Thread Closed
Re: do tree-level results in effective potential incorporate loop
Share Thread Thread Tools
May24-05, 08:02 PM   #1
<jabberwocky><div class="vbmenu_control"><a href="jabberwocky:;" onClick="newWindow=window.open('','usenetCode','toolbar=no,location=no, scrollbars=yes,resizable=yes,status=no,width=650,height=400'); newWindow.document.write('<HTML><HEAD><TITLE>Usenet ASCII</TITLE></HEAD><BODY topmargin=0 leftmargin=0 BGCOLOR=#F1F1F1><table border=0 width=625><td bgcolor=midnightblue><font color=#F1F1F1>This Usenet message\'s original ASCII form: </font></td></tr><tr><td width=449><br><br><font face=courier><UL><PRE>On 2005-05-24, Xiao &lt;noncommutate@yahoo.com.cn&gt; wrote:\n&gt; Many thanks.\n&gt; So the second derivative of the effective potentail with respect to the\n&gt; field phi gives phi\'s physical mass which is scale independent, since\n&gt; there are no longer loop diagrams here?\n&gt; The second derivative is usually a polynomial of the parameters which\n&gt; is scale dependent. So if the second derivative is the physical mass,\n&gt; it implies that there are some automatic cancellations between the\n&gt; scale dependent quatities in the polynomial?\n\nI\'ll assume that by scale dependent, you mean dependent on the\nrenormalization scale. Since the coefficients, of the terms in the\neffective potential are taken to be renormalized scattering amplitudes,\nthey will in general be scale dependent. However, during renormalization\nthe coefficient of the effective mass term is tuned to be the physical\nmass at the renormalization momentum scale. Thus the effective mass term\nwill be scale independent in as much as it is momentum independent.\n\nHope this helps.\n\nIgor\n\n</UL></PRE></font></td></tr></table></BODY><HTML>');"> <IMG SRC=/images/buttons/ip.gif BORDER=0 ALIGN=CENTER ALT="View this Usenet post in original ASCII form">&nbsp;&nbsp;View this Usenet post in original ASCII form </a></div><P></jabberwocky>On [itex]2005-05-24,[/itex] Xiao <noncommutate@yahoo.com.cn> wrote:
> Many thanks.
> field [itex]\phi[/itex] gives [itex]\phi's[/itex] physical mass which is scale independent, since
I'll assume that by scale dependent, you mean dependent on the
Hope this helps.
Igor
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
Thread Closed
Thread Tools
Similar Threads for: Re: do tree-level results in effective potential incorporate loop
Thread Forum Replies
MATLAB- for loop saving results of 3 variables Math & Science Software 3
dose tree-level results in effective potential incorporate loop effects? General Physics 1
Re: dose tree-level results in effective potential incorporate loop General Physics 0
dose tree-level results in effective potential incorporate loop effects? General Physics 0
