Saturn Speed: Can You Ease On At 1mph?
  • Context: High School
  • Thread starter Thread starter TonySlim
    Saturn
The discussion revolves around the feasibility of driving a front-wheel drive car onto a moving car carrier at a speed of 1mph while the carrier is traveling at 99mph. Participants explore the dynamics involved, including traction, tire performance, and acceleration relative to the truck.
  • Some participants suggest that attempting to drive onto the truck at 1mph while the truck is at 99mph could result in the car flying off at a much higher speed if not executed correctly.
  • Others propose that pressing the clutch before hitting the ramp could prevent the tires from spinning excessively, potentially allowing for a safer transition onto the truck.
  • There are concerns about the tires' ability to handle the sudden change in speed and the possibility of them disintegrating due to the rapid deceleration required.
  • Some participants argue that a skilled driver might be able to manage the transition with practice, although it would still be risky.
  • There is a suggestion that rear-wheel drive cars might perform better in this scenario due to different traction dynamics compared to front-wheel drive cars.
  • A few participants mention specific vehicle recommendations, such as an early 80's Toyota Corolla, citing its rear-wheel drive configuration and affordability as advantages.
Participants do not reach a consensus on the feasibility of the maneuver, with multiple competing views regarding the necessary conditions for success and the risks involved. The discussion remains unresolved.
Limitations include assumptions about vehicle performance, tire durability, and the specific dynamics of the ramp transition, which are not fully explored or quantified.
TonySlim
if you drive a front-wheel drive car 100mph onto the back of a car carrier driving 99mph, could you ease it on at 1mph, or would it fly off the front at 100mph? I need to know before my drive home tonight.
If I were you, I wouldn't try this.
If on the off chance you are trying an italien job, I would suggest using a rear wheel drive car.
If your only option is a front wheel drive car (I'm assuming that you are insane for trying this), you could get a run up at say, 105mph and just before you hit the ramp, press the clutch.
You should be able to roll your front wheels onto the ramp before driving up the rest of the ramp "normally".
Of course this will not be the best thing you could do to your tyres as they will have to reduce their angular velocity very quickly indeed.
Edit: If you didn't press the clutch before you hit the ramp, then your tyres will spin and rip most of the tread off, while accelerating at the maximum rate that the grip of your shredded tyres will allow, and you will be propelled off the end of the transporter at well over 100mph, then when you come crashing down, the transporter will most likely crash into you.
Well, good luck.
I think the outcome would be somewhere inbetween. First of all few front wheel dirve cars could accelertate rapidly enough to fly off the front. At 100MPH a 19" wheel is turning at nearly 1800RPM, at 1MPH it is turning at 18 RPM. There is not enough traction or power for the car to accelerate to 100MPH RELATIVE to the truck, this would be the scenario of flying off the front. But the wheels are spinning and being DRIVEN by the engin at a rate 100x needed when you get onto the truck. Something would have to give. My bet would be the tires. I see lots of smoke, and rubber flying every where. YOu can take if from there.
I am not saying that a skilled driver could not pull it off, it would take practice at much lower speeds. Perhaps it is possible to drop your engine RPMs fast enough to stay on the truck and not destroy your tires.
One thing is certian the car will NOT race across the truck at 100MPH.
As I said above, I doubt that tires are make that could pull this off. Once your tires have disintegrated you would stop accelerating.
Remember to travel off the front end of the truck at 100mph your velocity with respect to the ground must be 200mph. American sedans simply do not have the power to do this nor are tires made that could live though this experience.
I think your approach scheme is the best bet for getting on.
I was talking about over 100 mph relative to the ground. You could stop the engine from driving the car by simply pressing the clutch.
Travel slightly faster than the truck, but for god's sake hit the clutch before you hit the ramp.
Even with the clutch in, tires don't stop spinning instantly. They have inertia. A tire coupled to the engine would have it worse because the engine has some energy in it, but it really doesn't matter if its a front or a rear wheel drive car.
Well, if its a rear wheel car, then you can use the pavement to decel just a bit before hitting the truck. Then you wouldn't lose as much traction as compared to a ff car when the drive wheels hit the slick(er then pavement) metal surface.
Can I recommend an early 80's toyota corrolla for the task? Its FR, makes a decent amount of power, and if your luck you can find one for $50-$500.
Well I did say:
79 Corolla is a great beater car.
Got mine for $1, sold it for $50!
ask to michael knigth,
have i wonder this
but it can be done since they did it
  • · Replies 16 ·
  • · Replies 66 ·
  • · Replies 60 ·
