(Bullets + you) / e = death, but why?
  • Thread starter Thread starter Pengwuino
    Death
The discussion centers around the biological processes and mechanisms that lead to death when a person is shot by a bullet. Participants explore various scenarios of gunshot wounds, including those to the lung, heart, brain, and other areas, examining the physiological consequences of such injuries.
  • Some participants suggest that death from a gunshot wound can result from internal bleeding, trauma to vital organs, or disruption of essential bodily functions.
  • In the case of a lung injury, one participant notes that a bullet could cause a lung collapse and difficulty breathing, potentially leading to drowning in blood.
  • Another participant claims that a heart wound would likely result in rapid death due to severe blood loss and the heart's inability to pump blood.
  • Discussion on brain injuries indicates that survival may depend on the specific brain regions affected, with potential complications from swelling or infection.
  • Participants mention that wounds to the abdomen could lead to slower death from sepsis if vital organs are damaged.
  • Some argue that even minor injuries can be fatal, emphasizing the fragility of human life and the ease with which it can be extinguished.
  • One participant introduces a thermodynamic perspective, likening the human body to an engine that requires a constant supply of fuel and oxygen to function, which can be interrupted by a bullet injury.
  • Another point raised is the role of bullet design and impact force in determining the extent of injury and potential lethality.
Participants express a range of views on the mechanisms of death from gunshot wounds, with no consensus reached on the primary causes or the specifics of each scenario discussed. Multiple competing explanations and hypotheses remain present throughout the discussion.
Participants acknowledge various assumptions and uncertainties regarding the biological processes involved in death from gunshot wounds, including the complexity of human physiology and the variability of injuries.
Pengwuino
(Bullets + you) / e = death, but why? :)
lol ok I am wondeirng something. When your hit with a bullet, what really kills you? Shock, loss of blood, what? Or well, I've been told its loss of blood but why would losing blood kill you? Whats the actual biological process/problem that arises that kills you?
Ok and to make this less general... what happens in these specific situations
1) bullet penetrates your lung
2) bullet penetrates your heart
3) bullet penetrates your brain (and let's say it wasnt that poewrful of a bullet as to just completely decimate your entire brain)
4) any other spot not commonly associated with being almost instantly fatal.
Biology news on Phys.org
Depends where you get shot.
Could be internal bleeding..or lack of having a head on your body, among other things.
hmm yah this has too many possibilities... ill clarify.
lung collapses, beathing difficulty's, extra oxygen in the blood(?), choking on blood
nearly instant death, no 'blood spurt's', simply put, death
some sort of seizure or fit, i would think
blood loss over long term, and possibly loss of control of limb
i'm not professional or anything, so just take my awnsers as assumptions
Yah but why do those results kill you.
In the case of a heart wound (or a wound to any of the major vessels surrounding the heart), you'd bleed out before help even arrived. Plus, the heart itself is severely traumatized and incapable of pumping any remaining blood, so none of your other vital organs are receiving any oxygen or nutrient supply to continue functioning either, and even a transfusion on the scene by paramedics isn't going to do much good if the heart can't pump. That sort of injury is most likely to be a DOA.
In the case of a wound to the lung, two factors, one, you also have bleeding, and may have struck one of the large pulmonary arteries or veins that would leave you to bleed out quickly, second, any hole into the thoracic cavity (same is true for a wound to the heart or through the diaphragm) is going to leave you unable to breathe (breathing requires negative pressure applied to the outside of the lung from the expansion of the thoracic cavity in order to draw air into the lungs). The bleeding would lead to a quicker death than the lack of breathing, but in either case, you haven't got long before there is too little oxygenated blood getting to the vital organs. In addition, the blood flooding the lungs (no longer contained in blood vessels but getting into the parts where air is supposed to be) would have the same effect as drowning.
A wound to the head would depend on what part of your brain and how much of it was injured. You can survive a head wound (whether or not you'd have any cognitive abilities intact) if brain regions that control vital organ functions (such as respiration and cardiac function) are spared. Keep in mind that with a head injury, the hole created by the bullet may not be what kills you, but the blood filling the brain and the swelling of the brain in response to injury that causes more extensive brain injury than the bullet hole itself. The brain is also very susceptible to infection, especially fungal infection, when penetrated by anything that's not sterile (it's hard to get medications across the blood-brain barrier; few broad-spectrum antibiotics will cross to treat bacterial infections, and I'm not even sure what options are available for antifungal treatment of brain infection).
Other fatal injuries would come from wounds to the abdomen that damage other vital organs and major blood vessels. Slower death would occur from sepsis if intestines were hit.
On the periphery (arms and legs), unless a major artery is hit and nobody can apply appropriate pressure or a tourniquet quickly enough to control the bleeding, then it probably wouldn't be immediately fatal. The risk then would be development of subsequent infection. If the infection remains local, it could go as far as requiring amputation of a limb, but if the infection is carried through the blood supply and becomes systemic, depending on how the "bug" responds to antibiotic treatments, it may be fatal.
The fact of the matter is, as Pascal says, it doesn't take a mountain to fall on us to kill us, a handful of dirt taken the wrong way can do it. Nor do we need an ocean to drown us, a cup of water that goes down wrong will do it.
It's one of those glass half empty/glass half full things. If you look at us one way it's amazing how tough we are and the awful things we can survive. But you look the other way and it's easy as pie to kill us. These two facts about us have been known at least since the stone age, if not since our common ancestor with the chimpanzees. They form the basis for warfare.
Perhaps you're looking for a more "thermodynamic" explanation of death. Every process in the universe can be understood as movement of energy from one place to another, physical "life" being no exception. In the case of animal life (the kind that humans have) energy is introduced into the system in a stored chemical form (food). This stored chemical energy is released in a controlled way to power the processes we refer to as "life". In this regard, the human body is not so different from any other kind of engine; we eat fuel, we inhale oxygen, the oxygen bonds with the fuel releasing energy to power the act of living.
If a bullet destroys the trachea, interrupting breathing, there is no oxygen being put to the fuel, and the "engine of life" stalls. The same is likely to happen with any major damage to the lungs. If the bullet strikes the heart, and stops it from pumping, neither fuel nor oxygen is supplied to the body and again, the engine stops. If the bullet passes through the brain stem, or severs the spinal cord just below the brain, the electrical signals that activate the various mechanisms will be cut off and again, the engine stops.
For the purposes of this discussion, the main difference between the human body and an automobile engine is that living tissue is extremely high maintenance. All of the cells in your body are only a few moments away from rotting where they stand. Only the constant supply of fuel, oxygen, and raw materials maintains these very fragile tissues. If a car engine is left for several months or a year without running, it may seize up and never start again. When the human body stops running, irreplaceable parts begin to fall apart almost immediately, rendering the body incapable of restarting.
As already addressed, rapid bleeding out or disrupting the nervous system are the two main ways to dispatch a living creature. To speak to the bullet's perspective, in terms of how it does it's work, it obviously has some force behind it and therefore an element of physical impact, but this typically does not do the killing. How strong the impact is will determine how far the bullet penetrates, also included in this is projectile design and makeup which will also determine how much it expands. If it expands a lot and quickly, it will penetrate less. A successful bullet will give both good penetration and expansion which will allow it to potentially disrupt more vital targets such as blood vessels and/or the nervous system.
12K
17K
  • · Replies 20 ·
325K
  • · Replies 17 ·
11K
13K
