Register to reply
Probability density function
by KataKoniK
Tags: density, function, probability
Share this thread:
KataKoniK
#1
Jun17-05, 04:26 PM
P: 168
How do I calculate the PDF of someone's earning followed by their mean and variance?
This is the question:
Given density function
f(x) = 2.5 if 0.1 < x < 0.5
0 otherwise
The person is paid by the # of jobs they finish rather than by the hour. They get 10$/job. Calculate the density function of his earnings per hour, then their mean and variance.
What I did so far was integrating 2.5 from 0.2 to 0.4 and got an answer of 0.5. I am a bit confused on what to do with my answer and the 10$/job property. Any help would be great thanks.
Phys.Org News Partner Science news on Phys.org
New type of solar concentrator desn't block the view
Researchers demonstrate ultra low-field nuclear magnetic resonance using Earth's magnetic field
Asian inventions dominate energy storage systems
Andrew Mason
#2
Jun17-05, 04:50 PM
Sci Advisor
HW Helper
P: 6,671
Quote Quote by KataKoniK
0 otherwise
I think we need more information. What does f(x) represent? What does x represent?
AM
KataKoniK
#3
Jun17-05, 05:25 PM
P: 168
My mistake. f(x) is the density function where x is the random variable that is dependent on the complexity of the job (x is the time(hr) to finish each job for a guy working for the bank) We need to find out from that, the rate (normally assumed per hour) of working at the bank.
KataKoniK
#4
Jun18-05, 07:42 AM
P: 168
Not enough information still?
OlderDan
#5
Jun18-05, 10:24 AM
Sci Advisor
HW Helper
P: 3,031
You are given a uniform distribution for the time to complete a task, and you need to find the distribution of the hourly rate of pay. The hourly rate is inversely proportional to the time. You need to do a change of variables from x to u = 1/x and find the new distribution. The general criteria for such a transformation is
[tex]
\left| {f(x)dx} \right| = \left| {g(u)du} \right|
[/tex]
so that when the variable transformation and change of limits of integration are accomplished you will have
[tex]
1 = \int_{.1}^{.5} {f(x)dx} = \int_a^b {g(u)du}
[/tex]
If you find the mean and standard deviation of the new distribution, you can find the average hourly rate and its standard deviation.
KataKoniK
#6
Jun18-05, 01:38 PM
P: 168
Hmm, so you are saying that our answer will be 1/[something]? Also, do we integrate from 0.2 to 0.4 because it is 0.1 < x < 0.5 and not 0.1 <= x <= 0.5?
OlderDan
#7
Jun18-05, 02:39 PM
Sci Advisor
HW Helper
P: 3,031
The limits of integration come from u = 1/x and the relationship between du and dx. The limits are not .2 and .4. They are related to the limiting values of 1/x at x = .1 and x = .5. There will be a reversal of limits because du and dx have opposite signs.
I really don't see why you are doing anything with x = .2 and x = .4. You can get arbitrarily close to 0.1 and 0.5. Whether you have 0.1 < x < 0.5 or 0.1 <= x <= 0.5 has no bearing on the result. The integral of the density function is the same regardless of wether the interval is open or closed.
KataKoniK
#8
Jun18-05, 04:07 PM
P: 168
Alright, I am seriously confused about what you are trying to say here. After thinking this over and reading your replies again, here is what I did so far. Is this what you mean?
I let u = 1/x and then proceeded with du = -1/x^2 dx where
x = 0.1 -> u = 10
x = 0.5 -> u = 2
Then I tried to integrate from 10 to 2, but am really confused about what to do from here. The reason is because the x^2 in -x^2 du = dx does not cancel with anything from the constant value of 2.5.
OlderDan
#9
Jun18-05, 06:33 PM
Sci Advisor
HW Helper
P: 3,031
That is a good start. What you have so far is
[tex]
1 = \int_{0.1}^{0.5} {f(x)dx} = - \int_{10}^2 {\frac{{f(x)}}{{u^2 }}du} = \int_2^{10} {\frac{{f(x)}}{{u^2 }}du}
[/tex]
where
[tex] f(x) = \frac{1}{{0.4}} = 2.5
[/tex]
Convince yourself that the last integral is equal to 1 and you will conclude that the integrand of that integral
[tex]
[/tex]
is the probability density function of u. The pay per hour is proportional to u. Find the average of u in the usual way you find the average of a variable when you know the probability density function, and you will be able to determine the average hourly pay rate. Do the same for the standard deviation.
KataKoniK
#10
Jun18-05, 07:30 PM
P: 168
So, if I am reading your post correctly,
[tex]
\frac{{2.5}}{{1/x^2 }}
[/tex]
is the Probability density function of u.
And to get the guy's earning per hour, we integrate this
[tex]
\int_2^{10} {\frac{2.5}{{1/x^2 }}dx}[/tex]
which gives us a value, just say 5
Correct? If not, I am still confused on what to do after that here. I am not understanding the proportionality thing and the interpretation of the method of integration for this kind of question. Any clarification would be great thanks.
OlderDan
#11
Jun19-05, 11:41 AM
Sci Advisor
HW Helper
P: 3,031
[tex]
[/tex]
[tex]
The integral is not correct. The integral should be
[tex]
\int_2^{10} {\frac{2.5}{1/x^2 }d \left(\frac{1}{x} \right) = \int_2^{10} {g(u) du} = \int_2^{10} {\frac{2.5}{u^2} du} = 1 [/tex]
where g(u) is the probability density function of u, as you have identified, but this is not the integral for finding the hourly rate. This is just the integral of the probability density function which must always be one for any such function.
Let's review (I assume you have seen this before) the calculation of the mean of a variable when you know its probability distributaion function. For the variable x, the distributuion function is constant between 0.1 and 0.5 and zero everywhere else. By symmetry you can see that the mean is halfway between the end points of the distribution function, or [tex]\mu = 0.3 [/tex]. To actually compute the mean, you need to find the "expected value" of x. That is accomplished by performing the integral of the probability density function times x
[tex] \mu = E(x) = \int_{0.1}^{0.5} {xf(x)dx} [/tex]
Have you seen this before? You should do this integral and verify that it gives the correct result. The mean of u = 1/x cannot be easily deduced from g(u) because it has no symmetry, but it can be calulated by integrating ug(u)
[tex] E(u) = \int_2^{10} {ug(u) du} [/tex]
Performing this integral will give you the mean value of u. From your problem statement what is the variable u? x is the time to complete a job measured in hours, so u = 1/x is the number of jobs that are completed each hour. The average number of jobs completed each hour is E(u), so what is the average pay rate? See what you get and check back.
The standard deviation is found by computing another integral, which is usually "simplified" to a couple of integrals that must be combined to get the result. Have you seen these before? See if you can find the formula for calculating the standard deviation from the distribution.
KataKoniK
#12
Jun19-05, 12:11 PM
P: 168
Thanks for the thorough reply, so is this basically what you mean?
So answering the question
[tex]\int_2^{10} {\frac{2.5}{u^2} du} = 1 [/tex]
Is the probability density function for the number of jobs completed in each hour. Really dumb question I am not seeing, but is this also the density function for a person's earning per hour? If so, then the first part of the question is done.
Then I must find the mean, which is basically (as you stated)
whatever the above gives us (a value, just say 100)
And to find the variance, we just do this
[tex] VAR(u) =\int_2^{10}{(u - \mu)^2g(u)du}[/tex]
whatever the above gives us is the variance (a value, just say 10).
Correct? I was confused at first. I thought that when the question was asking "What is the probability density function of his earning per hour". I thought they wanted a physical value rather than an equation/integral definition of the scenario.
OlderDan
#13
Jun19-05, 01:18 PM
Sci Advisor
HW Helper
P: 3,031
They do want an actual value. The integral is not the density function. The density function is g(u). The integral of g(u) over the interval 2 to 10 has to be 1. (The interval from 2 to 10 is the only interval where g(u) is not zero since f(x) is non-zero only between 0.1 and 0.5.) The integral of all probability density functions over their entire range must always be 1. When you perform the integral of ug(u) discussed earlier, you will get a numerical result between 2 and 10. That is the average number of jobs that can be completed in 1 hour. From that number you can calculate the average $$ earned in one hour. The density function for the pay rate is also g(u) because the pay rate is directly proportional to u. The expected value of the pay rate is not simply ug(u) because the pay rate is a multiple of u, not u itself.
Your expression for the variance is correct. You might want to expand the quadratic and perform separate integrals over the terms in the expansion, but if you can do the integral as written, that is fine too. Performing the integration will also result in a numerical value for the variance of u. If you multiply that by the same factor used for the mean, you will have the variance for the pay rate.
KataKoniK
#14
Jun19-05, 01:31 PM
P: 168
So you are saying that doing
[tex]\int_2^{10} {ug(u) du = \int_2^{10} {u \frac{2.5}{u^2} du} = \int_2^{10} {\frac{2.5}{u} du} = 5[/tex]
Assume the answer is 5, so that is the average number of jobs that can be completed in 1 hour? Furthermore, since the answer is 5, his earnings per hour based on that density function is just $50 (5 x 10)? If so, thanks a ton for the help OlderDan. I think I understand it now
Thanks for the heads up.
OlderDan
#15
Jun19-05, 03:45 PM
Sci Advisor
HW Helper
P: 3,031
That's it. Just do the integral and get the right number for E(u)
KataKoniK
#16
Jun19-05, 04:25 PM
P: 168
Thanks. One last comment, from this, the mean is the same as the average number of jobs completed in 1 hour?
KataKoniK
#17
Jun19-05, 06:35 PM
P: 168
Ignore the previous post. Is this correct?
[tex]\int_2^{10} {ug(u) du = \int_2^{10} {u \frac{2.5}{u^2} du} = \int_2^{10} {\frac{2.5}{u} du} = 2.5 ln |u| [/tex]
which gives 2.5 * ln 10 - 2.5 * ln 2 = 4.0236
Earnings per hour is 4.0236 * 10 = 40.236
[tex]E(u) = 4.0236[/tex]
[tex] VAR(u) =\int_2^{10}{(u - \mu)^2 (2.5/u^2)du} = 3.810[/tex]
Cool? If so, thanks a bunch for your time and help
Furthermore, I just noticed there is a subquestion. It says that the guy has to pay 29% of his earnings for tax purposes. What is the density function of his actual earnings after paying this tax?
Isn't the answer for this just taking (provided I have did the above right) 40.236 / 1.27 = $31.681? Or is the actual density function completely different than what you came up with without the tax?
OlderDan
#18
Jun19-05, 09:25 PM
Sci Advisor
HW Helper
P: 3,031
The hourly rate and variance looks good. The tax does not change the density function. It only changes the scale factor for computing his earnings after taxes. His hourly eanings are still based on the average number of jobs he can complete every hour, for which the density function is the same g(u) as before. You need to check the after taxes calculation.
Register to reply
Related Discussions
Probability density function Calculus & Beyond Homework 6
Probability density function Calculus & Beyond Homework 2
Probability Density Function Calculus & Beyond Homework 6
Probability Density Function...Help Calculus & Beyond Homework 3
Probability Density Function - Need Help Set Theory, Logic, Probability, Statistics 3
