Thread Closed
Actual Depth and Apparent Depth
Share Thread Thread Tools
Jun1-05, 10:27 AM   #1
Okay, I need a bit of a jump start with this question, I know how to find the Apparent depth normally, but I've never done actual depth and I can't really figure it out (*stupid*)
11. Frederika is sitting in her fishing boat observing a rainbow trout swimming below the surface of the water. She guesses the apparent depth of the trout at 2.0m. She estimates that her eyes are about 1.0m above the water's surface, and that the angle at which she's observing the trout is 45degrees....
b)Calculate the actual depth of the trout.
please help ~_~
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Jun1-05, 12:29 PM   #2
Ok I hope you know something about "what refractive index" does ?
If we are looking from air into water then the refractive index m is related as:
[latex]
m=\frac{realdepth}{apparentdepth}
[/latex]
First try to draw figure of above situation using correct laws for refraction and a good ray diagram will definitely help..show your work...help will follow..
Jun1-05, 08:22 PM   #3
Recognitions:
Homework Helper Homework Help
If your fuzzy on refraction you might want to take a look at this reference
If you read along, you will see they discuss depth perception.
I agree with Doc, to try and draw a complete diagram of the information given. It makes the analysis much easier.
Jun14-05, 02:26 PM   #4
I decided to give my brain a bit of a rest on this problem and moved forward. I think I may have it, I'd still like to see if it's accurate or get help if it's completely wrong (which is very likely) Here's what I have so far:
Analysis:
n[i] = 1.33 for water
n[2]= 1.00 for air
Actual depth= (sine{angle}i)(d)
tanZ = tan{angel}R = d/h, therefore d= (h)(tan{angle}R)
{Angle}R = (n[i])(sin{angle}i)/(n[2])
Solution:
sin{angle}R = (3.00)(0.071)/(1.00)
= 0.9404
{angle)R = 70.1*
d = (3.0m)(tan70.1*)
= (3.0m)(2.762)
= 8.286m
Actual Depth = (sin{angle}i)(d)
= (sin45*)(8.286m)
= (0.7071)(8.286m)
= 5.859m
Therefore the actual depth of the fish is 5.859m.
Hope this is right this problem is driving me nuts!!
Jun14-05, 03:01 PM   #5
Mentor
Quote by chibi_lenne
According to your diagram, that should be: Actual depth = [itex]d/ \tan \theta_i[/itex]. Note that d = 2.0 m, since [itex]\theta_r[/itex] is 45 degrees.
Jun14-05, 06:19 PM   #6
Quote by Doc Al
Now I'm confused...how is d = 2.0m? if I did the equation for actual depth with that as d, it would mean the actual depth is the same as the apparent depth?
Actual depth = (2.0m)/tan45*
= (2.0m)/(1.0)
= 2.0m
Jun14-05, 06:47 PM   #7
Mentor
This can be deduced from the statement of the problem: The apparent depth is 2 m and the angle is 45 degrees.
No.
= (2.0m)/(1.0)
= 2.0m
No. Actual depth = [itex]d/ \tan \theta_i[/itex], not [itex]d/ \tan \theta_r[/itex]
Jun14-05, 07:18 PM   #8
okay, so I have to find the angle of incidence....so how do I do that? x.x
Jun14-05, 07:20 PM   #9
Mentor
By applying Snell's law for refraction.
Jun14-05, 07:44 PM   #10
duh *slaps forhead* alright I have to rearrange the formula, I feel stupid now. So it should be:
(ni)(sin{angle}i) = (nR)(sin{angle}R) so therefore
sin{angle}i = (ni)/(nR)(sin{angle}R)
Jun14-05, 07:54 PM   #11
Mentor
I believe you made an error in reaching your second equation.
Snell's law tells us:
[tex]n_1 \sin \theta_1 = n_2 \sin \theta_2[/tex]
So:
[tex]\sin \theta_1 = (n_2/n_1) \sin \theta_2[/tex]
Jun14-05, 08:16 PM   #12
Quote by Doc Al
So:
ooo I see, (forgot to put in an extra set of () ) so it should be:
[tex] \sin \theta_i = (1.00/1.33) (0.8509)[/tex]
[tex]
= 0.6398 [/tex]
[tex] \theta_i = 39.6* [/tex]
Jun15-05, 08:02 AM   #13
Mentor
Where does the "0.8509" come from??
Jun15-05, 10:05 AM   #14
Quote by Doc Al
[tex] 0.8509 = \sin45*[/tex]
Or at least that is what I was doing....
Jun15-05, 10:31 AM   #15
Mentor
Better double check that result!
Jun15-05, 11:29 AM   #16
gah what am I doing wrong? x.x
Jun15-05, 11:33 AM   #17
Mentor
Ah, now I see what you did... You have your calculator set for radians, not degrees.
Thread Closed
Thread Tools
Similar Threads for: Actual Depth and Apparent Depth
Thread Forum Replies
physics - optics - apparent depth Introductory Physics Homework 4
Apparent & Actual Depth Introductory Physics Homework 7
Apparent Depth? Introductory Physics Homework 1
setup help needed:apparent depth vs. actual depth Introductory Physics Homework 17
Apparent Depth Problem Introductory Physics Homework 3
