Calculate the density of the object
  • Thread starter Thread starter DDS
    Density
The discussion focuses on calculating the density of an object based on its weight in air, water, and oil. The object weighs 324 N in air, 290 N when submerged in water, and 303 N when submerged in oil. The calculations reveal that the mass of the object is 33.027 kg, and the volume is determined to be 3.466 kiloliters (or 3466 cubic centimeters). The density of the object is calculated as 9.5288 grams per cubic centimeter, while the buoyant force in oil is used to derive the density of the oil.
  • Understanding of buoyancy and Archimedes' principle
  • Knowledge of weight, mass, and density relationships
  • Familiarity with unit conversions (N to kg, g to cc)
  • Basic skills in algebra for solving equations
  • Learn about Archimedes' principle and its applications in fluid mechanics
  • Study the concept of buoyant force and how it affects submerged objects
  • Explore density calculations for various materials and fluids
  • Investigate the properties of different liquids, including oil and water densities
Students in physics, engineers working with fluid dynamics, and anyone interested in understanding buoyancy and density calculations in practical scenarios.
DDS
An object weighing 324 N in air is immersed in water after being tied to a string connected to a balance. The scale now reads 290 N. Immersed in oil, the object weighs 303 N. Calculate the density of the object.
B)Calculate the density of the oil.
Part A:
The mass of the object is 33.027 kg
and the mass when submerged in water is 29.561 kg.
This means the volume would be 3.466 because the volume of the object is the volume of the displaced water.
So, 33.027 kg/ 3.466 kg =9.5288 and the answer is wrong.
What am i doing wrong.
As for B i don't know how to tackle it
The mass of the object doesn't change when submerged. What forces act on the object? Figure out what the buoyant force must equal and use that to figure the volume of the object.
Part A:
I wouldn't word it that way! The mass of an object doesn't change when it is submerged in water- it's weight does because of an upward bouyancy force. What is true here is that there is an upward bouyancy force of 324- 290 = 34 N. That would be equivalent to 34/9.81= 3.466 kg of water or, since water has a density of 1 g per cc, displacing 3466 cm3 of water. The object has a volume of 3.466 kiloliters.
This means the volume would be 3.466 kiloliters or 3466 cubic centimeters because the volume of the object is the volume of the displaced water.
I would strongly advise you to be careful about your units! The mass of the object is 324/9.81= 33.027 kg so its density is 33027 g/3466 cc= 9.5288 grams per cubic centimeter. Why do you say the answer is wrong?
The bouyancy force due to the oil is 324-303= 21 N so the oil displaced has a mass of 21/9.81= 2.141 kg= 2141 grams. The volume of oil displaced is the volume of the object, 3466 cubic centimeters.
12K
  • · Replies 20 ·
