Help with this partial derivative problem
The discussion revolves around finding the second-order partial derivatives of a function defined implicitly by the equation z^2 + sinx = tany. Participants are exploring the correct application of partial differentiation techniques in this context.
  • Participants discuss the process of finding the second-order partial derivatives, questioning the validity of their initial calculations and the distinction between multiplying first-order derivatives and taking second-order derivatives. There is an exploration of implicit differentiation and its application to the given equation.
The discussion is active, with participants identifying mistakes in their approaches and refining their understanding of the differentiation process. Some have made progress in correcting their methods, while others continue to seek clarity on the correct application of partial derivatives.
Participants are working under the constraints of implicit differentiation and are attempting to reconcile their results with those provided in a textbook, which has led to some confusion regarding the correct forms of the derivatives.
schattenjaeger
I'm supposed to find (assume all these d's are the partial derivative sign, not d)
d^2z/dxdy, d^2z/dx^2, and d^2z/dy^2
The one I can't do is z^2 + sinx = tany
I set it equal to zero, so z^2 + sinx - tany=0
so dz/dx = - Fx/Fz = sec^2y/2z
dz/dy = - Fy/Fz = -cosx/2z
multiply them for d^2z/dxdy I get -(sec^2y*cosx)/(4z^2) which is ALMOST right, but the book says the denominator is 4z^3, and the other two I do the same procedure(dz/dx * dz/dx for the second one for example) and get nothing close
Your problem seems to be the fact that
[tex]\frac{\partial^2z}{\partial x\partial y} \neq \frac{\partial z}{\partial x}\frac{\partial z}{\partial y}.[/tex]
On the left-hand side (what you want to find), you are taking the partial derivative with respect to x of the partial derivative of z with respect to y, that is
[tex]\frac{\partial}{\partial x}\left(\frac{\partial z}{\partial y}\right).[/tex]
This gives you a second-order derivative, whereas on the right-hand side (what you did) you are merely multiplying two first-order derivatives together... The same will be true for the other derivatives you have to find, since
[tex]\frac{\partial^2z}{\partial x^2} \neq \left(\frac{\partial z}{\partial x}\right)^2.[/tex]
Ah, ok, one mistake outta the way
in that case, and I know I'm doing it wrong, if I take the partial derivative of z with respect to y, I end up with 2z*dz/dy + sec^2y, and if I take the partial derivative with respect to x at this point, I end up with 0, which clearly isn't right. I can usually do implicit differentiation but I'm doing something silly here
Edit, oh wait I'm stupid, I guess the -Fx/Fy stuff was still right then? Hang on
Edit #2 - Oh jeez, I had that bacwards up there too, so I'm still taking the partial with respect to x, but with no x in the equation which gives me 0:(
YES, got it, though I'm not sure it was the most efficient way
I set the equation equal to z to find dz/dy,
z=sqrt(tanx-sinx)
dz/dy=-((tany-sinx)^-1/2 / 2) * sec^2y
then derivative in terms of x, (-sec^2 y /2) * 1/2(tany-sinx)^-3/2 * cosx
plug in z for (tanx-sinx)^1/2 and that all simplifies to the right answer
