Dynamics Problem HELP - Free body diagram
The discussion revolves around a dynamics problem related to golfing putts on a slope. The original poster is tasked with comparing the difficulty of uphill versus downhill putts, considering factors such as friction, mass of the ball, and the slope of the green. They are also required to draw free body diagrams and determine the range of speed needed for the ball to stop within a certain distance from the hole.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • The original poster attempts to analyze the forces acting on the ball using free body diagrams and mathematical equations. They express uncertainty about their calculations and seek clarification on the meaning of variables used in their equations. Other participants question the definitions of the forces involved and the appropriateness of the calculations presented.
Participants are actively engaging in clarifying the problem and the calculations presented. Some guidance has been offered regarding the need to check units and the assumptions made in the original poster's approach. Multiple interpretations of the problem are being explored, particularly concerning the forces acting on the ball and the method for determining the initial velocity needed for the putts.
The original poster has mentioned constraints related to the assignment, including the requirement to use free body diagrams and the challenge of determining the range of speed for the putt. There is also a note about the difficulty in sharing visual aids due to file size limitations.
coglon
IM in Phys.20 Got this question for an assignment. Tried it and got stuck. I really need help
When golfing, uphill and downhill putts present different levels of difficulty. Suppose a green has a 5.0 degree slope and the force of friction will be 0.10N against the ball's motion. The ball has a mass of 46g and the length of putt will be 10.0m.
Which putt (uphill or downhill) presents a greater level of difficulty? Explain your reasoing using appropriate calculations
Draw Free body diagrams for both purrs. Find range of speed you may give the ball on each type of putt so that even if you miss the ball will stop within 1.0m of the hole.
I know uphill would be more difficult because it requires more force but I am having a hard time proving this using Free body diagrams and mathematical reasoning.
THANKS FOR THE HELP,
Coglon
Dynamics -- Still stuck.. need ideas
Fm=Fa+Fg
46^2=Fa+9.81^2
Fa=[squ]2019.7639
fa= 44.9m/s^2
F=Ma
=46g*44.9m/s^2
=2065N
Using Free body diagrams I believe I figured out that it would take...
43.8N downhill and 64.3N uphill
Im not sure if the above calculation are at all close and I cannot show you my Free Body Diagram due to the attach file would be too large and would not be readable to fit in attachment... I am have no clue how to determine the range of speed used to get the putt within 1.0m and whether or not I should be using some kinematic equations.
Thanks for help,
Coglon
Hi coglon,
welcome to the forums.
This is an interresting problem...
Originally posted by coglon
Fm=Fa+Fg
46^2=Fa+9.81^2
Fa=[squ]2019.7639
fa= 44.9m/s^2
F=Ma
=46g*44.9m/s^2
=2065N
Uh, not exactly sure what you're trying to do here. What do Fm, Fa, and Fg represent?
You also need to check your units. A Newton is 1kg*1m/s2, not 1g*1m/s2
You aren't going to be able to supply it with a force over the entire length of the path. The problem is assuming you bump it to give it an initial velocity (not caring the physics of the bump), and then applying friction and gravity forces to slow down/speed up the ball.
What type of file is it?
The way I see it, you'll need to do 4 different equations for two different cases. You will know the final velocity (0), and through the free body diagrams you can find the total force for the two cases. You'll be solving for initial velocities given a final position of 9m and 11m (one meter past the hole and one meter in front of the hole) for each case.
I will second enigma in his wondering if you really have looked carefully at what you are doing. In addition to writing Fm= Fa+Fg without telling us what Fm, Fa, Fg mean (I would guess that Fg is "force of gravity", perhaps Fm is the net force on the ball. Would Fa be the friction force?) you have replaced Fm with (46)2 and Fg with (9.81)2. The only "46" in the problem is mass of the ball: 46 grams and I would guess that "9.81" is the acceleration due to gravity. Neither (46g)2 nor (9.81 m/s2)2 is a force and since they don't have the same units, they certainly would not fit into that equation no matter what Fm, Fa, or Fg were supposed to be.
  • · Replies 38 ·
  • · Replies 25 ·
