay can transform an unstable atom into a more stable one, while in other cases it can lead to further decay and instability.
5. Can beta decay be controlled or stopped?
Beta decay is a spontaneous process and cannot be controlled or stopped. However, the rate of beta decay can be affected by external factors such as temperature and pressure. Additionally, certain elements undergo beta decay at a much slower rate, making them more stable and less likely to undergo decay in a given time period.
