Thread Closed
an oldie
Share Thread Thread Tools
Jun2-05, 11:38 AM   #1
Recognitions:
Gold Membership Gold Member
an oldie
I know that crop circles have been discussed to death but, has all the data
gleaned from the investigations of these anomalies shown that they are hoaxes
ie the node explosions?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Jun2-05, 11:42 AM   #2
Recognitions:
Homework Helper Homework Help
Yes, node explosions create hoax circles.
Jun2-05, 01:47 PM   #3
Recognitions:
A "node explosion", is explained by the water in the plant stem boiling, by
some unknown process, which bursts the stem at a node.
Jun2-05, 02:01 PM   #4
an oldie
Here is some research which talks about an 'electromagnetic point (or spherically shaped) radiation source at a height of 4.1 meters above the ground':
http://archiv.fgk.org/99/Berichte/Hoeven99/index.shtml
The symmetry found for pulvinus length increase in an extensive amount of sampling data from one of the investigated crop circles is remarkable, and seems to lack trivial explanations. Moreover, the pulvinus length increase of 118% is an order of magnitude more compared with results from control studies performed earlier by the BLT team.
The results shown in Graph 5 indicate that the pulvinus length increase in one of the circles corresponds perfectly to the radiation intensity on the ground resulting from an electromagnetic point (or spherically shaped) radiation source at a height of 4.1 meters above the ground. The high correlation coefficients seem to provide physical evidence of the statements made by the eye witness, mentioning the involvement of ‘balls of light’ and ‘heat’.
Consequently, the observations described in this report are in agreement with the hypothesis that pulvinus lengthening in crop circles is a thermo-mechanic effect, induced by heat from a point source with (at least some) electromagnetic properties.
Jun3-05, 07:01 AM   #5
Recognitions:
Thanks PIT2
A very interesting paper
Jun3-05, 07:27 AM   #6
Recognitions:
This paper convinces me that a unknown force is at work.
http://www.bltresearch.com/dispersion.html
Jun3-05, 07:41 PM   #7
Recognitions:
Retired Staff Staff Emeritus
I tend to think that genuine anomalies are found, probably the simple donut shaped impressions that go way, way back, and if in fact strong EM effects were present - in these cases involving the so called exploded nodes - these are probably due to ball lightning, or a close but unrecognized cousin.
As a seat of the pants notion, one thing has always interested me is the idea that a field of wheat or grass at the peak of its pollen cycle, on a dry day or night, might be capable of generating a fairly high static potential. This struck me while watching a dark cloud of smoke, actually grass pollen, wafting around the valley below our place here in Oregon at the peak of the season. With the billions [?] of prickly protrusions, and the pollen to act as a charge carrier, it seems possible that a signficant local potential might be generated. Note that grain dust is famous for static charge generated explosions. Dust can be an excellent charge carrier.
Jun4-05, 03:50 AM   #8
Recognitions:
Ivan
Do you have more on this? your idea is fascinating, does it explain the variety
of shapes? any more scientific investigations?
Jun4-05, 04:01 AM   #9
Recognitions:
So why don't these hyperadvanced, crop hating aliens give us a gem of knowledge in return? Has anyone explained the concept of school chalkboard to these bug eyed, thin lipped morons? And why haven't they imprinted any fancy equations like e =mc^2? Forgive me for saying .... cowpie. It drops on the ground, is smelly and the best thing you can do is walk away from it.
Jun4-05, 04:46 AM   #10
Recognitions:
Quote by Chronos
Yes the literature is full of alien rubbish Chronos, but beyond the hoaxes and
nuttery there may be a small percentage of events that justify scientific
investigation, an unknown "earthly", explanation is possible, but robust
scientific evidence seems thin, i thought, "node explosions", worthy of
investigation, as it may tie in with anomalous atmospheric electromagnetic discharge, obviously this would not create intricate patterns, "they must be
hoaxes", but a simple circle or shape could be a natural phenomena.
Jun4-05, 09:32 AM   #11
Recognitions:
Quote by Chronos
So what do you know about the subject? And why do you insist that aliens are involved?
Jun4-05, 10:08 AM   #12
Recognitions:
Quote by wolram
Ivan
I don't think that we need to explain a variety of shapes; at least not complex shapes. As far back as the 1940s, meteorologists knew about this circle [donut shaped] phenomenon occuring in fields, and they hypothesized that since these impressions were often found near the bases of a hills, vortices that form along the ridge of the hilltops may rotate down as they cross the valley.
With the reports of bright, multicolored lights, and other EM effects allegedly associated with some crop circles, I began to wonder if something like ball lightning might be involved. Then then idea of a static potential forming over a field, something that might provide the potential for some static charge event, ultimately resulted from work that I had done with High Voltage. But I have never seriously explored the idea.
Jun4-05, 10:23 AM   #13
Recognitions:
There was a rather convincing woman interviewed on one of AC Clarke's shows. She claimed that as a child she had seen a circle form in the field right in front of her. She reported hearing a buzzing, electric noise, and this was followed by the sudden formation of a circular impression, about ten meters across IIRC, in the field of grass. She said that it formed all at once as if someone had set down a large, invisible plate.
Jun4-05, 02:00 PM   #14
There is a guy in Holland who says he sometimes gets attracted towards a field of crops, walks into it, sees a ball of light and goes unconscious. He then wakes up inside a cropcircle. So far there have appeared around 60 circles in the area place.
Nancy Talbot from BLT research went to investigate and witnessed the forming of a cropcircle by 'tubes of light':
http://www.bltresearch.com/eyewitness1.html
The guy actually also videotaped some of these balls of light from his balcony:
http://www.ufoplaza.nl/~ganzegal/vid/BoLHoeven.RM
The balls dont just appear near crops, they go whereever the guy goes. His family thought he was crazy at first, untill his sister one night also saw many balls of light appear which scorched a window. His parents have since then also witnessed the events. The guy also sees a whole range of other paranormal phenomena and as a kid saw 'shadows' flowing down his bedroom walls. He has also taken pictures of a 'grey' materialising in his house. A TV crew that went to investigate also took pictures of this thing. All these pics look fake and 2D though, but who knows.
Jun5-05, 10:03 AM   #15
Recognitions:
Thanks guys
I have been looking for, "events", in my area, the nearest i could find was in
oxfordshire about 40 miles from me, do you know if "locality", is a factor, ie
loads of circles in one area but none in an adjacent one?
What about soil types? my area is mostly lias clay and AFAIK no reported
circles.
The only unusual event i can find for this area is, a post wind mill was nocked
down and several trees uprooted by a "tornado", many years ago.
Jun6-05, 12:38 AM   #17
There can obviously be more explanations than aliens or humans.
For instance, rainbows arent made by aliens, should we then conclude that they are made by humans?
Here are some balls of light that were captured by a BBC camera crew:
http://www.ufoplaza.nl/~ganzegal/vid/bbcufo.rm
Thread Closed
Thread Tools
