Help with Speaker Issues: Static, Volume & More
  • Thread starter Thread starter Hurkyl
The discussion revolves around issues with speaker performance, specifically problems related to static, volume inconsistencies, and potential causes such as wiring and connections. Participants explore various aspects of speaker functionality, including the role of volume controls and the integrity of cables.
  • One participant describes intermittent static and volume issues with their speakers, suggesting potential problems with the speakers or cables.
  • Another participant proposes that the volume control (potentiometer) could be the source of the problem.
  • A different participant shares a personal experience indicating that static was due to wiring issues rather than the speakers or input jack.
  • Questions arise about how to determine whether the issue lies with the cables or the speakers' internal wiring, along with requests for reliable fixing methods.
  • One suggestion involves using an ohmmeter to trace unstable circuits while manipulating the components.
  • A participant queries whether the speakers are internally amplified based on their previous connection to a CD player.
  • Another participant expresses doubt about internal amplification, recalling that the CD player likely handled amplification itself.
  • Concerns are raised about loose connections and the potential for static interference due to exposed wires, along with recommendations for inspecting and cleaning the speakers.
  • One participant suggests that if cleaning and inspection do not resolve the issue, the circuitry in the speakers may need replacement.
Participants express varying opinions on the source of the speaker issues, with some attributing it to wiring or connections while others consider the volume control or internal circuitry. No consensus is reached regarding the exact cause or solution.
Participants mention potential limitations in diagnosing the problem without specific tools or further inspection of the speakers and connections. The discussion reflects uncertainty about the internal workings of the speakers and the reliability of various proposed solutions.
Hurkyl
Staff Emeritus
My speakers have done an odd thing for as long as I can remember. Sometimes, they'll play music perfectly fine, but sometimes, unless the volume level is sufficiently high, one or both speakers will crackle, and often play the music at a much reduced volume.
When the volume gets loud enough, they both start playing perfectly again, and usually continue to play perfectly for quite a while when the volume gets soft. (Though sometimes the static comes back immediately)
Often times, moving the speakers around, jiggling the cables, et cetera can cure the static for a little while, but it comes back again.
I'm pretty sure it's not my stereo, despite the fact it has an 8-track player! My speakers had the same problem with my previous system. (They could plug directly into the CD player I had at the time)
Today, I was getting fed up and started fiddling with them again... in the end I simply swapped the connections into the stereo, and voila! No static.
Well, basically my question is this... do I need new speakers, or is there something else that could be causing this problem? Maybe it's the cables? The input on my speakers requires bare wire -- we had to strip the ends off of ordinary cables to hook them up.
Computer science news on Phys.org
My experience is that the volume control (potentiometer) commonly causes problems similar to those you mention.
I had a pair of headphones that needed a little jiggling to remove the static. It was definitely a wiring problem, not the speakers themselves or the input jack.
Is there a way to tell if it's the cables connecting the speakers to the stereo, or the speakers' internal wiring? In either case, is there a reliable way to fix it?
In some cases an ohmmeter can trace down unstable circuits while one "wiggles" their various components.
Your speakers could be plugged directly into a CD player? Does this mean the speakers are internally amplified?
- Warren
I don't think so. It's been a long time since I used my previous CD player, but I guess it did its own amplification.
Sounds like you just have a loose connection, although any exposed wire is not good. The more exposed a wire is, the more subject it is to static interference. Where is the volume control, on the speakers or CD changer? If its on the changer then that's not good, somehom ur changer is getting a signal to decrease the resistance which causes boosts in the volume. If the volume control is on the speakers is most likel a connection issue. If its all on the speakers I'd just open them up, blow any dust out, wipe off any spills or if anything like that occurred, and just make sure nothing looks burn out and that all the connections are securely soldered. If none of that fixes it, then the problem is probably in the circuitry in the speakers in which case you'll most likely want to replace them unless you know of a handy EET with a few hours of spare time.
  • · Replies 30 ·
  • · Replies 23 ·
9K
  • · Replies 31 ·
  • · Replies 27 ·
  • · Replies 23 ·
  • · Replies 36 ·
