The discussion revolves around the feasibility and design considerations of using CO2 canisters to power a water rocket. Participants explore the principles of thrust generation, pressure dynamics, and the relationship between water flow and nozzle design, focusing on theoretical calculations and experimental approaches.
- Exploratory
- Technical explanation
- Mathematical reasoning
- Debate/contested
- One participant suggests using a CO2 canister to pressurize a water tank, emphasizing the need to calculate optimal tank size and thrust based on nozzle diameter.
- Another participant notes the complexity of determining water exit rates due to the shape of the nozzle and suggests experimental testing as a practical approach.
- A different participant proposes a thrust calculation based on pressure and nozzle area, questioning how to determine the necessary tank pressure and size.
- One reply corrects the thrust calculation, stating it should be based on mass flow and flow velocity, requiring thermodynamic principles for accurate assessment.
- Another participant introduces Bernoulli's equation to relate pressure, water height, and flow velocity, while expressing concerns about the behavior of CO2 under varying conditions.
- Further discussion includes equations relating thrust to mass flow rate and exit velocity, with emphasis on the need to account for gauge pressure and drag forces.
- Participants discuss the implications of water density and mass flow rates on thrust, suggesting that the exit area and burn time are critical design factors.
- One participant emphasizes the importance of smooth transitions in nozzle design to minimize frictional losses and suggests a venturi effect for improved performance.
Participants express differing views on the best methods for calculating thrust and the necessary parameters for tank design. There is no consensus on a definitive approach, and multiple competing models and ideas are presented throughout the discussion.
Participants acknowledge limitations in their calculations, including assumptions about constant flow rates and the behavior of CO2 as it is injected into the tank. The discussion also highlights the complexity of accurately modeling the dynamics of the system.
Individuals interested in experimental rocket design, fluid dynamics, and the application of thermodynamic principles in practical scenarios may find this discussion beneficial.
