Which acid more stronger
  • Thread starter taregg
  • Tags
    Acid
In summary, the strongest acid is fluorosulfonic acid with a pKa value of -14, followed by hydrochloric acid with a pKa value of -7. The strength of an acid is determined by its ability to donate a proton, with a lower pKa value indicating a stronger acid. However, corrosiveness is not directly related to the strength of an acid. An acid can be too strong, which can be dangerous and cause severe burns or damage to skin and materials. Proper safety measures should be taken when handling strong acids.
taregg
70
HI ACID OR HCl ACID
Chemistry news on Phys.org
Whats your interest in acid strength?
You can find this info easily on Google, both are really strong.
1. Which acid is the strongest?
The strongest acid is fluorosulfonic acid, with a pKa value of -14, making it over 10 quadrillion times stronger than vinegar.
2. How do you determine the strength of an acid?
The strength of an acid is determined by its ability to donate a proton (H+) in a solution. The lower the pKa value, the stronger the acid.
3. Is hydrochloric acid stronger than sulfuric acid?
Yes, hydrochloric acid (HCl) is stronger than sulfuric acid (H2SO4). This is due to the fact that the pKa value of HCl is -7, while the pKa value of H2SO4 is only -3.
4. Which acid is more corrosive?
Corrosiveness is not directly related to the strength of an acid. However, strong acids such as hydrochloric acid and sulfuric acid can be highly corrosive to certain materials.
5. Can an acid be too strong?
Yes, an acid can be too strong. Acids that are too strong can be dangerous and cause severe burns or damage to skin and other materials. It is important to handle strong acids with caution and proper safety measures.
