Integration by Parts: Solve x^2exp(-3x)dx
The discussion revolves around solving the integral of the function x^2 * e^(-3x) using integration by parts. Participants explore various methods and approaches to tackle the problem, including the tabular method and the assignment of variables in the integration by parts formula.
  • Homework-related
  • One participant expresses difficulty in applying integration by parts to the integral of x^2 * e^(-3x).
  • Another participant suggests taking dv = e^(-3x) dx and u = x^2 as a starting point.
  • A question arises regarding the integral of e^(-3x), with a proposed answer of -1/3 * e^(-3x).
  • Confirmation is provided that the integral of e^(-3x) is indeed -1/3 * e^(-3x) by differentiation.
  • One participant mentions that the tabular method could be effective for this integral and asks if others are familiar with it.
  • Another participant indicates uncertainty about the tabular method.
  • A participant shares their derived answer for the integral but expresses uncertainty about its correctness due to lack of solutions for the exercise.
  • One participant mentions that a software tool, Maple, agrees with their answer.
  • There is a reminder to include an arbitrary constant in the final answer.
  • A link to an external resource on the tabular method is provided for further reference.
Participants generally agree on the steps to take in solving the integral, but there is uncertainty regarding the correctness of the final answer and the application of the tabular method. No consensus is reached on the best approach.
Some participants express uncertainty about the tabular method, and there is a lack of definitive solutions for the exercise, which may affect the confidence in the derived answers.
cogs24
hi guys
just doing some revision and I am stuck on this question
*integral sign* x^2 . exponential ^ -3x . dx
I know i have to use integration by parts, but i just can't seem to get it out
any ideas?
thanx
HINT:Take [tex]dv=e^{-3x} \ dx[/tex] and [tex]u=x^2[/tex].
U'll figure out what to do next.
Daniel.
but, what is the integral of exponential ^ -3x?
is it -1/3 *exponential* ^ -3x?
Yes,as you can check by differentiation.
Daniel.
The tabular method would work great on this question. Are you familiar with this?
ok, once i sub u, du, v and dv into the integral by parts formula, i have to assign, u and dv again to:
-1/3 exponential ^ -3x and 2x
so is dv assigned to the exponential again, like in the first case?
no, i am not aware of the tabular method, sorry
ok, I've got my answer, unfortunately i don't kow if its right, we don't get solutions for this exercise
-1/3 *exponential* ^ -3x . x^2 - 1/9*exponential*^-3x . 2x - 2/27*exponential*^-3x
Maple agrees, good job.
Surely,you must add an arbitrary constant wrt "x" to your solution.
Daniel.
arbitary constant would be + c
In case you were interested in this method, http://marauder.millersville.edu/~bikenaga/calculus/parts/partspf.html is a link to the explanation. If one of the two terms will eventually differentiate to zero, this method is much less time consuming.
Jameson
i see, thanks for that link, i will probably apply this method from now on
  • · Replies 27 ·
  • · Replies 30 ·
