Which is larger? the weight or the force?
  • Thread starter Thread starter Francis Oliver
    Force Weight
The discussion revolves around the concepts of weight and force in physics, specifically in the context of throwing a ball upward. The original poster expresses confusion about comparing the weight of the ball to the upward force applied to it during the throw.
  • Participants explore the relationship between weight and the net force acting on an object, particularly when it is in motion versus at rest. Questions arise about the definitions of weight and force, and how they interact during different phases of throwing the ball.
Several participants have provided insights into the relationship between weight and force, noting that the force applied during the throw must exceed the weight of the ball for it to accelerate upward. There is an ongoing exploration of how these forces interact, particularly in different scenarios such as holding the ball at rest versus throwing it.
Participants discuss the effects of gravity and the implications of net force, while also addressing potential misconceptions about the independence of weight and net force in different contexts.
Francis Oliver
Hello, I just started physics about a month ago and I’m having a bit of trouble. It may seem silly but I just have a hard time wrapping my mind around the concept of comparing amount of weight to amount of force.
So anyway my question is while you throw a ball upward, which is larger: the weight of the ball or your upward force on the ball?
Thank you very much for any assistance you can offer.
The total force on the ball is its weight (mg) plus any other force on it. When the ball is in your hand as you throw it up, you apply an upward force greater than mg so that there is a net acceleration, giving it an upward velocity. As soon as you let go, the only force acting on it is gravity (ignoring air resistance, which just acts to slow it down whatever direction its going). The net force is down, and the ball accelerates downward until it loses its upward velocity and begins to fall back down to earth.
Also, to clarify the weight of an object is a measure of the force of gravity acting on it.
A 1lb object has mass 0.45kg
The force of gravity on a 0.45 kg is 0.45*9.8 = 4.45N
So you get the conversion factor for the force of gravity,
1lb = 4.45N (only on Earth).
An object always WEIGHS the same (again, on Earth) but the net FORCE acting on it is independent of that. For example, if I'm holding a 1lb object in my hand the net force on it is zero, however it doesn't weigh 0 lbs, it weighs 1lb.
Cool?
I think perhaps whozum did not mean independent in the sense that the weight has no bearing on the net force. For if this were the case, his arm would require 0 force to hold the mass in the air.
I preume he meant that the net force of an object is not solely determined by the weight of an object. In your example, the ball is moving upwards, therefore the upwards force is greater, as it is OVERCOMING the gravitational force pulling the object down
-NewScientist
If you are simply holding the ball, at rest, the force you are applying to the ball is equal to the weight of the ball. Throwing it upward, you are giving the ball an acceleration so the force must be greater than the weight of the ball.
Thank you HallsOfIvy for expressing my idea far better than I could!
-NewScientist
-NewScientist
No, I'm just "simpler" than you are!
