Can a line be constructed that ends in any positive integer whatsoever?
The discussion revolves around a mathematical exploration of sequences generated by a specific procedure involving operations on pairs of numbers. Participants investigate whether a line can be constructed that ends in any positive integer, as well as other related puzzles about number generation and transformations within the sequence.
  • One participant proposes a method to generate sequences starting from 0 and 2, using operations like addition, subtraction, multiplication, and division on the last two numbers.
  • Another participant suggests that any integer can be constructed, although the method may result in longer sequences for larger numbers.
  • Some participants express difficulty in generating higher prime numbers and fractions, indicating a potential complexity in the process.
  • A participant outlines procedures for negating numbers and seeks additional methods for achieving this.
  • There are claims that it is possible to create lines ending in specific forms, such as x 1 or 1 x, from lines ending in x.
  • Questions are raised about the ability to create any rational number or any two integers, with some participants asserting that it is indeed possible.
  • One participant presents a sequence that generates all integers, noting that it may take a long time for larger integers.
  • Another participant summarizes the outcomes of the original five questions, indicating that they have found answers to all but one, which remains unresolved.
Participants generally agree that it is possible to construct lines ending in any positive integer, as well as rational numbers and pairs of integers. However, there is disagreement regarding the specific methods and the feasibility of certain transformations, particularly in the context of reversing the order of two numbers in the sequence.
Some participants note that generating higher primes and certain transformations may be more complex than others, and there is an acknowledgment of the potential length of sequences required for larger integers.
This discussion may be of interest to those exploring mathematical sequences, number theory, and operations involving integers and rational numbers.
BicycleTree
I had this idea this morning and was going to make another "figure-out-the-sequence" out of it, until it occurred to me that it was slightly more interesting than that.
Consider the following procedure: start a line with 0 2, and add on additional numbers as you please so long as the following condition is met for each additional number: label the preceding two numbers from the one you are adding on a and b (in order) and the new number must be a - b, a + b, a / b, or a * b.
Here are lines made by that procedure that end in the numbers 1-4 respectively:
0 2 2 1
(0 + 2 = 2, 2 / 2 = 1)
0 2
(no additional numbers added)
0 2 2 1 3
(0 + 2 = 3, 2 / 2 = 1, 2 + 1 = 3)
0 2 2 4
(0 + 2 = 2, 2 * 2 = 4)
I ended it here because 5 is the first one that's a little bit harder.
Puzzlers:
1. Find lines ending in numbers as high as you can (say, shoot for 20; I just did 11).
2. Given that the last number so far on a line is x, how can you append numbers so that the number -x is the last on the line?
3. Given that the last two numbers in a line are arbitrary x y, can you append numbers until the line ends in y x? (note: if the last two numbers are x y, you can append x - y but not y - x)
4. Given that the last number on a line is arbitrary x, can you append numbers until the line ends in x 1 or in 1 x?
5. Can a line be constructed that ends in any positive integer whatsoever?
I do not know the answers to 3 and 4 at present. If, in thinking about this, you come up with other puzzlers about this type of sequence, feel free to add them to the thread.
Mathematics news on Phys.org
Here's some more idea of what I mean, in the form of lines ending in numbers from 1 to 9. Complete these up to 30:
0 2 2 1
0 2
0 2 2 1 3
0 2 2 4
0 2 2 1 3 -2 5 (slightly tricky)
0 2 2 4 6
0 2 2 1 3 4 7
0 2 2 4 8
0 2 2 1 3 3 9
To be clear, this is how you can make 5:
0 2
(start of line) Now the next number can be 2 (= 0 + 2), -2 (=0 - 2), 0 (=0 * 2), or 0 (= 0 / 2). In this case I chose 2.
0 2 2
Now the next number can be 4 (= 2 + 2), 0 (= 2 - 2), 4 (= 2 * 2), or 1 (= 2 / 2). In this case I chose 1.
0 2 2 1
Now the next number can be 3 (= 2 + 1), 1 (= 2 - 1), 2 (= 2 * 1), or 2 (= 2 / 1). In this case I chose 3.
0 2 2 1 3
Now the next number can be 4 (= 1 + 3), -2 (= 1 - 3), 3 (= 1 * 3), or 1/3 (= 1 / 3). In this case I chose -2.
0 2 2 1 3 -2
Now the next number can be 1 (= 3 + (-2)), 5 (= 3 - (-2)), -6 (= 3 * (-2)), or -1.5 (= 3 / (-2)). In this case I chose 5.
0 2 2 1 3 -2 5
Thanks for the clarification bicycletree. I've gotten pretty high numbers, obviously, there isn't a limit to the series. Those number with a lot of factors are particularly easy. I can't seem to get any of the higher primes(like 17, 31, 53, etc.). I can also get quite a large number of fractions. I'm still working on it though. :frown:
Well, any integer can be constructed--in fact I figured out a general method that will do so, although the line it makes for a given number n is somewhat longer than n is large. Doing 17 (without that method) was a little tricky:
0 2 2 1 3 4 7 11 -4 7 3 10 -7 17
You can get 31 from 17:
0 2 2 1 3 4 7 11 -4 7 3 10 -7 17 -24 -7 -31 22 -7 31
And you can get 53 from 31:
0 2 2 1 3 4 7 11 -4 7 3 10 -7 17 -24 -7 -31 22 -7 31 22 53
I have 4 procedures for negating a number. Here's one of them, the second one I discovered:
a b (a+b) (a+2b) -b
What are the other 3?
I did some more thinking about this last night and discovered that yes, it is possible to create a line ending in x 1 or 1 x from a line ending in x.
So the only question of the original five that I don't know the answer to is whether you can create a line ending in y x from a line ending in x y. My feeling at the moment is no; in fact, I know that you can't do it in a straightforward manner using addition and subtraction only. Looking at each new appended number algebraically as (nx+my), you can't get y x explicitly. Puzzle: how do you prove that?
Also, here is an additional question: can you create any rational number whatsoever? Or, more broadly, can you create a line ending in any two integers whatsoever?
Getting 20:
0 2
0 2 2 +
0 2 2 1 /
0 2 2 1 3 +
0 2 2 1 3 4 +
0 2 2 1 3 4 12 x
0 2 2 1 3 4 12 16 +
0 2 2 1 3 4 12 16 -4 -
0 2 2 1 3 4 12 16 -4 20 -
a b (a+b) (a+2b) -b
(+, +, -) a b a+b a+2b -b
(-, +, -) a b a-b a -b
(*, +, -) a b ab b+ab -b
(/, +, -) a b a/b b+a/b -b
(*, /, *, +, +, -) a b ab 1/a b (1/a)+b (1/a)+2b -b
(*, /, *, -, +, -) a b ab 1/a b (1/a)-b 1/a -b
(*, /, *, *, +, -) a b ab 1/a b b/a b+b/a -b
(*, /, *, /, +, -) a b ab 1/a b 1/(ab) b+1/(ab) -b
(/, /, *, *, +, +, -) a b a/b bb/a b b+bb/a 2b+bb/a -b
(/, /, *, *, -, +, -) a b a/b bb/a b b-b/a 2b-b/a -b
(/, /, *, *, *, +, -) a b a/b bb/a b bbb/a b+bbb/a -b
(/, /, *, *, /, +, -) a b a/b bb/a b b/a b+b/a -b
(*, *, /, *, *, -, +, -, /) a b ab abb 1/b ab a ab-a ab -a -b
[/color]
Yep, Gerben--the first four of those are what I had in mind. The next eight are just variations on the first four (you just did some operations to get b again, and then applied one of the first four) but the last one is interesting.
Here's my sequence for all the integers:
a b a+b a+2b -b a+3b -a-4b -b -a-5b -a-6b b ...
When a = 0 and b = 1, which you can get from 0 2 2 1 1 0 1, this creates every integer or the negation of that integer. Although it does take a long time for larger integers. Anyone know a shorter way (besides brute force)?
I have figured out the remaining puzzles. So here is the remaining list of questions, which I have the answer to:
1. Given that the last two numbers in a line are arbitrary x y, can you append numbers until the line ends in y x? (note: if the last two numbers are x y, you can append x - y but not y - x) (yes)
2. Given that the last number on a line is arbitrary x, can you append numbers until the line ends in x 1 or in 1 x? (yes)
3. Can a line be constructed that ends in any positive integer whatsoever? (yes--I have answered this one though a quicker answer may exist, and it's necessary in order to solve the other questions)
4. Can any rational number be constructed? (yes)
5. Can a line be constructed that ends in any two integers whatsoever? (yes)
6. Given that a line ends in x y, does there exist a single sequence of operations involving only addition and subtraction that can always be applied to make the line end in y x? (no)
And here is a puzzle I have not solved:
7. Given that a line ends in x y, does there exist a single sequence of operations that can always be applied to make the line end in y x?
Trivial answer:
0 2 2 1 2 2 1 2 2 1 2 2 1 2 2 1
0+2
2/2
2/1
1*2
2/2
2/1
1*2
...repeat
