Anyone know of good sites that teach you tricks to solving physics problems?
The discussion revolves around seeking resources or strategies to enhance problem-solving skills in physics, particularly through the use of "tricks" or shortcuts that may not be covered in textbooks. Participants share various equations and principles related to basic physics concepts, such as projectile motion and fluid mechanics.
  • Participants discuss the value of understanding fundamental principles versus relying on memorized equations. Some suggest deriving equations from basic concepts, while others question the effectiveness of "tricks" in unfamiliar problem contexts. There are mentions of specific equations and scenarios, such as projectile motion and forces in fluid dynamics.
The conversation is ongoing, with multiple perspectives being explored. Some participants emphasize the importance of conceptual understanding over memorization, while others seek practical tips for applying physics principles effectively. There is no explicit consensus, but a general inclination towards deeper comprehension is noted.
Participants highlight the potential pitfalls of relying on specific tricks without a solid grasp of underlying concepts. There are references to assumptions that may affect the applicability of certain equations, such as the angle of an incline or the conditions of projectile motion.
michaelw
With equations or facts that are not given in textbooks?
Just things that can help you solve problems faster with general basic physics
for example, the acceleration of a block on a frictionless incline is gsin(theta)
the volume displaced by a block in a water is (volume of block) * (specific gravity of block)
or, in hydraulic lifts, F1/A1 = F2/A2, F1d1 = F2d2
or, fraction submerged of something (x) in a water is = the specific gravity of x
or, the max height of a projectile can be solved by vsin(theta) = sqrt(2gh)
things like that :)
You can get those yourself by just deriving them from the concepts taught in the book... :rolleyes:
some hints
I think a lot of your equations are too specific. Use more general principals and cancel out terms.
For example, with your equation to predict the height of a projectile you simply state an equation. I don't like this approach because it requires memorization of a formula and not a process.
Start problems with basic equations and assumptions. It seems for the physics you are taking that constant acceleration and neglegible air resistance are all good assumptions. With these assumptions we can write the displacement of a particle as X = X0 + volt + 1/2at^2
Take this equation and let's apply it to the y direction
Y = Yo + Voyt + 1/2at^2
If we start at ground level, our initial displacement in the y direction is 0
Also if we take up to be positive then the acceleration term must be negative because we have downwards acceleration. So the taylored for of this equation becomes
Y = Voyt - 1/2at^2
Now you have an equation to decribe the y position of a particle for projectile motion starting at ground level with constant volt and neglegible air resistance and non zero initial velocity pointing upwards.
Quite specific huh?
Typically you won't know everything though in this equation. Well what's true about the velocity in the y direction of a particle at the top of its motion? It has to be zero right? It can't go up any higher than its max height so the velocity in the y must be zero at this point. This gives us
0 = Voy - at
We can solve this for t and get t = Voy/a
Plug it into our very specific equation about 12 lines up and you'll get the same formula for max height. Using this principle you just need to think about what you have.
For force problems ALWAYS ALWAYS ALWAYS draw and FBD. If you draw your forces correctly all you need to do is model them and set them equal to m*a.
In momentum problem...when is momentum a constant? Well momentum is the integral of external forces on a system with respect to time. So the integral of what gives us a constant? How about zero... Integral of 0 is just equal to zero + C. So linear momentum is conserved when the sum of external forces on a system is zero.
Basically what I am doing here in all these problems is just taking very general concepts and doing some basic math.
What about energy how do you do that. Well in most mechanics problems I've seen at this level the only energies you need to model are potential, spring, kinetic, and frictional. Remember Energy Initial = Energy Final + Energy Lost
I like to use this definition because then I use positive terms only. There are no negatives. So with energy it will always be true that...
KEo + PEo + Uo = KEf + PEf + Uf + |Wf|
KE = Kinetic energy
PE = Potential energy
U = Elastic Energy
|Wf| = Magnitude Of Work Done By Friction
michaelw, what text are you using - what is your major?
"no pain no gain"
The trouble with remembering "tricks" to help you solve certain types of problems is that they won't help you at all when you're confronted with a problem you haven't seen before. It is FAR better to understand the relevant physical principles than to rely on "tricks" to solve problems.
Of course, that depends on your end goal. If you just want to pass exams, then tricks may be enough. If you really want to learn physics, you need to learn the concepts.
I totally agree with the overall sentiments of the respondents when they say that you should go for understanding on a more general level. Cases in point...
Unless "theta" happens to be the angle that the incline makes with the vertical, rather than the horizontal.
Unless the particle is launched from an elevated platform, and the height h is measured from the ground.
Physics is not meant to be learned formulaically. It is meant to be learned from first principles. That's the difference between a scientist/engineer and a technician.
I agree
what about tips/facts that help you understand physics concepts more clearly?
For example, if there was a charged plate infinitely high and wide, then no matter how far you move a charged particle from the plate, it will always have the same electric field affecting it, and thus the same force (it becomes independent of radius, since the field lines coming out from the plate have nowhere to go, thus there is a constant electric field present)
Things like that :)
Anyone have any tips where to find such things?
I think , the tricks you are talking about should be learned from the books itself.Some of the books on competitive exams provide a good insight on short tips . Moreover, you can develop a habit of first understanding the concept and then derive the formula and know when and where the forumula is applicable.
michaelw said:
I agree
I think that the "tips" are the laws of physics themselves, combined with the relevant principles of mathematics. There are no short-cuts to replace thinking and exprerience. That's how you acquire the knowledge of a large number of special cases.
Physics is best learned by going from the general to the specific.
19K
11K
34K
