Solve Ka for Weak Acid HCN - 0.18mol KCN in 1.00L, pH 9.70, 298K
  • Thread starter Thread starter Aly
    Acids Weak
The discussion focuses on calculating the acid dissociation constant (Ka) for the weak acid hydrogen cyanide (HCN) using a solution of potassium cyanide (KCN) with a concentration of 0.18 mol in 1.00 L at a pH of 9.70 and a temperature of 298K. The equilibrium concentration of cyanide ions (CN-) is established at 0.13M. Participants suggest using the Henderson-Hasselbalch equation and the relationship between Kb and Ka to derive the necessary values for HCN.
  • Understanding of the Henderson-Hasselbalch equation
  • Knowledge of equilibrium concentrations in acid-base chemistry
  • Familiarity with the concepts of pH, pOH, and their calculations
  • Ability to manipulate equilibrium expressions for weak acids and bases
  • Learn how to apply the Henderson-Hasselbalch equation in various acid-base scenarios
  • Study the calculation of Kb from equilibrium concentrations
  • Explore the relationship between Ka and Kb for weak acids and bases
  • Investigate the impact of temperature on acid dissociation constants
Chemistry students, educators, and professionals involved in acid-base equilibrium calculations, particularly those working with weak acids and their conjugate bases.
Aly
hi forum,
would nebody be able to help me solve this problem?
0.18mol of potassium cyanide (KCN) was dissolved in 1.00L of a solution in which the pH was held constant at 9.70 at a temperature of 298K.
the equilibrium concentration of CN- was 0.13M.
Calculate Ka for the weak acid HCN.
ne help would be greatly appreciated. :)
Chemistry news on Phys.org
Use Henderson-Hassebalch equation. It won't be difficult to calculate equilibrium concentrations of HCN and CN- - just enter them into HH and solve for pKa.
hi forum,
Start with finding Kb
[tex]Kb= \frac{[OH-][HCN]}{[CN-]}[/tex]
You can find the initial concentration, you also know the equilibrium concentration, thus you can find how much of CN- reacted. It also says that the pH was held constant. From the pH given, find the pOH, from this calculate the concentration of hydroxide [OH-]. This is the equilibrium concentration thus you can plug it back into the equilibrium equation.
How would you find the HCN concentration to solve for Kb...and then Ka?
17K
