How Do I Integrate (x^2 + 7x + 10) / (x + 2)?
The discussion revolves around the integration of the rational function (x^2 + 7x + 10) / (x + 2). Participants explore methods for integration, including substitution and factoring, while considering the implications of singularities in the function.
  • Participants discuss the possibility of using substitution and factoring to simplify the integral. There are questions about the existence of the integral due to the singularity at x = -2, and some participants suggest breaking the integral into parts to evaluate limits.
The discussion is active, with participants raising various points about the nature of the integral and the impact of discontinuities. Some guidance has been offered regarding the need to exclude certain points from the integration domain, but no consensus has been reached on a definitive approach.
There is a noted singularity at x = -2, which affects the integration domain. Participants are also navigating the distinction between integrability and continuity in the context of the functions discussed.
Guero
how can i integrate:
x^2+7x+10 dx
x+2
i assume it's by substitution, but i can't work it out.
sorry for the formatting, btw
Factor the top, it cancels.
x^2+7x+10 dx
x+2
(x+5)(X+2) =x+5
(x+2)
I don't know nothing about integrate. But I think you have to factor the trinomial then divide.
Note the singularity at x = -2, it can't be integrated in a region containing this point.
Not really.It can't be defined at x=-2,which means that automatically that point is excluded from the integration domain.
Daniel.
thanks. should've seen it.
Does the integral
[tex]\int_{-3}^1 \frac{x^2+7x+10}{x+2} \ dx[/tex] exist, dex? As its written?
I don't know.U'll have to break it into 2 and evaluate each limit.(I wasn't talking about a definite integral,so your (counter)example is useless).
Daniel.
Its the same thing.
However, the integral is a "smoothing" operation. The integral of a function with removable discontinuity exists and is exactly the same as the integral of the function with the discontinuity removed.
whozum do you agree that x^2 is integratable, what about [tex]\frac{(x^2)(x+1)}{x+1}[/tex]?
Theyre both integrable, just the latter isn't continuous.
  • · Replies 16 ·
