The discussion revolves around the computation of the expected value E[Y] for a random variable Y defined as Y = X^2 + 1, where X follows a Uniform(0,1) distribution. Participants explore different methods for calculating this expected value, including integration techniques and the use of probability density functions.
- Exploratory
- Technical explanation
- Debate/contested
- Mathematical reasoning
- Some participants propose integrating x(x^2 + 1) from 0 to 1 to compute E[Y], while others argue that the correct integrand should be (x^2 + 1).
- There are two suggested methods for calculating E[Y]: integrating over x from 0 to 1 or integrating over y from 1 to 2, with questions raised about the appropriate probability density function in each case.
- Participants discuss the change of variables from x to y, noting that y = x^2 + 1 leads to the limits of integration changing from 0 to 1 for x to 1 to 2 for y.
- One participant outlines the steps to compute E[Y], E[Y^2], E[XY], and Cov[X,Y], providing specific expressions for each expected value and variance.
- Another participant expresses uncertainty about the correctness of the arithmetic in the computations presented.
Participants do not reach a consensus on the correct integrand for computing E[Y], as there are competing views on the integration approach. The discussion remains unresolved regarding the best method to compute the expected value and related quantities.
Participants express confusion about the definitions and roles of probability density functions in the context of expected value calculations, indicating potential limitations in understanding the integration methods discussed.
