- #1
Mniazi
- 57
- 1
I had this distilled battery water, it fizzes when I throw it on rock and it turns copper hydroxide into a greenish solution. does it have hydrochloric acid?
Distilled water is water that has been purified through a process called distillation, which involves boiling the water and then condensing the steam back into liquid form. This process removes impurities and minerals from the water, resulting in a pure and clean form of water.
No, distilled water does not contain any minerals or nutrients. The distillation process removes all impurities, including minerals, from the water. While this makes distilled water very pure, it also means that it does not contain any beneficial minerals that other types of water may have.
Yes, distilled water is safe to drink. The distillation process removes impurities and contaminants from the water, making it safe for consumption. However, because it does not contain any minerals, it is not recommended for long-term consumption as it may lead to mineral deficiencies in the body.
Yes, distilled water can be used for cooking and other household purposes. It is often recommended for use in appliances such as humidifiers, steam irons, and car batteries, as it does not contain minerals that can cause buildup or damage. However, it may not be ideal for cooking as it does not have the same taste as other types of water.
Yes, there is a difference between distilled water and purified water. Distilled water undergoes a specific distillation process, while purified water can be produced through various methods such as filtration, reverse osmosis, or distillation. Additionally, distilled water is considered to be the purest form of water, while purified water may still contain some minerals or impurities.
