Calculating the Period of Binary Stars
The discussion revolves around calculating the period of binary stars, specifically focusing on the relationship between their masses, distances from the center of mass, and the gravitational forces acting on them. The original poster attempts to derive the period using the formula T² = 4π²(r₁ + r₂)³ / (G(m₁ + m₂)) and explores the implications of using different reference frames in their calculations.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss the definition of the center of mass and its implications for the calculations. There are attempts to derive the period from different reference frames, leading to questions about the independence of angular velocity from the choice of frame. Some participants express confusion regarding the rotational dynamics and the application of Kepler's laws.
The discussion is active, with participants providing insights and clarifications on the original poster's approach. Some guidance has been offered regarding the use of reference frames and the relationship between mass and distance in the context of binary star systems. Multiple interpretations of the problem are being explored, particularly concerning the effects of rotational motion.
Participants are navigating the complexities of non-inertial reference frames and the implications of rotational motion on their calculations. There is mention of constraints related to the assumptions made about the masses and their distances, as well as the application of Kepler's laws in this context.
StephenPrivitera
Hello.
Two binary stars (m1 and m2) orbit each other around their center of mass. They orbit in circles of radii r1 and r2. I am to show that the period is given by T2=4pi2(r1+r2)3/(G(m1+m2))
The mutual force between m1 and m2 is F=Gm1m2/(r1+r2)2
Considering m1, the acceleration of m1 is given by a1=Gm2/(r1+r2)2=v12/r1
Solving for v and using T1=2(pi)r1/v1=T2, I get T2=4pi2r1(r1+r2)2/(Gm2)
What did I do wrong?
I would reconsider the definition of "center of mass."
What precisely do you mean by "reconsider?" If I take the CM to be my reference frame (which I do), then m1r1=m2r2. I don't know how this helps. However, I noticed that if I take m2 to be my reference frame, then I get T2=4pi2(r1+r2)3/(Gm2). This is unexpected to me. I thought that omega was independent of reference frame so long as these reference frames have only translational motion wrt each other. Since T is indirectly proportional to omega, T should also be independent of reference frame. I'm clearly making some mistake here, but I can't figure out what it is.
Stephen, your original approach was exactly on target. You simply didn't finish it.
The mutual force between m1 and m2 is F=Gm1m2/(r1+r2)2 Correct.[/color]
Considering m1, the acceleration of m1 is given by a1=Gm2/(r1+r2)2=v12/r1 Correct.[/color]
Solving for v and using T1=2(pi)r1/v1=T2, I get T2=4(pi)2r1(r1+r2)2/(Gm2) Correct.[/color]
Now, remembering that m1r1 = m2r2
divide numerator by r1 and denominator by m2r2 /m1 giving you
T2=4(pi)2(r1+r2)2/(Gm1/r2)
Now multiply numerator and denominator by (r1+r2) giving
T2=4(pi)2(r1+r2)3/(G(m1r1 /r2+m1)
But m1r1 /r2 = m2 which is exactly what you wanted.
But I'm puzzled by your later statement which seemed to suggest that it would be OK to use m2 as a reference frame on the assumption that these frames have only translational motion wrt each other. How can you make this assertion when these frames are rotating about each other?
The frames would not rotate with respect to each other. If their axes were originally parallel, they would always be parallel. In that way, omega would be the same in either frame.
Edit:
I learned it yesterday actually in my physics book. Perhaps my inexperience with the new concept has caused me to use it incorrectly. In the book, it says that if an object rotates in a plane, then it rotates about any axis perpendicular to that plane. And no matter which axis is chosen, the angular velocity omega is the same (however, as they are noninertial frames, linear velocity is affected).
Edit:
Thanks for your answer. I would have never gotten that. It still took me ten minutes to finish the problem after I read your answer.
... if an object rotates in a plane, then it rotates about any axis perpendicular to that plane. And no matter which axis is chosen, the angular velocity omega is the same.
That's very interesting. I don't remember coming across that before. I imagine it will prove useful someday, but right now I'm having trouble visualizing it. In particular, does it still hold if you choose an axis that is outside of the objects orbit?
By the way, the equation you wrote using m2 as the reference frame is Kepler's Second Law, which we learned is only valid to describe the orbit of a body wrt another body which is so much larger that the mass of the smaller body can be ignored.
No it shouldn't matter where the axis lies, inside or outside of the orbit. I drew a picture to convince myself. The book actually used a rotating object as an example. It's easy to see then how the reference frame must move with the other particles in the object. When I was doodling with orbits it wasn't as clear how the RF should move.
The parallel axis theorem (having to do with moments of inertia I) states:
IR=0+MR2=IR=R
