What is the Amplitude and Wavelength of a Real Wave in Nature?
  • Context: Undergrad
  • Thread starter Thread starter tino lin
    Amplitude Wave
The discussion revolves around the amplitude and wavelength of real waves in nature, particularly focusing on electromagnetic waves, mechanical waves, and their properties as described by the equation wavelength = v/f, where v is the speed of light. Participants explore the implications of these properties for understanding wave behavior and measurement.
  • One participant seeks exact measurements of amplitude and wavelength for waves in nature, suggesting examples like light waves, electron waves, or radio waves.
  • Another participant notes that for a medium with a linear restoring force, wavelength is independent of amplitude and cautions against comparing amplitude and wavelength directly due to their different units.
  • Some participants differentiate between electromagnetic waves and mechanical waves, emphasizing that only mechanical waves involve a material medium that vibrates.
  • Questions arise about the measurement of amplitude in electromagnetic waves and whether it can be treated similarly to mechanical waves.
  • One participant suggests that radio frequencies can be used to calculate wavelengths, while amplitude is related to the strength of electric and magnetic fields rather than a physical length.
  • There is a discussion about the mathematical representation of wave motion and the vertical velocity of points on a wave, with a focus on the relationship between amplitude, frequency, and wavelength.
  • Concerns are raised about the interpretation of amplitude as a length, with some participants arguing that it should be viewed as a measure of field strength instead.
  • One participant questions the similarity in equations describing electromagnetic and mechanical waves, suggesting philosophical implications rather than purely physical ones.
  • Another participant provides a mathematical derivation linking circular motion to wave properties, but this is met with skepticism regarding its applicability to demonstrating wave existence.
Participants express differing views on the nature of amplitude in electromagnetic waves, with some asserting it cannot be treated as a length, while others explore the implications of viewing it as such. The discussion remains unresolved regarding the exact nature of wave properties and their measurements.
Limitations include the potential misunderstanding of amplitude in the context of electromagnetic waves, as well as the dependence on definitions and interpretations of wave behavior across different types of waves.
tino lin
I am interest in finding the amplitude and wavelength of an actual wave in nature that apply to the equation:
wavelength = v/f where v = speed of light.
This kind of wave would be example of light wave, electron wave, or radio wave, I assume. What I need is the exact measurement of it's amplitude and wavelength observe in nature. Can any please help with finding this kind of information.
This information will help me find the vertical vibration velocity of a wave in nature. If amplitude = wavelength/4 then vertical vibration velocity is equal speed of light.
If amplitude > wavelength/4 then vertical vibration velocity is greater then speed of light which should not be possible. But I cannot prove until the I know the actual wave behavior in nature.
Science news on Phys.org
For a medium with a linear restoring force, wavelength is independent of the amplitude.
In any case, you can't compare amplitude to wavelength when talking about electromagnetic waves because these quantities have completely different units. It would be comparing apples to oranges.
Claude.
Don't confuse electromagnetic waves (like light and radio) or quantum mechanical "matter waves" (like electron waves) with mechanical waves (like sound or water waves). Only with mechanical waves is a material medium actually vibrating. And I assure you, the vibrating material comes nowhere near light speed.
Thanks to the two post have answer some of my questions.
But it only lead to more questions.
True, electromagnetic wave may not have the vibration nature of the machanical wave. But if we choose to view
it in this way what would that vibration speed be?
Is the amplitude of an electromagnetic wave ever meausure or calculated before? Are we able to detect both the amplitude and the wavelength of an electromagnetic wave before in the lab or through an equation, what would that number be?
Of course! Radio stations are assigned frequencies around which they broadcast their programs. These are approximately in the range from 500KHZ up to around 100MHz. If you divide the speed of these waves (3E8 m/s) by these frequencies you'll get the wave lengths. They range from a few meters (high frequencis) up to hundreds of meters (low frequencies).
As to amplitude, that can also be measured. But your posts make it seem like you think this amplitude is a length. That isn't true. The amplitude of an electromagnetic wave is the strength of the electric and magnetic fields that are the wave.
Correct I am trying to view the amplitude as length. Is it totally wrong or irrelevant to view it this way? Is the definition of wave totally different when it come to electormagnetic wave, then why is the equation to describe it the same as machanical wave.
Is seem the amplitude of an electromagnetic wave is not an easy answer, cause it view of as intensity.
Looks like I'll have to try and calculate the amplitude base on your idea of the
radio wave, but it's probably not precise.
If you consider, say, a wave in the sea and approximate it by a sine (or cosine) wave of given amplitude (height) moving at a constant velocity, it's a simple matter mathematically to work out the vertical velocity of a fixed point. Bear in mind that this vertical velocity isn't going to be constant.
To quantify mathematically, assume the displacement of a wave at an arbiatary fixed point and variable time is given by the expression
[tex]d(t)=A\sin{\omega t}[/tex]
where A is the amplitude, and [itex]\omega[/itex] is the angular frequency given by [itex]\omega=2\pi f[/itex]. Remembering [itex]v=f\lambda[/itex] you can express the angular frequency in terms of velocity and wavelength if you want.
So, to find the 'vertical velocity' you differentiate the expression for the displacement with respect to time, to give
[tex]v_{vert}=\omega A\cos{\omega t}[/tex]
This is clearly at a maximum when [itex]\cos{\omega t}=1[/itex], so the maximum vertical velocity is [itex]\omega A[/itex].
Taking the example of a radio wave at 100Mhz, if the average amplitude = 3/4 meter or greater then there
is a virtual speed (the vertical velocity) that is near or
greater then the speed of light. I assume that this kind
of wave have an average amplitude in the millimeter range
no where near the meter range, so the vibration of the
antenna(for imagine) is no where near the speed of light.
The analogy to 'vertical velocity' in the wave you're describing is the rate of change of the field (either electric or magnetic). It has no physical meaning in terms of height.
What about the intensity, can it be view as having different height? What is the closest imagination for this kind of wave? Is it close to droping a rock in the pond generated wave or something different that I don't have the imagination for cause I don't understand electromagnetic wave?
just bear in mind that the speed of an electromagnetic wave must be constant. only its amplitude, frequency and wavelength can be changed. however, the amplitude of a wave is not effected by its wavelength or frenquency, while the wavelength is inverse proportional to the frequency.
do u mean the intensity of the wave? if yes, it's suppose to be the intensity of the flux.
Yes. You would never ask what is the height of your bank account, i.e. mixing dollars and metres. Similarly, it makes no sense to ask the height of an electromagnetic wave; the amplitude is an electric field. Also, the intensity is the square of the amplitude.
That's a very good question, and I'm not sure anyone knows the answer. It's just how nature is!
However, the equation is a very simple one: the second time derivative is proportional to the second space derivative. So maybe it wasn't so unlikely that it would show up in more than one place. But that's really philosophy, not physics.
Hmm, I don't know if I would go that far jdavel. If you start from an analysis of origin centred circular motion in the cartesian plane you have the expression
[tex]y=r\cos{\omega t}[/tex]
We know that
[tex]\omega = \frac{2\pi}{T} = 2\pi f[/tex]
and that
[tex]\lambda=2\pi r[/tex] (circumference of circle)
Therefore
[tex]2\pi = \frac{\omega}{f}[/tex]
Which gives
[tex]\lambda =\frac{\omega r}{f}[/tex]
so
[tex]f\lambda =\omega r = v[/tex]
So that's for a 'physical' wave. We solve Maxwell's equations in free space and we get a nice planar sinusoidal wave as a solution, so the same relation holds.
James Jackson said:
...[tex]\lambda=2\pi r[/tex] (circumference of circle)...
James Jackson,
But you can't really do that and then say that lambda is also the wave length of a periodic wave. Because up to that point, you haven't even shown that there is a wave.
To show that a mechanical wave can exist on, say, a stretched string, you have to show that the string (under no force except its tension) can assume a shape of the form f(kx - wt) where k and w (omega) are constants. The function f doesn't have to be sinusoidal (or even periodic for that matter). In fact f can be anything (as long as it's continuous etc.).
The fact that this condition is approximately valid for lots of mechanical systems (stretched strings, air, the surface of water etc.) is very interesting. The fact that it is exactly valid for classical electric and magnetic fields is, I think, astounding!
Oh totally, I was just generalising to an easily analysed example... It's easy enough to also show that a sinusoidal wave is the simplest solution to the wave equation for a tensioned string, much like it's easy to show a sinusoidal wave (well, two of them) are the simplest solution to Maxwell's field equations in free space.
At the level you're talking at, this all comes down to the 'model vs reality' discussion.
Krab - Irradiance is proportional to the square of the amplitude (I'm being picky, I know), in SI units. Not sure about other units though.
[tex]I=\frac{1}{2}c\epsilon_0E_0^2[/tex]
jdavel - The reason why the equations are similar is because the wave equation describes propagating phenomena! The solutions to the wave-equation are waveforms moving at a constant velocity.
The fact that one disturbance is electromagnetic and one mechanical is irrelevant, the important similarity is that both scenarios involve a propagating disturbance, and it should therefore come as no surprise that all wave phenomena can be explained by the same form of equation.
tmwong - The speed of an electromagnetic wave can change when propagating through media (i.e. not in a vacuum). In this circumstance the velocity will reduce and wavelength is reduced by the same factor. Frequency is the only true invariant quantity. In a vacuum however, velocity and wavelength are indeed constant.
Claude.
  • · Replies 28 ·
  • · Replies 29 ·
  • · Replies 44 ·
58K
  • · Replies 16 ·
  • · Replies 19 ·
