Need help Inverse of an operator
  • Thread starter Thread starter einai
    Inverse Operator
The discussion revolves around the spectral decomposition of a Hermitian operator and its inverse in the context of quantum mechanics. The original poster seeks to understand how to express the inverse of an operator given its spectral decomposition and the conditions under which the inverse exists.
  • Conceptual clarification, Assumption checking, Mathematical reasoning
  • Participants explore the relationship between the spectral decomposition of an operator and its inverse, questioning how to correctly multiply the sums representing these operators. They also discuss the implications of having zero eigenvalues on the existence of the inverse.
The discussion is active, with participants providing insights into the conditions necessary for the existence of an inverse operator. There is a recognition of the need to prove that zero eigenvalues prevent the existence of an inverse, and some participants are clarifying their understanding of the implications of eigenstates and eigenvalues.
Participants are operating under the assumption that the eigenstates of the operator are orthonormal, and there is an ongoing examination of the implications of eigenvalues being zero on the operator's invertibility.
einai
Another quantum question...I feel dumb :frown:.
A Hermitian operator A has the spectral decomposition
A = &Sigma; an|n><n| (summation in n)
where A|n> = an|n> (the an's are eigenvalues of A, and |n>'s the eigenstates).
So, how can I find the spectral decomposition of the inverse of A so that
AA-1 = A-1A = 1?
My intuition would be A = &Sigma; (1/an)|n><n| (summation in n), since 1 = &Sigma; |k><k| (summation in k), but I don't think it's that easy.
Thanks in advance!
Try multiplying the given sum for A and your sum for A-1 and see if you get 1 as the answer.
Thanks. I have a question about multiplying the 2 sums though. Should I make n --> n' for one of them, then sum over n and n'? Like this:
A-1 = &Sigma; (1/an')|n'><n'| (summation in n')
then AA-1 = &Sigma;&Sigma; an(1/an') |n><n|n'><n'| (summation in n and n') ?
And what is the condition imposed on A so that the inverse exists? I have no idea...
Right, that's how you do the summation. (it will simplify to 1)
As for the condition imposed on A, your formula for A-1 contains a strong hint as to what that condition might me...
Thank you!
*scratches head*
Hmm...is it that A and A-1 must have the same eigenstates, so that <n|n'> gives a delta function? And eigenvalues of A must be none zero otherwise the term in the inverse diverges?
It is true that A and A-1 have the same eigenstates. For example, if |1> is an eigenstate of A with nonzero eigenvalue &lambda;, then:
|1> = A-1A|1> = A-1&lambda;|1>
and thus A-1|1> = &lambda;-1|1>
So any eigenstate of A is an eigenstate of A-1 (and vice-versa, by symmetry).
More importantly, we can always choose an orthonormal eigenbasis, in which <n|n'> would indeed be a delta function. (I would presume the basis used by spectral decomposition would be orthonormal, but don't quote me on that!)
And yes, the right condition here is that all of the eigenvalues of A be nonzero. However, there is still work to do! At the moment, your formula only proves that if all of the eigenvalues of A are nonzero then there exists an inverse! You still need to prove that if A has a zero eigenvalue then it cannot have an inverse.
That's a very good explanation, thank you.
Yes, they're orthonormal basis since it's the summation over the eigenstates.
Yikes, I'm not too sure if I understand this part... I mean, if A has a zero eigenvalue, then its inverse would have an eigenstate with eigenvalue 1/0 which diverges...couldn't that prove A cannot have an inverse?
I'm not sure if you're off the right track, or if you're on the right track but are missing a detail or two... so I'll give an example of a wrong proof and a right proof. :smile:
Wrong proof:
A-1 is given by that formula, and if we plug in a zero for one of the eigenvalues, the sum diverges, so A-1 doesn't exist.
This is wrong because you haven't proved that A-1 must have the form given by your formula; you can only prove that the formula works when the eigenvalues are nonzero.
It might be the case that there's another formula that will give you the inverse when one of the eigenvalues is zero. (It turns out that this is not the case, but from just the information I mentioned above, we can't determine this fact!)
Right proof:
Suppose |1> is an eigenstate of A with eigenvalue 0. Then:
|1> = A-1A|1> = A-10|1> = A-1 0 = 0
But since |1> is not the zero vector, we have a contradiction in assuming A-1 exists.
This is kinda like what you were saying, because we have:
|1> = 0 A-1 |1>
Implying A-1 has an "infinite" eigenvalue which is impossible... I just wasn't sure if you were aiming at this ponit or not.
Right proof:
|1> = 0 A-1 |1>
Oh, I see! Now I understand... I've always been bad at proving things :smile:. Thank you again for your help!
  • · Replies 26 ·
