Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Physics > General Physics
Reply
image Induction and Quantum Mechanics Share It Thread Tools image
Old May28-05, 05:11 AM                  #1
Ralph Hartley
Ralph Hartley is
Posts: n/a
<jabberwocky><div class="vbmenu_control"><a href="jabberwocky:;" onClick="newWindow=window.open('','usenetCode','to olbar=no,location=no,scrollbars=yes,resizable=yes, status=no,width=650,height=400'); newWindow.document.write('<HTML><HEAD><TITLE>Usene t ASCII</TITLE></HEAD><BODY topmargin=0 leftmargin=0 BGCOLOR=#F1F1F1><table border=0 width=625><td bgcolor=midnightblue><font color=#F1F1F1>This Usenet message\'s original ASCII form: </font></td></tr><tr><td width=449><br><br><font face=courier><UL><PRE>rof@maths.tcd.ie wrote:\n\n&gt; Yes, but the statements "Quantum mechanics accurately describes the\n&gt; statistics of measurement results" and "The principle of\n&gt; induction accurately describes the statistics of measurement\n&gt; results" both place constraints on the statistics of\n&gt; measurement results. Probability theory, in contrast, only\n&gt; has something to say about measurement results if one\n&gt; introduces a model for the process generating the results.\n&gt; That is, probability theory alone says nothing about the\n&gt; results of experiments, but becomes applicable if one\n&gt; introduces an extra hypothesis about the measurement\n&gt; results.\n\nQuantum mechanics alone does not tell you anything about the results of\nexperiments either. Just as probability theory requires a distribution,\nquantum mechanics needs at least a Hamiltonian (or something equivalent,\ndepending on the formulation being used).\n\nFortunately, we seem to inhabit a world in which both QM and induction\napply, so we can use induction to figure out at least some of the\nmissing information.\n\n&gt; Ralph Hartley &lt;hartley@aic.nrl.navy.mil&gt; writes:\n&gt;&gt;... they [QM and induction] don\'t say the *same* nontrivial thing. There are possible\n&gt;&gt;worlds in which induction works, but not quantum mechanics. I\'m pretty\n&gt;&gt;sure the reverse is true as well.\n&gt;\n&gt; ... It is logically\n&gt; possible for induction to work without quantum mechanics working\n&gt; because the principle of induction is vaguer than quantum mechanics\n&gt; and hence weaker.\n\nFurthermore it is by induction that we discovered QM. If induction was\ndependent on QM, I\'m not sure that would make sense. In a world in which\ninduction did not work, it would be impossible to tell if QM worked or\nnot (or anything else).\n\n&gt; Imagine what it would be like if induction didn\'t work\n&gt; at all. Experiments would give random results, and the\n&gt; information we would have in advance of an experiment\n&gt; about the result would be zero. Now, suppose the\n&gt; amount of information given by the result of the experiment\n&gt; is I=I1 + I2, where I1 is what quantum mechanics tells us\n&gt; and I2 is the "surprise" when we get the final result. In\n&gt; a world where induction didn\'t work at all, we would\n&gt; know nothing in advance about the result and so I1 would have\n&gt; to be zero, that is, quantum mechanics would be able to\n&gt; tell us nothing about the result.\n\nJust so. In a world in which induction does not work, QM would tell us\nnothing.\n\nLet\'s try constructing a toy world.\n\nAssume you can make a sequence of experiments. For each experiment you\nchoose an N bit number E_t, make a 1 bit "guess" G_t, and get back a one\nbit result R_t = w(E_t,t). Your goal is to be able to correctly guess as\nmany results as possible.\n\nConsider this game in which the results are produced by some process\nequivalent to a fair coin, and independent of the experiment E_t. In\nthis case you can never do better than chance. Induction doesn\'t help.\nYou can guess 1 every time, or 0, or you can flip a coin, it doesn\'t\nmatter. Your guesses will be right half the time.\n\nThis is the same regardless of how the process producing the results\nworks. It can be quantum or classical. It can even be a predetermined\nfunction of t and E_t.\n\nIn this world quantum mechanics indeed gives no information.\n\nWe can construct worlds in which induction (and/or QM) does work by\nputting restrictions on how the results are produced.\n\nFor example, we could require that the result be produced by a circuit\n(or a quantum circuit) with at most X gates, or by a program of length\nat most X. Induction will work in this world, but as X increases it will\nget harder.\n\nThese toy worlds may not be much like ours, but if one of them has a\ncertain combination of properties, then you *can* have a possible world\nwith those properties.\n\nRalph Hartley\n\n</UL></PRE></font></td></tr></table></BODY><HTML>');"> <IMG SRC=/images/buttons/ip.gif BORDER=0 ALIGN=CENTER ALT="View this Usenet post in original ASCII form">&nbsp;&nbsp;View this Usenet post in original ASCII form </a></div><P></jabberwocky>rof@maths.tcd.ie wrote:
> results.
> Ralph Hartley <hartley@aic.nrl.navy.mil> writes:
>>... they [QM and induction] don't say the *same* nontrivial thing. There are possible
>>worlds in which induction works, but not quantum mechanics. I'm pretty
> ... It is logically
> and hence weaker.
dependent on QM, I'm not sure that would make sense. In a world in which
> Imagine what it would be like if induction didn't work
> is LaTeX Code: I=I1 + I2, where I1 is what quantum mechanics tells us
> a world where induction didn't work at all, we would
nothing.
Let's try constructing a toy world.
choose an N bit number LaTeX Code: E_t, make a 1 bit "guessLaTeX Code: " G_t, and get back a one
bit result LaTeX Code: R_t = w(E_t,t) . Your goal is to be able to correctly guess as
equivalent to a fair coin, and independent of the experiment LaTeX Code: E_t . In
this case you can never do better than chance. Induction doesn't help.
You can guess 1 every time, or 0, or you can flip a coin, it doesn't
function of t and LaTeX Code: E_t .
We can construct worlds in which induction LaTeX Code: (and/or QM) does work by
get harder.
Ralph Hartley
Old May30-05, 01:22 AM                  #2
Charles Francis
Charles Francis is
Posts: n/a
Re: Induction and Quantum Mechanics
<jabberwocky><div class="vbmenu_control"><a href="jabberwocky:;" onClick="newWindow=window.open('','usenetCode','to olbar=no,location=no,scrollbars=yes,resizable=yes, status=no,width=650,height=400'); newWindow.document.write('<HTML><HEAD><TITLE>Usene t ASCII</TITLE></HEAD><BODY topmargin=0 leftmargin=0 BGCOLOR=#F1F1F1><table border=0 width=625><td bgcolor=midnightblue><font color=#F1F1F1>This Usenet message\'s original ASCII form: </font></td></tr><tr><td width=449><br><br><font face=courier><UL><PRE>In message &lt;d755qq\\$kn9\\$1@ra.nrl.navy.mil&gt;, Ralph Hartley\n&lt;hartley@aic.nrl.navy.mil&gt; writes\n&gt;&gt; Imagine what it would be like if induction didn\'t work\n&gt;&gt; at all. Experiments would give random results, and the\n&gt;&gt; information we would have in advance of an experiment\n&gt;&gt; about the result would be zero. Now, suppose the\n&gt;&gt; amount of information given by the result of the experiment\n&gt;&gt; is I=I1 + I2, where I1 is what quantum mechanics tells us\n&gt;&gt; and I2 is the "surprise" when we get the final result. In\n&gt;&gt; a world where induction didn\'t work at all, we would\n&gt;&gt; know nothing in advance about the result and so I1 would have\n&gt;&gt; to be zero, that is, quantum mechanics would be able to\n&gt;&gt; tell us nothing about the result.\n&gt;\n&gt;Just so. In a world in which induction does not work, QM would tell us\n&gt;nothing.\n&gt;\nInduction works as a pragmatic tool, but not as proof. But it is not\nnecessarily the case that we need induction. Einstein showed by thought\nexperiments that certain laws of relativity are necessary because of the\nway in which we go about measuring things. Likewise, as rof has pointed\nout, we do not need induction for the probabilistic part of quantum\ntheory.\n\nBut when we seek to apply simply the constraints which we can find on\nexperiment the mathematical structure becomes constrained. So\nconstrained in fact that we do not know how to satisfy it and combine\ngeneral relativity and qm. In fact we cannot even resolve all the issues\nfor a special relativistic theory.\n\nI do not believe that the physical universe can be inconsistent, and\ntherefore I believe it must be describable by a consistent mathematical\nstructure. I very much doubt that much induction will be left once we\nhave found such a mathematical structure.\n\n\nRegards\n\n--\nCharles Francis\n\n</UL></PRE></font></td></tr></table></BODY><HTML>');"> <IMG SRC=/images/buttons/ip.gif BORDER=0 ALIGN=CENTER ALT="View this Usenet post in original ASCII form">&nbsp;&nbsp;View this Usenet post in original ASCII form </a></div><P></jabberwocky>In message <d755qq$kn9$1@ra.nrl.navy.mil>, Ralph Hartley
>nothing.
theory.
Regards
Charles Francis
Old May30-05, 11:12 PM                  #3
rof@maths.tcd.ie
rof@maths.tcd.ie is
Posts: n/a
<jabberwocky><div class="vbmenu_control"><a href="jabberwocky:;" onClick="newWindow=window.open('','usenetCode','to olbar=no,location=no,scrollbars=yes,resizable=yes, status=no,width=650,height=400'); newWindow.document.write('<HTML><HEAD><TITLE>Usene t ASCII</TITLE></HEAD><BODY topmargin=0 leftmargin=0 BGCOLOR=#F1F1F1><table border=0 width=625><td bgcolor=midnightblue><font color=#F1F1F1>This Usenet message\'s original ASCII form: </font></td></tr><tr><td width=449><br><br><font face=courier><UL><PRE>Ralph Hartley &lt;hartley@aic.nrl.navy.mil&gt; writes:\n\n&gt;&gt; Imagine what it would be like if induction didn\'t work\n&gt;&gt; at all. Experiments would give random results, and the\n&gt;&gt; information we would have in advance of an experiment\n&gt;&gt; about the result would be zero. Now, suppose the\n&gt;&gt; amount of information given by the result of the experiment\n&gt;&gt; is I=I1 + I2, where I1 is what quantum mechanics tells us\n&gt;&gt; and I2 is the "surprise" when we get the final result. In\n&gt;&gt; a world where induction didn\'t work at all, we would\n&gt;&gt; know nothing in advance about the result and so I1 would have\n&gt;&gt; to be zero, that is, quantum mechanics would be able to\n&gt;&gt; tell us nothing about the result.\n\n&gt;Just so. In a world in which induction does not work, QM would tell us\n&gt;nothing.\n\n&gt;Let\'s try constructing a toy world.\n\n&gt;Assume you can make a sequence of experiments. For each experiment you\n&gt;choose an N bit number E_t, make a 1 bit "guess" G_t, and get back a one\n&gt;bit result R_t = w(E_t,t). Your goal is to be able to correctly guess as\n&gt;many results as possible.\n\n&gt;Consider this game in which the results are produced by some process\n&gt;equivalent to a fair coin, and independent of the experiment E_t. In\n&gt;this case you can never do better than chance. Induction doesn\'t help.\n&gt;You can guess 1 every time, or 0, or you can flip a coin, it doesn\'t\n&gt;matter. Your guesses will be right half the time.\n\n&gt;This is the same regardless of how the process producing the results\n&gt;works. It can be quantum or classical. It can even be a predetermined\n&gt;function of t and E_t.\n\n&gt;In this world quantum mechanics indeed gives no information.\n\nQuantum mechanics, considered as a recipe for predicting the\nreults of future measurements, works better than chance\nonly if induction works better than chance.\n\nYou didn\'t deny this, but instead hypothesised a "real world",\nwhich was invisible, but contained the "process producing\nthe results", and supposed that quantum mechanics could work\nthere, and hence still "work" even though induction didn\'t.\n\nIt was, or should have been, clear that when I was referring\nto quantum mechanics I meant the formalism which is used to\nassign probabilities to measurement results, not "what\'s\ngoing on in the real world". If the former works, meaning\nallows you to predict meaurement results better than\nchance, then induction also works.\n\nR.\n\n</UL></PRE></font></td></tr></table></BODY><HTML>');"> <IMG SRC=/images/buttons/ip.gif BORDER=0 ALIGN=CENTER ALT="View this Usenet post in original ASCII form">&nbsp;&nbsp;View this Usenet post in original ASCII form </a></div><P></jabberwocky>Ralph Hartley <hartley@aic.nrl.navy.mil> writes:
>nothing.
You didn't deny this, but instead hypothesised a "real world",
there, and hence still "work" even though induction didn't.
assign probabilities to measurement results, not "what's
R.
Old Jun1-05, 12:42 AM                  #4
Marcel LeBel
Marcel LeBel is
Posts: n/a
<jabberwocky><div class="vbmenu_control"><a href="jabberwocky:;" onClick="newWindow=window.open('','usenetCode','to olbar=no,location=no,scrollbars=yes,resizable=yes, status=no,width=650,height=400'); newWindow.document.write('<HTML><HEAD><TITLE>Usene t ASCII</TITLE></HEAD><BODY topmargin=0 leftmargin=0 BGCOLOR=#F1F1F1><table border=0 width=625><td bgcolor=midnightblue><font color=#F1F1F1>This Usenet message\'s original ASCII form: </font></td></tr><tr><td width=449><br><br><font face=courier><UL><PRE>\n&gt;\n&gt; You didn\'t deny this, but instead hypothesised a "real world",\n&gt; which was invisible, but contained the "process producing\n&gt; the results", and supposed that quantum mechanics could work\n&gt; there, and hence still "work" even though induction didn\'t.\n&gt;\nThis is like watching someone bathing in quicksand right in front of the\nwarning sign! Do you have any idea of what you are doing or even of\nwhat you want? Sure, there is (A) a real universe out there made of\nsome mush substance with its built-in processes and causes. Then there\nis (B)our reality which is a total construct, which is how we experience\nthe variations this mush has to offer given the way we are built, our\nsize and the way we think. An then there is (C)our scientific analysis\nof our experience of that mush. So you see, you are a long way from\nbeing able to say what is, and what is not about that mush. So, what is\nit that you want? Do you want to understand what the universe is made of\nand how it works by itself?(It does) To that question there is a single\npossible answer and you need an ontological analysis for that. If not,\nwhat is it that you are trying to do? ????? I suggest an ontological\nanalysis of (C) in order to elucidate (A), which will come back as\nunderstanding, not experiencing. There is some good in understanding\n(you know)that we can apply to (C) and in turn physically turn into\nstuff in (A).\n\nPhilosophy is just that; standing back for a moment and asking yourself\nwhere you are and what you are trying to achieve. Good luck!.\n\nsuggestion applies to both parties.\nlebel@muontailpig.com ------- remove particle\n\nMML\n\n</UL></PRE></font></td></tr></table></BODY><HTML>');"> <IMG SRC=/images/buttons/ip.gif BORDER=0 ALIGN=CENTER ALT="View this Usenet post in original ASCII form">&nbsp;&nbsp;View this Usenet post in original ASCII form </a></div><P></jabberwocky>You didn't deny this, but instead hypothesised a "real world",
stuff in (A).
MML
image image
Reply
Thread Tools
Similar Threads for: Induction and Quantum Mechanics
Thread Thread Starter Forum Replies Last Post
Quantum physics vs. Quantum Mechanics WarrickF Quantum Physics 27 Jul10-07 02:44 PM
Quantum physics vs. quantum mechanics Mattara Quantum Physics 3 Mar21-06 10:05 PM
Is Quantum Mechanics and Quantum Physics the same? MohammadK Quantum Physics 28 Oct4-05 04:54 PM
Ontological Domains (was Re: Induction and Quantum Mechanics) Mike Helland General Physics 1 Jun3-05 02:03 AM
Quantum Physics / Quantum Mechanics Lil`SciWizGirl Quantum Physics 3 Apr1-05 09:50 AM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
