How Do You Solve the Limit of (e^x * tan^-1 y) / y as (x, y) Approaches (0,0)?
  • Thread starter Thread starter schattenjaeger
    Hey Limit
The discussion revolves around evaluating the limit of the expression (e^x * tan^-1 y) / y as (x, y) approaches (0, 0). Participants are exploring the behavior of this limit in the context of multivariable calculus.
  • Participants are attempting to find paths to evaluate the limit, questioning the behavior of the denominator as it approaches zero. Some are considering approximations for tan^-1 for small angles and discussing the applicability of L'Hôpital's rule in a multivariable context.
The discussion is ongoing, with various participants offering insights into approximations and questioning the validity of certain methods. There is no explicit consensus on the approach to take, but several lines of reasoning are being explored.
Some participants note that the problem is situated before the chapter on partial derivatives, which may influence their understanding of the techniques applicable to the limit evaluation.
schattenjaeger
Assuming it exists(and upon checking the answer is 1, but I'll be damned if I can get it)
the limit as (x,y)->(0,0)
I can't find a path where the denominator isn't 0 or cancels out that goes through the point 0,0, so I can't, you know, solve it.
What is the Gauss aproximation for tan^-1 for small angles? e^0=1. Not the most exact way, but it should work.
Well, I'm in Calculus 3 and have no clue what that approxamation is nor do I think I'm expected to for this problem, thanks though
See next post.
Well, it's a function of two variables, and this problem is in the chapter before partial derivatives, so ignoring the fact that I'm not technically sposed to know how to apply l'hopital's rule to it, I don't even know if you can on a multivariable thing like that
Alright that puts the question in a little perspective. Still, you can simplify the limit to one variable by just applying x = 0 to it.
Edit: Applying tan^-1() to each side of the first approximation Berislav gave would work also I guess.
Gauss aproximation:
siny=y, for very small y --->sin^-1y=y
cosy=sqrt(1-y^2)
tany=y/(sqrt(1-y^2))
The y's will cancel when you combine the above eqaution with your own.
Then I have to take the derivative of tan^-1y, which definitely isn't 1(like it would have to be for l'hopital's rule to give me 1)
As for the Gauss approximation, I don't think I should use it here because it doesn't specify only small values of y, and I certainly haven't officially learned it yet
For small values of y, sin y = y, cos y = 1, and tan y = y. :-p
How's it not? [tex]\frac{d(tan^{-1}(y))}{dy} = \frac{1}{1+y^2}[/tex] at y = 0.. Divide this by the derivative of the denominator of your original limit.
Right. I only approximated sin y=y, though.
Oh right
ok, thanks!
  • · Replies 22 ·
