| Thread Closed |
Is volume displaced by an item in water = volume of item * specific gravity of item? |
Share Thread | Thread Tools |
| Jun8-05, 04:36 AM | #1 |
Or does that hold true for just one particular problem im working on :)?
(this formula is for objects that sink, not float.. if they float volume displaced = volume of item) |
| Jun8-05, 04:48 AM | #2 |
Your second statement is wrong- if an item floats then the water displaced has the same mass as the object, not the same volume. Since not all of the object is in the water, the water "doesn't know" its volume. If an object is completely submerged (does not float) the amount of water displaced is exactly equal to its volume. However, in order to sink to the bottom, it is only necessary that the object's specific weight be greater than one. Other than that, the object's specific weight does not come into the equation: the volume of water displaced is equal to the objects volume times 1.0, not its specific weight.
| Jun8-05, 04:33 PM | #3 |
ah whoops
so then if an object floats, the amount of water displaced is volume of item * specific gravity of item? and if it sinks, amount of water displaced = volume of item? |
| Jun8-05, 05:03 PM | #4 |
Nope,Archimedes' principle applies,no matter what is the configuration,solid + fluid.
The volume displaced in the fluid is simply the volume of the solid inside the fluid. BTW,"amount" is highly ambiguous.Use either MASS or VOLUME. Daniel. |
| Jun8-05, 05:31 PM | #5 |
specific gravity is = fraction submerged = p(object)/p(water)
so then wouldnt volume displaced be fraction submerged * volume of item? (ie specific gravity of item * volume of item) |
| Jun8-05, 05:35 PM | #6 |
Nope,you got them all mixed up.
I don't like the term "specific gravity",physicists don't use this term.It's "mass volumic density". The volume of fluid displaced is a fraction of the solid's volume. Daniel. |
| Jun8-05, 09:34 PM | #7 |
| Jun9-05, 10:50 AM | #8 |
Recognitions:
I think your earlier statement was misinterpreted. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Is volume displaced by an item in water = volume of item * specific gravity of item?
| What does mass, volume and density of displaced water mean? | Introductory Physics Homework | 4 | ||
| Volume of water displaced...? | Advanced Physics Homework | 5 | ||
| Item charges confusion. | Introductory Physics Homework | 2 | ||
| Greatest Non-Newsworthy Item Ever? | General Discussion | 17 | ||
| What is the mystery item? | Brain Teasers | 19 | ||
