Why Does Atomic Radius Increase Moving Left on the Periodic Table?
  • Thread starter Thread starter undertow
    Radius
The discussion revolves around the reasons for the increase in atomic radius as one moves left on the periodic table. Participants explore concepts related to atomic structure, effective nuclear charge, and electron shielding, with a focus on theoretical and conceptual understanding.
  • One participant expresses confusion about why atomic radius increases to the left, suggesting that more electrons should correlate with a larger radius.
  • Another participant proposes that while electrons increase moving right, the greater number of protons leads to a stronger effective nuclear charge, which contracts the atomic radius.
  • A different viewpoint emphasizes that elements in the same period have the same subshells, and the weaker nuclear charge on the left results in a larger atomic radius.
  • Some participants mention the shielding effect, indicating that filled electron orbitals shield the nucleus's charge, affecting the radius.
  • One participant questions the relationship between shielding and atomic radius, suggesting that increased shielding should lead to a larger radius moving right, but acknowledges that proton charge may overcome this effect.
  • Technical details are introduced regarding potential energy functions and Slater's rules, with questions raised about specific variables and their meanings.
  • Another participant discusses the relationship between energy levels and distance from the nucleus, explaining that greater energy is required to maintain electrons further away from the effective nuclear charge.
Participants express multiple competing views regarding the relationship between atomic radius, effective nuclear charge, and electron shielding. The discussion remains unresolved, with no consensus reached on the explanations provided.
Some participants reference specific rules and equations related to shielding and potential energy, but there are unresolved questions about the definitions and values needed for calculations. The discussion also touches on the complexity of atomic structure without fully clarifying all assumptions or dependencies.
undertow
Hi all. I'm a student trying to learn some chemistry concepts on my own. So, i'll asking for some help a bit here. Look forward to hairing from yall too.
To the question..
I don't understand why the radius of an atom gets larger as u move to the left of the periodic table. Since atoms have move electrons as you move to the right, I'm thinking, that the radius should also increase in that direction too. Move electrons, larger radius--but this isn't the case. How come?
Chemistry news on Phys.org
Educated guess: As you move to the right, the amount of electrons increases, but likwise the number of protons in the nucleus is larger. The effective nuclear charge on the outer electrons is stronger and thus the atom is contracted a bit more.
I would guess because those elements are in the same period. This means they have the same level of subshells avaliable, and while there in increase in electrons as well as protons as you go to the right, the effective nuclear charge is greater on the electrons, thus 'pulling' the valence electrons to reduce the atomic radii.
To the left, its the opposite, *given the fact that it the elements are in the same period for fair comparison*. The overall nuclear charge on the elctrons is 'weaker' than that of the elements on the right (due to reduced proton number AND WITH THE SAME SUBSHELL), and there is a a more 'loose' hold on the electrons, thus increasing the atomic radii.
undertow said:
More electrons, larger radius--but this isn't the case. How come?
As both whozum and Bladibla said, the increase in protons increase the attraction that are had on the electrons. This decreases the radius of the atom.
http://www.colorado.edu/physics/2000/index.pl is a periodic table that will show this.
The Bob (2004 ©)
Specifically,in The Bob's link, click "Table of Contents"; scroll down to the Periodic Table section under Science Trek and click "Periodic Properties" about midway down that section.
Whozum and Bladibla have said essentially the same thing.
remember that atomic radii also increase as you go DOWN the periodic table.
also, part of the reason for this is that as the electron orbitals are filled, they shield some of the charge of the protons in the nucleus from the outer orbitals. Thus, the + charge that electrons in the new orbital (i.e. each row, going down the periodic table) feel will effectively decrease as the orbitals become filled.
Slater's rules are a good "rule of thumb" for finding this shielding effect:
http://www.unb.ca/fredericton/science/chem/2201/Slater's_rule.html
these can then be applied to the potential energy function:
[tex]V(r_{ij}) = \frac{-Z^* e^2}{4\pi \epsilon r_{ij}}[/tex]
and solved for [itex]r_{ij}[/itex], the radius, by setting the potential energy equal to the known values for the orbitals (where Z* is the effective charge of the nucleus felt by the electron, that is, Z minus the loss due to electron sheilding). A more theoretical way, that wouldn't depend upon knowing the energy values a priori, would be to solve the Schrödinger equation, but this can be difficult.
If you solve this for varius elements on the period table, you will see the general trend of the radii increasing. ..you will also see that there are some exceptions!
Adding to what other's have said, you'll need to consider in detail aspects of effective nuclear charge. The latter increases as you move to the right. Why is this so? It's due to the trend in electron shielding...try to read up on this subject and if you have any further specific questions I'll try answering them.
makes sense...but the comment about the shielding effect brings up another question. If more electrons means more shielding for the outer shells causing an increase in radius. Then wouldn't it follow that the radius gets larger as you move to the right.The only explanation i can come up with is that the charge of the protons is so great that it overcomes this shielding effect
I'm completely stumped by this.
A couple of questions, please :
1. What do the subscripts i,j index ?
2. How do I find these known values of the Potential Energies of the orbitals ?
A guess here (so corrections please) but is mass affects the force of gravity then why not mass on the 'force' of charge. Protons have a greater mass so a greater pull.
The Bob (2004 ©)
[tex]r_{ij}[/tex] would be the same, in this case, as [tex]\sqrt{x^2 + y^2 + z^2}[/tex] where we take the origin to be the center of the nucleus. Since we are talking about one electron here with respect to a fixed origin, i guess the index notation really isn't needed.
A chemist would look them up in a table. I remember doing this in inorganic chemistry. A physicist would probably turn up their nose at this.
alright i think i understand so for. I have another question about atomic structure. My book states that there is greater energy in the orbitals as u move further away from the nucleus of an atom. It just states this and doesn't explain. anyone know why this is so?
I'll try and answer this.
It's because greater energy is required to 'maintain' the promoted electron at a greater distance from the effective nuclear charge.
Note: 'orbitals' and 'Energy level' has many swapped uses. Energy level is a more accurate descritpion, however..
Could you please indulge me and point me towards such a table ? I really am curious because the potential energy does not commute with the Hamiltonian.
The total energy of an electron bound to a nucleus must be negative. When you separate the electron greatly from the nucleus (ionize the atom), the energy of interaction between the two goes to zero, and so, a stationary free electron has zero energy, which is greater than any negative number. This tells you why it's plausible that the energy increases with distance.
A better explanation is slightly mathematical. The potential energy is always negative between an electron (negative charge) and nucleus (positive charge). The kinetic energy can be shown (in a few lines) to always be related to the potential energy through the relation, KE = -PE/2, which is a positive number. Hence, the total energy is given by, E = PE + KE = PE - PE/2 = PE/2, and is always a negative number proportional to the potential energy. The absolute value of the potential energy falls off as roughly 1/r with distance from the nucleus, so the total energy must increase (being the negative of this absolute value) with increasing r.
I'm curious about such a table also. Considering that the p, d, f, etc orbitals are highly eccentric with respect to the geometry of the electron distribution, I'm skeptical that one can actually look up a value for potential energy of a single orbital.
Zz.
The relative increase in shielding is less then the effect of the increasing proton number. Think about what happens as you successively add electrons starting from the 1s2 orbital for instance, how effectively do electrons in the 1s2 orbital shield each other relative to when you arrive at the p sub-orbitals?
yes, i see now. thanks for your help guys
I am glad I found this, I often wondered this same thing.
