| Thread Closed |
Dedekind Cuts |
Share Thread | Thread Tools |
| May26-05, 01:36 PM | #1 |
Dedekind Cuts
The question:
Show D= {x: x [tex]\in[/tex] Q and (x [tex]\leq[/tex] or x^2 < 2)} is a dedekind cut. A set D c Q is a Dedekind set if 1)D is not {}, D is not Q 2) if r[tex]\in[/tex] D then there exists a s [tex]\in[/tex] D s.t r<s 3) if r [tex]\in[/tex] D and if s [tex]\leq[/tex] r, then s [tex]\in[/tex] D. For the first case, D is not an empty set because x is equal to 0 or the sqrt of 2. But, how do I prove case 2,3. Do I have to use addition/multiplication to prove them? |
| May26-05, 02:05 PM | #2 |
I'm not sure I understand your definition of D
is it equivilant to [tex] D=\{x\in Q | x\le 2\}\cup \{x\in Q | x^2 < 2\}[/tex] Which means [tex]D= \{x\in Q | x\le 2\}[/tex] which seems to contradict 2). Steven |
| May26-05, 05:36 PM | #3 |
D= {x: x [tex]\in[/tex] Q and (x [tex]\leq[/tex] 0 or x^2 < 2)} |
| May26-05, 07:01 PM | #4 |
Dedekind Cuts
1. Obviously, D is not empty- any negative number is in D. Obviously D is not all rational numbers, 2> 0, 22= 4> 2 so 2 is not in D.
3. if r is in D and s< r then either: a) r< 0 in which case r is in D or b) 0< r< s so 0< r2< s2< 2 so r is in D. 2. is the hard one. Obviously if r< 0, we can take s= 0. Ir r> 0, then r2< 2. Take d= 2- s2. Can you show that 0< (r+ d/4)2> 2? |
| May27-05, 06:25 PM | #5 |
if d= 2- s2 0< r + (2- s2)/4 > 2 Do I let r = sqrt(2) both plus and minus to show that 0< r > 2, so this will confirm the fact that r<s? |
| May28-05, 11:13 AM | #6 |
Sorry, there was a misprint! I mean 0< (r+d/4)2< 2. (not > 2)
Suppose r is the largest number in the set. It is obvious that (3/2)2= 2.25> 2 so 3/2 is not in this set. It is obvious that 1.42= 1.96 so 1.4 is in this set. Any possible maximum for the set must be greater than or equal to 1.4 and less than 1.5= 3/2: 1.4<= r< 3/2 and so d= 2- r2 must be less than or equal to 2- 1.96= 0.04. (r+ d/4)2= r2+ rd/2+ d2/16 so 2- (r+d/4)2= (2- r2)- rd/2- d2/16. 2- r2= d and since r< 3/2, rd/2< (3/4)d. d[sup]/16= d(d/16) and since d< 0.04, d/16< (.04/16)= (.01/4)= 0.0025. That is: 2- (r+d/4)2> d- (3/4)d- 0.0025d= d- (0.7525)d> 0 which means (r+ d/4)2. r+ d/4 is larger than r but (r+ d/4)2< 2 so r+ d/4 is still in the set contradicting the hypothesis that r is the maximum for the set. Therefore, the set has no maximum. |
| May28-05, 02:57 PM | #7 |
For the third proof, do I go onto assume that s is equal or greater than r to prove that it's a contradiction?
| May29-05, 12:28 PM | #8 |
Suppose r is in this set. There are two possibilities: r< 0 or r2< 2. (a) If r< 0 and s<= r, then s< 0 so s is in the set. (b) If 0<= r, r2< 2, and s< r then either (i) s< 0 so s is in the set (ii) s>= 0 so 0<= s2< r< 2 and s is in the set. In any case, if r is in this set and s< r, then s is in the set. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Dedekind Cuts
| UK Funding cuts | Academic Guidance | 0 | ||
| Dedekind Cut | General Math | 1 | ||
| Do tax cuts pay for themselves? | Current Events | 71 | ||
| Dedekind cuts | Linear & Abstract Algebra | 8 | ||
| Tricky Tax Cuts | Current Events | 11 | ||
