Finding G-Force & Pressure in Fluid Flow: Aluminium Sphere Case
The discussion revolves around calculating the gravitational force and acceleration of an aluminum sphere, as well as determining pressure changes in a fluid flowing through a hose. The problem involves concepts from fluid dynamics and gravitational physics.
  • Participants discuss the relationship between gravitational force and the sphere's weight, suggesting the use of density and volume to find mass. Questions arise regarding the relevance of water resistance in this context. For the pressure aspect, there are inquiries about how to calculate pressure differences using given area and velocity data.
Participants are exploring different interpretations of the gravitational force and pressure calculations. Some guidance has been offered regarding the use of density and the Bernoulli equation, but no consensus has been reached on the best approach to take.
There is mention of needing specific values such as the density of aluminum and the pressures at certain points in the hose, which may not have been provided in the original problem statement.
cogs24
hi guys
if you have an aluminium sphere of volume 0.006 metres cubed, how do you find the gravitational force acting on the sphere, as well as its acceleration (ignoring water resistance)
Also, if your given the area and velocity of a fluid at two points of hose, how can you find the pressure at these two points in the hose?
What does water resistance have to do with gravitational force? You need to state the entire problem and maybe we can help. The force due to gravity is simply the sphere's weight.
You are going to have to know one of the pressures to calculate the other, or you could calculate the delta P between the two points, but that won't tell you anything about the individual pressures. For simplicity, use the Bernoulli equation.
You probably have a table that lists the density for aluminum. You'll need that.
The "gravitational force acting on the sphere" is just its weight. Look up the density of aluminum and multiply by the volume of the sphere. (The volume of a sphere of radius r is [tex]\frac{4}{3}\pi r^3[/tex].)
HallsofIvy was correct, the gravitational force is just its weight, its simple
use desnity of aluminium along with its volume to find the mass, then use this is W=mg formula to find the the weight force
In terms of the pressure question, i know the area and velocity of the fluid at 2 points, its asking how much the pressure changes as it goes from one point to another.
  • · Replies 16 ·
  • · Replies 22 ·
  • · Replies 16 ·
  • · Replies 28 ·
  • · Replies 56 ·
