What Is the Optimal Pinhole Size for Double-Slit Interference with Daylight?
  • Context: Graduate
  • Thread starter Thread starter Codeman
    Diameter Double-slit
The optimal pinhole size for achieving a clear double-slit interference pattern using daylight involves careful consideration of several factors, including the wavelength of light and the distance between the pinhole and the double-slit plate. The formula for calculating the optimal pinhole diameter is D = 1.22λf/D, where D represents the pinhole diameter, λ is the wavelength of light, and f is the focal length of the lens. Additionally, the slits should be narrower than the wavelength of light, with their spacing matching the slit width to enhance coherence while minimizing diffraction.
  • Understanding of double-slit interference principles
  • Knowledge of light wavelength and diffraction
  • Familiarity with optical formulas, specifically D = 1.22λf/D
  • Experience with experimental optics setups
  • Research the wavelength of daylight and its implications for interference patterns
  • Learn about diffraction and its effects on optical experiments
  • Explore the design and construction of pinhole cameras
  • Investigate advanced techniques for measuring interference fringe spacing
Physics students, optical engineers, and hobbyists interested in experimental optics and interference patterns will benefit from this discussion.
Codeman
Hi All,
I am trying to get a interference pattern from normal daylight and was wonder if I used a VERY FINE pinhole (micron sizes) to concentrate the light into some coherence and THEN have the double-slit plate behind the pinhole plate if this would work. How do I calculate the measurements? What is the optimal pinhole size that will give the best of both worlds between most coherence and least diffraction? If the pinhole is x then how do I calculate the slit size (length & width)? PLEASE HELP if you can...
Thank you,
Codeman
Hi Codeman,
Using a very fine pinhole to concentrate the light into coherence and then using a double-slit plate behind it can indeed help in obtaining an interference pattern from normal daylight. However, the optimal diameter of the pinhole and the size of the slits will depend on several factors such as the wavelength of light, the distance between the pinhole and the double-slit plate, and the desired spacing between the interference fringes.
To calculate the optimal pinhole size, you can use the formula for diffraction-limited resolution, which is given by D = 1.22λf/D, where D is the diameter of the pinhole, λ is the wavelength of light, and f is the focal length of the lens used to project the pinhole onto the double-slit plate. This formula will give you the smallest pinhole size that will still allow enough light to pass through and create an interference pattern.
As for the size of the slits, the general rule is to make them as small as possible while still allowing enough light to pass through. The width of the slits should be smaller than the wavelength of light, and the distance between the slits should be around the same size as the width of the slits. However, the exact measurements will also depend on the factors mentioned above.
I hope this helps. Good luck with your experiment!
  • · Replies 32 ·
  • · Replies 65 ·
  • · Replies 17 ·
  • · Replies 60 ·
9K
  • · Replies 17 ·
  • · Replies 19 ·
