Can a Bird Lift a Container of Mass 10 Tonnes?
The discussion centers around the question of whether birds can lift a closed container, specifically a van with birds inside, and how their flight affects the weight of the van. Participants explore theoretical implications, analogies, and the mechanics of flight within a closed system.
  • Some participants argue that the weight of the van will not decrease when the birds fly, as the birds exert force on the air, which in turn exerts an equal force on the floor of the van.
  • Others suggest that the pressure exerted by the birds could cause fluctuations in the apparent weight of the van during the transition of the birds taking flight.
  • A few participants discuss the concept of momentum conservation, stating that if the van could become lighter, it would imply an impossible scenario of accelerating without an external force.
  • Some participants mention that the movement of air caused by the birds' flight would create turbulence, affecting pressure on the sides and ceiling of the van, but ultimately argue that these forces cancel out.
  • There is a discussion about the relationship between the center of mass and weight, with some noting that changes in the center of mass during flight could lead to temporary changes in the normal force exerted by the ground.
  • One participant provides an analogy involving a person jumping in a sealed crate to illustrate how apparent weight might change during dynamic actions.
Participants express a range of opinions, with no clear consensus on whether the weight of the van decreases when the birds fly. Some agree on certain mechanics of flight and pressure, while others present competing views on the implications of these mechanics.
Participants highlight various assumptions regarding the closed system, the nature of forces involved, and the implications of momentum conservation. The discussion includes unresolved questions about the relationship between center of mass and apparent weight.
ssj5harsh
I came across this question while looking around the forums at physlink.com:
There are birds of mass 20 tonnes in a van of mass 10 tonnes. The back of the van is closed(no air can go in or come out). If now the birds start flying, will the weight of the van decrease?
I ask this question here because the folks at physlink at quite divided on this topic. My opinion is that the weight will not decrease since the bird will apply a force on the air to fly. The air will apply the same force on the floor of the van(since it can't go out). Hence the weight shouldn't decrease.
Another analogy is that the birds are acting as point particles. They will interact with other birds and with air particles(like another gas mixed in air). So the weight won't decrease.
Another question:
Can a bird in a closed container lift the container up? This is surely possible if the bird is in a cage, but probably not in this case.
For the first one, I'm really divided in my opinion, so I don't know.
ssj5harsh said:
Another question:
A cage isn't a closed container, so it could lift a cage. If it was in a balloon or something, then I don't think it would be able to lift itself up. It wouldn't have enough airflow to work with to generate its lift.
wouldn't the bird end up putting pressure on the sides aswell, and therefore , from outside, the van will lift slightly, but it will also rock as the birds put pressure on the sides...
When the cage is closed and the birds start flying:
A flying bird inside the cage will try to support its own weight , therefore the thrust with which the bird swaps its wings will equal the mg downwards bu the force with which air molecules strike the surface with the same thrust , thus the whole weight still remains the same.You can say the basic interaction remains the same.
Evidently the folks at physlink have forgotten that momentum is conserved.
If the birds could make the van lighter, then with no gravity they could accelerate it with no outside force acting on it. That's impossible. So making it lighter is too.
I agree with you. The force needed to make the bird fly is provided by the air, which will exert the same force on the floor.
As hexhunter said, the movement of the air will be turbulent and thus exert pressure in the sides and even the ceiling of the van, but all those forces cancel out. The force in the floor will be the weight of the birds plus the force on the ceiling.
Of course a bird can't lift a closed container anymore than you can lift yourself by pulling at your hair, like did the baron of Münchausen.
If the birds start out sitting on the floor of the van, then begin flying around, realize that the center of mass of the system has changed. During that transistion, the apparent weight of the van would fluctuate.
Wouldn't the molecules of a gas also exert a similar force causing a closed container which is sitting on the table to rock slightly? I think the pressure on either side cancels the force out.
This would also be true for a large number of birds in said van.
Is there any correlation between centre of mass and weight?
W=mg
The change of the position would only cause a small(perhaps negligible) change in 'g'. As far as I know centre of mass only related to stability.
W=mg
The question really isn't asking about the actual weight of the van (the force of the Earth's gravitational pull, w = mg), but about the apparent weight that a scale would register. (Imagine the entire van on top of a giant, very accurate scale.) The apparent weight is equal to the normal force of the supporting surface.
Now rethink your answer. Does the force that the ground (or scale) exerts on the van change at any time as the birds begin to fly?
Here's an exaggerated version of the same thing that may be easier to visualize. Imagine yourself sealed up in a large wooden crate. The crate rests on top of a scale. You jump up and down. Will the scale reading change?
I get your point now Doc Al. Thanks.
Yes, in order to jump you must accelerate your mass, so in the instant of the jump the normal force will be greater. But if after jumping you could fly the normal force would be only your weight. The same is true for the birds. In the moment they start to fly the weight is greater, but it stabilizes afterwards.
Anyway I don't see what does this relate to the displacement of the center of gravity.
Right.
The movement of the center of mass implies an acceleration, thus an increased normal force. (Just another way of looking at the same thing.)
Doc Al said:
Right.
OK! I didn't realize that in your previous post you mentioned that the weight variation occurred during transition. I agree with you.
  • · Replies 16 ·
  • · Replies 71 ·
10K
  • · Replies 30 ·
  • · Replies 16 ·
11K
