How Are the Roots of t^2-t-2 Related to the Solutions of y''-y'-2y=0?
  • Context: Undergrad
  • Thread starter Thread starter gigi9
    Polynomial
The discussion focuses on the relationship between the roots of the polynomial t² - t - 2 and the solutions of the differential equation y'' - y' - 2y = 0. The polynomial is factored as (t + 2)(t - 1), revealing roots at t = -2 and t = 1. The solutions to the differential equation are y = e^(-x) and y = e^(2x). The roots of the polynomial correspond to the exponential solutions of the differential equation, demonstrating a direct connection between polynomial roots and differential equation solutions.
  • Understanding of polynomial factoring techniques
  • Knowledge of differential equations, specifically second-order linear equations
  • Familiarity with exponential functions and their properties
  • Basic algebraic manipulation skills
  • Study the method of solving second-order linear differential equations
  • Learn about the characteristic equation and its role in finding solutions
  • Explore the implications of polynomial roots in relation to differential equations
  • Practice factoring polynomials using various methods, including grouping and the quadratic formula
Students studying algebra and differential equations, educators teaching these concepts, and anyone interested in the mathematical connections between polynomials and differential equations.
gigi9
Someone please help me to do this problem below. Thanks
1)a) Verify that y= e^(-x) and y= e^(2x)are both solutions of the differential equation y"-y'-2y=0
b) Factor the polynomial t^2-t-2. What connection do you see between the roots of this polynomial and the solutions of y"-y'-2y=0 ?---What does "roots" means in this case??..I don't understand.
*** t^2-t-2=(t-2)(t+1)
Once again, this really should be in homework (its a territorial matter!) and you really should show what you have tried.
However I will give you a hint: To show that y= e-x and y= e2x are solutions to the differential equation y"-y'-2y=0 means to find y' and y" for each function, put them into the given equation and see what happens!
") Factor the polynomial t^2-t-2. What connection do you see between the roots of this polynomial and the solutions of y"-y'-2y=0 ?---What does "roots" means in this case??..I don't understand."
I started to write "exactly what it means in algebra" but you do have a point (perhaps inadverdant): Strictly speaking to talk about "roots" you must have equation, not just a polynomial. This problem should have said either "the roots of the equation t2- t- 2= 0" or "the zeroes of the polynomial t2-t-2".
Okay, you have factored t2- t- 2= (t+ 1)(t- 2). Now WHAT are the roots of t2- t- 2= (t+ 1)(t- 2)= 0 and what possible connection could that have with e-x and e2x?
To factor the polynomial t^2-t-2, we can use the standard method of grouping or the quadratic formula. Let's use the grouping method:
Step 1: Write the polynomial in the form t^2+at+b. In this case, a=-1 and b=-2, so we have t^2-t-2.
Step 2: Find two numbers that when multiplied give you the constant term (b) and when added give you the coefficient of the middle term (a). In this case, the numbers are -1 and 2, since (-1)(2)=-2 and -1+2=1.
Step 3: Rewrite the polynomial using these two numbers as coefficients for the middle term. t^2-t-2 can be rewritten as t^2+2t-t-2.
Step 4: Group the first two terms and the last two terms together. We get t(t+2)-1(t+2).
Step 5: Factor out the common term (t+2). We get (t+2)(t-1).
Therefore, the polynomial t^2-t-2 can be factored as (t+2)(t-1).
Now, let's look at the connection between the roots of this polynomial and the solutions of y"-y'-2y=0.
In the polynomial t^2-t-2, the roots are the values of t that make the polynomial equal to zero. In this case, the roots are t=-2 and t=1.
In the differential equation y"-y'-2y=0, the solutions are the values of y that make the equation true. In this case, the solutions are y=e^(-x) and y=e^(2x).
Notice that when we substitute t=-2 in the polynomial, we get (t+2)(t-1)=(-2+2)(-2-1)=0, which means that t=-2 is a root of the polynomial. Similarly, when we substitute t=1 in the polynomial, we get (t+2)(t-1)=(1+2)(1-1)=0, which means that t=1 is also a root of the polynomial.
This shows that the roots of the polynomial t^2-t-2 are directly related to the solutions of the differential equation y"-y'-2y=0. This is because both the polynomial and the differential equation have the
