| Thread Closed |
schottky contacts - band bending |
Share Thread | Thread Tools |
| Jun7-05, 01:47 PM | #1 |
Hello!
I am looking a bit at the Schottky contacts, metal-semiconductor, and I am starting to get a hang of it, but some things are missing. Specifically: Why must the distance from the Fermi Energy to the vacuum level in the metal and the distance from conduction band edge to vacuum level in the semiconductor stay constant at the contact point? I only have a very condensed description, and the argument is "because these distances are crystal properties". But it would make more sense to me if the distances had to stay constant further into the crystals, where the dynamic between the two materials should be of less importance. That's it. Appreciate all answers! /Jonas |
| Jun7-05, 02:25 PM | #2 |
Mentor
What I think you may be asking is the reason for bend bending. Specifically, why the Fermi energy level in the metal and the chemical potential in the semiconductor must "line up". This has nothing to do (at least not directly) with the crystal structure, but rather with thermodynamics. At thermodynamical equilibrium, the contacts must be at the same "temperature", and thus the Fermi energy of the metal (which is the highest energy of the occupied state) will coincide with the statistical characteristic energy of the semiconductor. When this occur, the rest of the bands will follow. Zz. |
| Jun7-05, 04:16 PM | #3 |
Hi, thanks for replying! And really fast also!
And, talking about the Fermi energy, isn't that the energy where the likelihood of a state (if it is allowed) to be occupied is 1/2. How can one say that this is the highest occupied state? I mean, the higher states are also possible, but the likelihood of them being occupied sinks quite fast with higher energy. How did you mean? |
| Jun7-05, 04:31 PM | #4 |
Mentor
schottky contacts - band bendingThe Fermi energy is DEFINED as the topmost occupied state of a fermionic system. What you just described is the occupation density, i.e. n(k), or n(E). Why is this even here? Zz. |
| Jun7-05, 04:46 PM | #5 |
That's the chemical potential [itex] \mu[/itex], which is equal to the Fermi Energy at 0 K and pretty darn close at normal temperatures.
[tex]\mu = \epsilon _F \left(1- \frac{\pi^2}{12} \left( \frac{k_BT}{\epsilon_F} \right) ^2 + ... \right) [/tex] |
| Jun7-05, 05:06 PM | #6 |
http://en.wikipedia.org/wiki/Image:FD_e_mu.jpg you see that the Fermi energy is where the distribution function is 1/2. |
| Jun7-05, 05:22 PM | #7 |
The Fermi Energy is the uppermost "occupied" state. But how do you tell if a state is occupied when it has an accupation probability < 1 ? The problem resolves itself at most working temperatures...by the fact that the energy difference to go from a high probability of occupation to a low probability is small compared to the Fermi Energy.
As to the rest of the question; I'm not sure I understand it at first glance. Does it not suffice to say that the chemical potentials of the two bodies in thermodynamic equilibrium must be equal ? If there were a difference in chemical potentials, there would be a flow of particles (electrons/holes) across the interface till the difference disappeared. |
| Jun7-05, 05:34 PM | #8 |
| Jun7-05, 07:38 PM | #9 |
Mentor
In metals, using the degenerate free electron gas, the Fermi energy is defined as the top of the occupied state at T=0K. This is NOT the same way it is defined for an intrinsic semiconductor, where the middle of the gap is the chemical potential at T=0K. Zz. |
| Jun8-05, 09:24 AM | #10 |
| Jun8-05, 02:04 PM | #11 |
But I don't have any problem saying that f(E) is 0.3. It doesn't give us any information about occupancy of course, I totally agree. But we can say that with probability 0.3 the state is occupied (if the state is at all allowed). How many states with the energy E that are possible -not occupied - per unit volume is described by N(E). In N(E) the pauli principle has to be taken into account, I guess. How many that can be in one energy state depends on the Hamilton operator, is my second guess. If the eigenenergies are degenerate more states are associated to each energy, and we get higher density of states. But how does distance come into the picture here? Let's imagine that we have a set of electrons in for example a semiconductor, and all of them are in unique quantum states. Suppose that there are states that are unoccupied, and that one electron jumps into one those free states. How is then the information carried over to the other electrons that this state is now occupied? And is really any information carried over, that would also mean transfer of energy, wouldn't it? And it can't happen instantly, and it can't be so that two electrons at "great" distance from each other couldn't have the exact same set of quantum numbers. |
| Jun8-05, 02:46 PM | #12 |
Mentor
This is diverging away from the main topic of this thread, but once quantum statistics kicks in, one needs to be aware that one is now dealing with the whole glob of things. The "individuality" of each particle is gone because they are no longer distinguishable. The exclusion principle is the result of such indistinguishibility. Zz. |
| Jun8-05, 03:04 PM | #13 |
Wow, this is truly incredible. I'm prepared to join Einstein and other sceptics, this is getting ridiculous =) I really can't accept that just because we're talking quantum mechanics all of a sudden information can travel infinitely fast. But I sense that my problem here is being stuck in the classical view. Talking about one specific electron changing state isn't anymore relevant. Nevertheless, I feel that the electron would have to "tell" the others to keep out of this state! But there's also another catch isn't it? You couldn't send any information by using this phenomena, could you? |
| Jun8-05, 04:37 PM | #14 |
Mentor
Where did I say there was information moving infinitely fast? There's nothing "moving" at all between the two entangled entities. That's the WHOLE point. If there is, we should be able to detect it on its way from one particle to another! We detect NO such thing! Furthermore, within QM's formulation, there's NOTHING that is being transfered! Special Relativity (and Einstein) is NOT being violated here! Now would you want the thread to deteriorate into such a thing? Zz. |
| Jun8-05, 05:14 PM | #15 |
| Jun9-05, 01:26 AM | #16 |
Let's get back to the original question, what ?
jonas, do you agree that the Fermi energies of the metal and SC want to match each other ? Unless you match chemical potentials, you can not have thermal equilibrium. The way this matching happens is through a transfer of electrons across the interface. This transfer results in a net charge gradient in the SC adjacent to the metal, which gives rise to an electric field in the SC. It is this electric field which causes the bands to bend. Recall what happens to a band when you apply a bias voltage. This is virtually the same effect here. |
| Jun9-05, 01:45 AM | #17 |
Now I have to get to the University again (don't know where you are, but here it's morning right now), but I'm gonna try to find a picture to show you tonight. Cheers! Jonas |
| Thread Closed |
| Thread Tools | |
Similar Threads for: schottky contacts - band bending
| Energy given off Photons/Heat from Conduction Band (Conduct Electron) to Valance band | Atomic, Solid State, Comp. Physics | 3 | ||
| Valance band to Conduction Band (Valance Electron), Energy Band Gap Levels | Advanced Physics Homework | 0 | ||
| Schottky anomaly | Atomic, Solid State, Comp. Physics | 0 | ||
| schottky effect | Electrical Engineering | 1 | ||
| E-K Diagrams, valence band, conduction band... | Introductory Physics Homework | 14 | ||
