Volume problem - Closest packing
  • Thread starter Thread starter Jchem
    Volume
The discussion revolves around calculating packing efficiency for different types of sphere arrangements, specifically Hexagonal Closest Packing, Cubic Closest Packing, and Body-Centered Packing. The original poster seeks to derive the volume of a box surrounding the spheres in these configurations to validate known efficiency values.
  • The original poster attempts to find the volume of a box around spheres in two packing configurations and questions how to approach this calculation. Some participants suggest using known efficiency values to derive the necessary volumes, while others propose counting whole and fractional spheres within an imaginary cube to estimate packing efficiency.
Participants are exploring various methods to calculate the volume of the surrounding box and are discussing the implications of different approaches. There is no explicit consensus on a single method, but some guidance has been offered regarding counting spheres and adjusting for efficiency.
The original poster mentions specific efficiency values from textbooks and the internet, indicating a reliance on established knowledge while seeking to understand the underlying calculations. The discussion also touches on the alignment of the box with sphere centers and the challenges posed by close-packed configurations.
Jchem
Ok I am trying to show the packing efficiency for 3 different types of packing.
1) Hexagonal closest packing (efficiency = 74%)
2) Cubic closest packing - (efficiency = 74%)
3) Body-centered - (efficiency = 68%)
I know the efficiency values because they are in my textbook and all over the internet. I need to come up with these numbers myself.
efficiency = Volume of the spheres/Volume of a box around the spheres.
the spheres in my model have a radius of 3cm, so volume of the spheres is easy... 4/3(pie)r^3 x (number of spheres)
I'm trying to figure out a way to find the volume of a box around Hexagonal closest packing and cubic closest packing.
_____________________________________________________________
Hexagonal closest packing: 13 balls in total in 3 layers. (see pictures below)
bottom layer: 3 spheres
middle layer: 7 spheres
top layer 3 spheres
Cubic closest packing : 13 balls in total in 3 layers
bottom layer: 4 balls
middle layer: 5 balls
top layer: 4 balls
______________________________________________________________
I know that the volume of both must be the same since they each have 13 balls and each have the same packing efficiency.
How do I find the volume of a box around these spheres?
I've been trying to figure this out for hours so any help at all is appreciated...and sorry for the length of the question :redface:
I can't think of a way to do this from scrath, but if you know the effeciency, you can solve for the volumes. That's kind of cheating though.
[tex]\frac{\mbox{Volume of Spheres}}{\mbox{x}} = \mbox{effiency}[/tex]
Solve for x.
I'm curious to the full answer of this problem as well.
top layer 3 spheres
top layer: 4 balls
In most cases, a box around whole spheres is not the way to look at it. You will probably do better assuming the corners of the volume you select are alighned with the centers of some spheres and then count the number of whole spheres and fractional spheres contained within that volume. Simple cubic can be done either way because there is no interlacing of layers. That is not the case for close-packed configurations.
ahh ok, thanks for the quick response ... I was trying to come up with something that would give me a precise answer.. but i guess that's not the most efficient way to solve it. :smile:
So basically, just pick the lines of an imaginary cube, calculate the volume..
Count the amount of spheres/partial spheres within that cube, multiply that by the volume of a sphere.
then doctor up your count to make the efficiency close to 74% :smile:
thanks
thanks
You won't even have to doctor it up :smile: Your second configuration also goes by the name face-centered-cubic.
  • · Replies 16 ·
13K
11K
