Some specific questions about waves
  • Thread starter Thread starter PinkSheep
    Specific Waves
This discussion focuses on wave mechanics, specifically addressing the relationship between tension, wave speed, amplitude, and power in a taut string. To double the wave speed, the tension must be increased by a factor of four, as derived from the equation v = √(T/(m/L)). Additionally, when power is doubled, the amplitude increases by a factor of √2, while the speed remains constant. The discussion also clarifies how to calculate wavelength using the formula wavelength = speed/frequency, with an example showing a speed of 2.5 m/s and a frequency of 80 cps, leading to a wavelength of 0.03125 m.
  • Understanding of wave mechanics and properties of waves
  • Familiarity with the equation v = √(T/(m/L)) for wave speed
  • Knowledge of harmonic motion and energy relationships
  • Ability to calculate frequency and wavelength
  • Study the relationship between tension and wave speed in different mediums
  • Learn about the energy of harmonic oscillators and its effect on amplitude
  • Explore the derivation and application of the wave equation v = fλ
  • Investigate the effects of power changes on wave properties in various systems
Students preparing for physics exams, educators teaching wave mechanics, and anyone interested in the principles of wave behavior in strings and oscillators.
PinkSheep
Okay, I have this study guide for a test, but I'm having troubles figuring out the answers...so these are some things I'm wondering:
1. If you have a taut string, by what factor would you have to increase the tension to double the wave speed?
I think it's 4, but I'm not sure.
2. If a string is under constant tension and generates a harmonic wave, by what factor would the amplitude and speed change if the power is doubled?
I have no clue on this one.
3. And how would you go about solving this problem: A sinusoidal wave is traveling along a rope. The oscillator that generates the wave completes 40 vibrations in 30s. A given peak travels 5m along the rope in 2s. What is the wavelength?
I know wavelength equals speed divided by frequency...but I don't know what to use as speed or frequency, so therein lies my problem.
Any help and/or explanations would be greatly appreciated.
Why don't you try it at the equation so you will be sure?
[tex]v = \sqrt{\frac{T}{\lambda_{density}}[/tex]
Example
[tex]v = \sqrt{\frac{4T}{\lambda_{density}}[/tex]
[tex]v = 2 \sqrt{\frac{T}{\lambda_{density}}[/tex]
[tex]v_{new} = 2 v_{old}[/tex]
What is the definition of frequency?
frequency = oscilations/time
Use:
[tex]v = \sqrt{\frac{T}{m/L}}[/tex]
The energy of a mass, dm, undergoing simple harmonic motion, is proportional to the square of its amplitude. This is apparent, for example, in a mass spring system where the energy of the mass is [itex]\frac{1}{2}kx^2[/itex].
The power is the time rate of change of energy. So how is the power related to the speed and the square of the amplitude?
The speed is 2.5 m/sec. The frequency is 80 cps. Solve for wavelength.
AM
  • · Replies 23 ·
  • · Replies 23 ·
  • · Replies 17 ·
