Engineering Mechanics Couple system question
The problem involves determining an equivalent force-couple system for a 25-lb force applied to a socket wrench's handle, with specific geometric constraints provided. The context is within engineering mechanics, focusing on force systems and moments.
  • Exploratory, Problem interpretation, Assumption checking
  • Participants discuss the nature of the problem, with some suggesting the need to find a force that cancels the applied force while maintaining the same moment about a point. Others explore the calculation of moments and forces at the origin, questioning their understanding of the requirements.
There is an ongoing exploration of the problem, with participants offering guidance on calculating the moment of the force with respect to the origin. Multiple interpretations of the approach are being discussed, indicating a productive exchange of ideas without a clear consensus yet.
Participants are navigating the specifics of the problem setup, including the geometry of the force application and the requirement to express the force-couple system at the origin. There is an emphasis on ensuring the calculations align with the problem's constraints.
Taiki_Kazuma
what is this problem searching for?
A 25-lb force acting in a vertical plane parallel to the yz plane is applied to the 8-in.-long horizontal handle AB of a socket wrench. Replace the force with an equivalent force-couple system at the origin O of the coordinate system.
See attached pic of the problem.
AO is 15-in.-long vertical
AB is 30 degrees off the x-axis
Force(in red) is 25-lb and is 20 degrees from the -z-axis
ok tell me if I"m wrong.
I think this problem is looking for the force that should be applied to cancel the other force but still have the same moment about O.
Please tell me if I'm thinking correctly...
however, how should I go about doing that? if that is the solution to this problem.
Not exactly. What you need to do is come up with a force and moment that, when applied at the point O, are equivilent to the lone force acting at the end of the handle.
ok, I think I get it...please correct me if I'm wrong (and let me know if I'm right)...
First I add vectors that are equal to F and -F at point O.
then I find the couple produced by F (original force) and -F. That will give me the answer of the couple moment at point O. and then I have F applied at O left over.
Is that what it is looking for?
I calculated the following answers:
M = 196.94i + 352.35j - 128.25k
F = -8.55j + 23.49k
Taiki, you only need to calculate the moment of F with respect to the origin, and put the rectangular representation of F. That should give you your Force-couple system at O.
  • · Replies 26 ·
9K
