Finite Square Well: Constructing Initial Wave Function with E < 0
The discussion focuses on constructing an initial wave function for a finite square well with energy less than the lowest bound state. It establishes that a mixture of bound states, represented by discrete energy levels, and scattering states, which have a continuous energy spectrum, is necessary to achieve this. The time-independent Schrödinger equation is central to this analysis, with solutions for bound states given by $\psi_n(x) = A_n\sin(k_nx)$ and scattering states by $\psi_k(x) = B_ke^{ikx} + C_ke^{-ikx}$. The combination of these states allows for the creation of an initial wave function with any energy, including those below the lowest bound state.
  • Understanding of the time-independent Schrödinger equation
  • Knowledge of bound and scattering states in quantum mechanics
  • Familiarity with wave function normalization techniques
  • Basic concepts of quantum mechanics, particularly energy levels
  • Study the time-independent Schrödinger equation in detail
  • Explore the properties of bound and scattering states in finite potential wells
  • Learn about wave function normalization and its importance in quantum mechanics
  • Investigate the implications of energy levels in quantum systems
Quantum mechanics students, physicists, and researchers interested in wave function construction and energy state analysis in finite square wells.
genxhis
I read through the derivation of bound and scattering states for a finite square well. The logic made sense to me, but I am not entirely sure how to accommodate an arbitrary initial wave function (with mean E < 0). Afterall, there are only a finite number of bound states. My guess was that the initial state might be constructed as a (unique?) mixture of both bound and scattering states. But how could this build a state with energy less than that of the lowest bound state?
Could someone clarify? thx.
Maybe such particles cannot exist (?)
edit: okay, i think i have it figured out in terms of uncertainty principles.
Your guess is correct, in order to construct an initial wave function with an energy less than the lowest bound state, we need to consider a mixture of both bound and scattering states. This is because the bound states represent the discrete energy levels available in the finite square well, while the scattering states represent the continuous energy spectrum. By combining these two types of states, we can create an initial wave function with any energy, including those below the lowest bound state.
To understand this concept better, let's consider the time-independent Schrödinger equation for a particle in a finite square well:
$\frac{d^2\psi}{dx^2} = \frac{2m}{\hbar^2}(V_0 - E)\psi$
where $V_0$ is the depth of the well and $E$ is the energy of the particle. This equation has two types of solutions: bound states and scattering states. Bound states have discrete energy levels given by:
$E_n = \frac{\hbar^2k_n^2}{2m}$
where $k_n = \frac{n\pi}{L}$ and $n$ is a positive integer. These bound states are represented by the wave functions:
where $A_n$ is a normalization constant.
On the other hand, scattering states have a continuous energy spectrum and are represented by the wave functions:
where $k$ is the wave number and $B_k$ and $C_k$ are normalization constants.
Now, to construct an initial wave function with energy less than the lowest bound state, we can take a linear combination of both bound and scattering states:
$\psi(x) = \sum_{n=1}^{\infty}a_n\psi_n(x) + \int_{0}^{\infty}b_k\psi_k(x)dk$
where $a_n$ and $b_k$ are coefficients that determine the weight of each state in the linear combination. By choosing the appropriate values for these coefficients, we can create an initial wave function with any energy, including those below the lowest bound state.
In summary, the key idea is to combine both bound and scattering states to create an initial wave function with the desired energy. This approach is valid because any wave function can be represented as a
