Can You Prove Simple Harmonic Motion for a Mass Spring System?
The discussion revolves around proving that a mass suspended from a spring, which follows Hooke's law, undergoes simple harmonic motion when displaced from its equilibrium position. Participants explore the relationships between forces acting on the mass and the spring's behavior during vertical displacements.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the use of differential equations to describe the motion and question the derivation of key equations related to forces and equilibrium. There is also confusion regarding the interpretation of forces at equilibrium and the implications for motion.
The conversation is active, with participants offering different perspectives on the problem. Some have suggested methods for approaching the proof, while others express confusion about the provided information and its implications. There is no explicit consensus, but a productive dialogue is ongoing.
Participants note that the textbook explanation lacks clarity and does not involve calculus, which adds to the confusion. There is also mention of assumptions regarding the forces acting on the mass at equilibrium.
repugno
I've been trying this question for quite some time and have given up.
Prove that a mass,M , suspended from a fixed point by a helical spring, which obeys hooke's law, undergoes simple harmonic motion when it is displaced vertically from its equilibrium position.
Say I displace the mass spring upwards, e metres. Then I can say:
Mg + ke = Ma ?
When the mass is at far bottom then
kx - Mg = -Ma ?
When I equate these two I get kx=-ke, which proves nothing.
Thanks
What do you have to use? You certainly can't do it by looking at kinetic energy not at a few positions. I would do it by setting up the differential equation governing the motion and showing that the solution is harmonic.
The book gives the answer very vaguely which confuses me more. It does not have any calculus involved..
k(e + x) - Mg = -Ma
I have no Idea how they've derived this
Then they say 'in the equilibrium position, the pull of the spring ke is equal to the weight'
ke = Mg
But when the mass is at the equilibrium position the force on the mass by the spring is 0
Subsittuting above..
Mg + kx - Mg = -Ma
kx=-Ma
a=-(k/M)x
Compare with a=-(omega)^2x
Doing some math it also shows that T = 2(pi)(M/k)^(1/2)
Thanks for your help
ke = Mg
The spring still has a tension, even in equilibrium. It's the sum of the forces on the mass that is 0, which is the same as that first statement.
Thanks, it's just occurred to me that I've been looking at the situation the wrong way. :zzz: . problem solved
