How can I rotate a figure around its center?
The discussion revolves around the topic of linear transformations in the context of rotating a geometric figure, specifically a rectangle, around its center. The original poster is attempting to modify a transformation matrix to achieve this rotation.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the necessity of translating the rectangle's center to the origin before applying the rotation transformation and then translating it back. The original poster questions the correctness of their transformation and the resulting coordinates after applying the transformation.
There is an ongoing exploration of the transformation process, with some participants providing guidance on the steps needed to achieve the desired rotation. The original poster is seeking clarification on their proposed transformation and its validity, while also raising additional questions related to homogeneous coordinates and the mapping of circles to ellipses.
The original poster mentions a deadline for their assignment, indicating a sense of urgency in resolving their questions. There are indications of potential errors in the translation and transformation process that are being scrutinized by other participants.
Mathman23
Rotating a figure around its center
Hi
I have this here this here linear transformation:
[tex](x,y) \rightarrow \left[ \begin{array}{cc} -cos( 2 \theta ) & sin(2 \theta) \\ sin(2 \theta) & cos(2 \theta) \end{array} \right] \left[ \begin{array}{c} x \\ y \end{array} \right][/tex]
Turns the figure recthangel A(3,1) B(5/2, 2) , (9/2, 3) , D(5,2)
90 degrees clockwise from the figures current position.
My questions is how do I change the transformation so it turns the figure around the figures center ?
Do I add the figures center like this
[tex](x,y) \rightarrow \left[ \begin{array}{cc} -cos( 2 \theta ) & sin(2 \theta) \\ sin(2 \theta) & cos(2 \theta) \end{array} \right] \left[ \begin{array}{c} x \\ y \end{array} \right] + \left[ \begin{array}{c} a \\ b \end{array} \right][/tex]
Fred
Yes, but first translate the rectangangle so its center is the origin, then rotate, then translate back. That is: determine what the coordinates of the center are, subtract those coordinates from each of the corners, multiply by the matrix then add the coordinates back.
Hi,
I get the center of the figure to be (15/4,2)
Then I subtract the coordinants from the center:
A(3,1): there is A'((3/4,1) is the new coordinant.
I then insert this coordinant into my transformation
[tex](x,y) \rightarrow \left[ \begin{array}{cc} -cos( 2 \theta ) & sin(2 \theta) \\ sin(2 \theta) & cos(2 \theta) \end{array} \right] \left[ \begin{array}{c} \frac{3}{4} \\ 1 \end{array} \right][/tex]
where theta = pi/2
I get the rotated A to be [(3/4,-1)]
I add the diffence between old A rotated A' to obtain the correct rotated A coordinant??
If I do that I get the center again. That can't be the rotated koordinant can it ?
Sincerely
Fred
The center should return to its original position. That is why you shift it to the origin before rotating, and then shift it back. Perform the same steps on the corners of the rectangle and see what you get.
Hi Dan and thanks for Your answer,
This is the coordinants translated:
A(3,1) -------> (3/4,-1)
B(5/2,2) -----> (5/4,0)
C(9/2,3) -----> ((-3/4,1)
D(5,2) -------> (-5/4,1)
Is this what You mean ?
How does this prove that my proposed transformation is correct ??
/Fred
If you plot them you will see that these are not corect. I did not notice it earlier because I thought you were asking about the center point, but your translation A to A' was not correct. You failed to change the y coordinate (or maybe just got the sign wrong?) and the sign of the x coordinate is wrong. Be careful with the translation and try these again.
Hi Dan,
As mentioned earlier my assignment is write a transformation which rotates the rectangel 90 degrees clockwise from its current position around the figures center.
My surgestion for the transformation is that wrong?
You talk about that I need to translate the center from to the (0,0) and then back again to the original center in order to make the transformation valid. Can this be incorparated into my surgested transformation if its vallid ??
I have two follow up questions if that's allright.
[tex]s(x) = \left[ \begin{array}{cc} a_{11} & a_{12} \\ a_{21} & a_{22} \end{array} \right][/tex]
I'm told that this transformation can be done by another transformation using homogeneous coordinants.
[tex]s(x) = \left[ \begin{array}{ccc} a_{11} & a_{12} & 0 \\ a_{21} & a_{22} & 0 \\ 0 & 0 & 1 \end{array} \right][/tex]
Any idears on how I can show this ??
Finally how can one explain using transformations that a circle in the plane can be mapped into a ellipse ??
I have tried for three weeks to answer these three questions, but my Linear Algebra isn't very good and I'm in a terrible jam because I have to be able to answer these three questions in tuesday. Therefore I will be forever greatful if You could help me answer these question :-)
Best Regards and Bless You
Fred
