Calculating Computer Heat Generation with Thermoelectric Cooling Device
  • Context: Undergrad
  • Thread starter Thread starter Jobistober
    Computer Thermodynamics
This discussion focuses on calculating heat generation in Watts from microchips and processors using a thermoelectric cooling device in a liquid-cooled computer setup. Key formulas mentioned include I²R, V²/R, and VI for determining heat output based on electrical resistance, voltage, and current. The conversation emphasizes that while calculating heat generation is important, the efficiency of heat exchange with the coolant is critical for maintaining optimal chip temperatures.
  • Understanding of thermoelectric cooling principles
  • Familiarity with electrical resistance calculations
  • Knowledge of microchip specifications and power ratings
  • Basic principles of heat transfer in liquid cooling systems
  • Research thermoelectric cooling device specifications and efficiency ratings
  • Learn about calculating heat generation using I²R, V²/R, and VI formulas
  • Explore liquid cooling system designs and their thermal management techniques
  • Investigate the thermal conductivity of various coolant fluids
Computer engineers, hardware developers, and anyone involved in designing or optimizing liquid-cooled computer systems will benefit from this discussion.
Jobistober
Greetings All,
I have a computer project coming up and wanted to take an approach with physics. I want to use a thermoelectric cooling device to cool water in a liquid cooled computer. Heres the question: How can I calculate the amount of heat in Watts generated by the certain microchips and processors in the computer? If I know the temperature of the chip, isn't there a simple way to convert that temperature to its equivalent in Watts?
Any help is appreciated. Thanks.
Science news on Phys.org
How about just knowing the power produced by each component? That should be published data on each component.
Jobistober said:
Greetings All,
The heat generated /unit time by any electrical resistance is [itex]I^2R[/itex] or [itex]V^2/R[/itex] or [itex]VI[/itex]. So, if you have the voltage supplied and the current, you will be able to work out the heat given off.
I suspect that the most critical factor, however, will not be the amount of heat given off, but the speed at which heat can be exchanged with your coolant at the desired working temperature of the chip.
AM
  • · Replies 32 ·
15K
