Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Mathematics > Calculus & Analysis
Reply
image The Partial Derivative Share It Thread Tools Search this Thread image
Old Jun4-05, 12:10 AM                  #1
Cyrus
Cyrus's Avatar
Cyrus is Offline:
A couple of quickies on the interpertation of the partial derivative I want to clear up with myself.
If we have a parametric function:
r(u,v)= x(u,v)i + y(u,v)j+z(u,v)k
then the partial derivative W.R.T u or v is regarded as the tangent vector, and we can think of it as the speed, or velocity vector at the point (u,v) along the curve.
Now for a function defined by,
xi + yj + z=f(x,y)k
When we take the partial derivative with respect to x or y, can we still regard it as the speed or velocty vector at the point (x,y)?
I dont see any reason not to call it that, they are both legitamite vectors tangent at the point (x,y) or (u,v).
Old Jun4-05, 12:44 AM                  #2
OlderDan
OlderDan is Offline:
Recognitions:
Homework Helper Homework Helper
xi + yj + z=f(x,y)k
What does this mean?
LaTeX Code: x\\widehat i + y\\widehat j + z = f(x,y)\\widehat k
I have no trouble conceiving of r(u,v) as a position vector represented in an orthogonal basis LaTeX Code: (\\widehat i, \\widehat j, \\widehat k) and the partial derivatives being "velocity" relative to a single changing parameter (a.k.a. u = "time" with constant v), but if you take the partial wrt x at constant y,z of your equation you get
LaTeX Code:  \\widehat i = \\frac{\\partial f(x,y)}{\\partial x}\\widehat k
which is a fundamental violation of everything we know about orthogonal vectors. Did you mean
LaTeX Code: z(x, y) = -x\\widehat i - y\\widehat j + f(x,y)\\widehat k
with z being some vector function of x,y?
Old Jun4-05, 12:51 AM                  #3
Cyrus
Cyrus's Avatar
Cyrus is Offline:
Sorry for being unclear, I meant that the the z component was a function of x and y, basically, f(x,y)k . I dont see why you put a negative sign infront of x and y though.
Old Jun4-05, 08:01 PM                  #4
Cyrus
Cyrus's Avatar
Cyrus is Offline:
Any help would be appreciated.
Old Jun4-05, 09:52 PM                  #5
Night Owl
Night Owl is Offline:
maybe you could restate the second equation that you'd like help with? I agree with OlderDan with regards to everything else.
If you clarify the last part of your post, perhaps we could help more.
Old Jun5-05, 01:37 AM                  #6
Cyrus
Cyrus's Avatar
Cyrus is Offline:
Ok, lets try this again from the top;
Now for a surface defined by,
x i + yj + f(x,y)k
The tangent vector would be,
1i + 0j + f_x(x,y) k <---(Can this not be considered the speed as well?)
Old Jun5-05, 01:53 AM                  #7
whozum
whozum is Offline:
Your surface: x i + y j + f(x,y) k exists in R^3, the way you have written it is equivalent to writing it as
f(x,y)k = -x i - y j, or omitting the k unit vector (as it is assumed)
f(x,y) = - x i - y j. Note x and y are both independant variables. The partials are
f_x(x,y) = -1. f_y(x,y) = -1
That is my understanding of your question. For z(x,y) to be an independant variable, you would need a function f(x,y,z) in order to represent it's partials.
Old Jun5-05, 10:39 AM       Last edited by arildno; Jun5-05 at 10:42 AM..            #8
arildno
arildno is Offline:
Recognitions:
PF Contributor PF Contributor
x i + yj + f(x,y)k
Correct.
Let us parametrize a surface S in the following manner:
LaTeX Code: \\vec{S}(x,y)=x\\vec{i}+y\\vec{j}+f(x,y)\\vec{k}
then the tangent vectors are given by:
LaTeX Code: \\frac{\\partial\\vec{S}}{\\partial{x}}=\\vec{i}+\\frac{  \\partial{f}}{\\partial{x}}\\vec{k}
LaTeX Code: \\frac{\\partial\\vec{S}}{\\partial{y}}=\\vec{j}+\\frac{  \\partial{f}}{\\partial{y}}\\vec{k}
Old Jun5-05, 12:09 PM       Last edited by Cyrus; Jun5-05 at 12:12 PM..            #9
Cyrus
Cyrus's Avatar
Cyrus is Offline:
Im sorry, but I have to disagree. A vector is not equal to its k component that you can move around and set equal to like that whozum. Its not an equation, its a vector, with meerely functions as components.
To arildno, can we regard it as the "speed" like we do for parametric surfaces? I.e. is the "speed" W.R.T x always 1 in the i direction, and f_x(x,y) in the z dierction? Likewisee the speed W.R.T y, always 1 in the y dirction, 0 in the x direction, and f_y(x,y) in the z direction?
Or is there something fundamentally wrong to call it the "speed"
Old Jun5-05, 12:12 PM                  #10
arildno
arildno is Offline:
Recognitions:
Why call it speed??
Why muddle the issue in that manner; the concept of tangent vectors is good enough, isn't it?
Old Jun5-05, 12:25 PM                  #11
Cyrus
Cyrus's Avatar
Cyrus is Offline:
Because I want to know if calling something "speed" is reserved for a special condition on the derivative, or can we call this situation speed as well. I want to have a rigerious definition of when and were speed can be used to describe a derivative.
Old Jun5-05, 05:59 PM                  #12
Cyrus
Cyrus's Avatar
Cyrus is Offline:
Im sorry if I seem anal about it, but I want to be very precise in when and where I can call it the speed. The book calles the partial of a parametric function the speed, but it does not call a function in terms of x,y the speed, which is why I ask about the rigidity (is that a word?) of the use of the term speed.
Old Jun6-05, 01:14 AM                  #13
OlderDan
Recognitions:
I have read the conversation that follow this post of yours, but I want to go back here to respond to this, and make some additional observations. If you have not discovered the answer yourself, the negative signs are there because I moved those terms to the other side of the equation to solve it for what you had called z. The equation only made sense if z is a vector function of x and y.
By changing your statement to say
x i + yj + f(x,y)k
you have changed from an equation to an expression. That expression can be interpreted as defining a surface in three dimensional space. arildno reasonably turned your expression into an equation with S as a vector equivalent to your expression. I assume S was chosen because your expression represents a set of termination points of vectors from the origin to the surface defined by the function f(x,y). By making this equality as a reasonable way to represent your expression, a sensible way of representing the partial derivatives with respect to x and y is achieved.
But notice what has been done here. Your "new" problem has been mapped into your "old" problem with S in place of r, x in place of u, y in place of v, and f(x,y) in place of z(u,v).
LaTeX Code: \\vec{r}(u,v)=x(u,v)\\widehat{i}+y(u,v)\\widehat{j}+z  (u,v)\\widehat{k}
LaTeX Code: \\vec{S}(x,y)=x(x,y)\\widehat{i}+y(x,y)\\widehat{j}+f  (x,y)\\widehat{k}
This is nothing more than a special case of your more general starting equation, with the x and y coordinates being functions of only one of the two parameters. What holds in the general case will hold in any specific case. If you want to think of the parameter x as "time" then the special case becomes
LaTeX Code: \\vec{S}(t,y)=t\\widehat{i}+y\\widehat{j}+f(t,y)\\wide  hat{k}
and
LaTeX Code: \\frac{\\partial\\vec{S}}{\\partial{t}}=\\widehat{i}+\\f  rac{  \\partial{f}}{\\partial{t}}\\widehat{k}
and sure enough, this is a "velocity" relative to the time parameter with the y parameter held constant. You could do the same thing wrt y instead of x. In this special case, what you have shown is that "velocity" wrt to one of the two parameters is always perpendicular to either the x axis or the y axis
As arildno has noted, there is really nothing to be gained by thinking in terms of velocity, but it does fit with your general construct. When the parameters are the spatial variables x and y, a change dx with y held constant is equivalent to moving a distance dx along the surface in the x direction, and a distance LaTeX Code: \\frac{ \\partial{f(x,y)}}{\\partial{x}}dx in the z direction. The partial derivative is the rate of change of the vector S with respect to a change in the spatial variable x. If you want to think of x as "time" than it is also a velocity.
Old Jun6-05, 10:22 AM                  #14
Cyrus
Cyrus's Avatar
Cyrus is Offline:
Thanks! I was considering that but I wanted to wait for one of your guys anwsers. That helps me alot.
Old Jun6-05, 01:26 PM                  #15
Cyrus
Cyrus's Avatar
Cyrus is Offline:
Ok, another question on interpretations of partial derivatives. It shows in the text that one way of thinking about the partial derivative W.R.T x or y is the slope of the tangent vector.
But as you two have pointed out, this vector is:
LaTeX Code:  \\frac{\\partial \\vec{S}}{\\partial{x}}=\\widehat{i}+\\frac{  \\partial{f}}{\\partial{x}}\\widehat{k}
So If we look at this vector, it has only components in the i and k direction. So in this SPECIAL case, we can see that the slope is the rise in z over the run in x, or f_X(x,y)/ 1, so we see that the partial of z is the slope of the tangent line.
But this is true only because the y component is zero. If the y component were not zero, it would be meaningless to mention the word slope. Is this reasoning correct?
Old Jun6-05, 05:18 PM                  #16
OlderDan
Recognitions:
The situation you are now looking at is that of a vector pointing to a location on the surface. That vector will always have the form
LaTeX Code: \\vec{S}(x,y)=x\\widehat{i}+y\\widehat{j}+f(x,y)\\wide  hat{k}
One of the most important things about partial derivatives is keeping track of what is being held constant. In your case, taking a partial with respect to x means that y is being held constant, and taking the partial with respect to y means that x is being held constant. If you combine the two you can write the differential
LaTeX Code: d\\vec{S}(x,y) = \\frac{\\partial{\\vec{S}(x,y)}}{\\partial{x}}dx + \\frac{\\partial{\\vec{S}(x,y)}}{\\partial{y}}dy = \\left[\\widehat{i} + \\frac{  \\partial{f}}{\\partial{x}}\\widehat{k}\\right]dx + \\left[\\widehat{j} + \\frac{  \\partial{f}}{\\partial{y}}\\widehat{k}\\right]dy  = dx\\widehat{i} + dy\\widehat{j}+\\left[\\frac{\\partial{f}}{\\partial{x}}dx + \\frac{\\partial{f}}{\\partial{y}}dy\\right]\\widehat{k}
What does this mean? Imagine yourself at the point on the surface (x, y, z=f(x,y)). Now you want to move to another point on the surface. The path you take is quite arbitrary, as long as you wind up where you want to go. You can walk along the surface, or you can walk in the x direction some distance, then walk in the y direction some distance, then look "up" and "down" (z direction) to see if you need to climb up to or down to get back to the surface. The differential vector LaTeX Code: d\\vec{S} tells you the components of the vector pointing from LaTeX Code: \\vec{S} to LaTeX Code: \\vec{S} + d\\vec{S} , both of which terminate on the surface. The distance you have to move in the z direction is the sum of the changes in the z coordinate of the surface resulting from the displacements dx and dy. If your path to the new location only requires you to move in the x direction, then in the z direction it is because dy has been chosen to be zero. If your path to the new location only requires you to move in the y direction, then in the z direction it is because dx has been chosen to be zero. It is simply a matter of the (x,y) coordinates of your destination relative to your starting point.
And notice what happens if you divide the differential displacement by the time dt it takes you to move. You get the velocity of the motion
LaTeX Code: \\frac{d\\vec{S}(x,y)}{dt} = \\vec{v} = \\frac{dx}{dt}\\widehat{i} + \\frac{dy}{dt}\\widehat{j}+\\left[\\frac{\\partial{f}}{\\partial{x}}\\frac{dx}{dt} + \\frac{\\partial{f}}{\\partial{y}}\\frac{dy}{dt}\\right]\\widehat{k}
image image
Reply
Thread Tools
Similar Threads for: The Partial Derivative
Thread Thread Starter Forum Replies Last Post
converting partial derivative w.r.t. T to partial derivative w.r.t. 1/T knulp Calculus & Beyond 2 Apr1-08 10:55 PM
replacing total derivative with partial derivative in Griffiths' book Newbie says Hi Advanced Physics 3 Feb15-07 12:00 PM
Partial Derivative Stevecgz Calculus & Beyond 0 Mar11-06 05:14 PM
partial derivative adamg General Math 14 May15-05 10:17 AM
Total derivative -> partial derivative Walkingman Differential Equations 6 May2-05 05:11 PM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
