Calculating Surface Integral with Stoke's Theorem | -2pi/5 Answer Explained
The discussion revolves around evaluating the surface integral ∫∫s (X^4 + Y^4 + Z^4) dσ over the surface defined by X^2 + Y^2 + Z^2 = 1, utilizing Stoke's Theorem. Participants explore various approaches, mathematical reasoning, and the implications of symmetry in the function being integrated.
  • One participant presents the integral and expresses uncertainty about the next steps after applying Stoke's Theorem.
  • Another participant questions how a positive integrand can yield a negative result.
  • A different participant proposes integrating over the top hemisphere of the sphere, suggesting symmetry in the function.
  • Concerns are raised about the symmetry of the function g(x,y,z) = x^4 + y^4 + z^4, with some participants affirming and others questioning this symmetry.
  • Several participants share their attempts at setting up the integral in polar coordinates and express varying results, leading to differing answers for the integral's value.
  • One participant provides a detailed spherical substitution and transformation of the integral, while others express confusion about the correct formulation.
  • Multiple participants report different numerical results for the integral, leading to a request for a third opinion to resolve discrepancies.
Participants do not reach a consensus on the correct value of the integral, with multiple competing views and calculations presented. Disagreement exists regarding the symmetry of the function and the implications for the integral's evaluation.
Participants express uncertainty about the assumptions underlying their calculations and the definitions used, particularly regarding the symmetry of the function and the setup of the integral.
Readers interested in advanced calculus, surface integrals, and the application of Stoke's Theorem may find this discussion relevant.
defang
Here is the question:
Evaluate the surface integral ∫∫s (X^4 + Y^4 + Z^4) dσ, where dσ is the surface element and S = { (X,Y,Z) : X^2 + y^2 + Z^2 = 1}
I know you have to take the square root of 1 + (dz/dx)^2 + (dz/dy)^2 dxdy. And I got -2X/2Z and -2Y/2Z, respectively. Then, I must incorporate this into Stoke's. Can anyone tell me what to do next? The answer to the quesion -2pi/5. THANKS!
How do you get a negative answer to an integral where the integrand is positive?
Hello Defang. Welcome to PF. This is what I have:
[tex]g(x,y,z)=x^4+y^4+z^4[/tex]
[tex]S=\{(x,y,z):x^2+y^2+z^2=1\}[/tex]
So, we're going to integrate g over a sphere at the origin with radius 1. Since everything is spherically symmetrical, let's just cut it in half and just do the top part:
[tex]I=2\int\int_K (x^4+y^4+z^4)ds[/tex]
where K is the surface above the x-y plane described by the function:
[tex]K=z(x,y)=\sqrt{1-x^2-y^2}[/tex]
Now, the projection of this surface onto the x-y plane is just the circle:
[tex]R=x^2+y^2+1[/tex]
It is over this area that we'll integrate using the standard formula:
[tex]I=2\int\int_R g(x,y,z(x,y)) \sqrt{(z_x)^2+(z_y)^2+1} dA[/tex]
Defang, I now suspect the function:
is not spherically symmetrical. Can someone confirm this? If so then my analysis above is not correct. Sorry.
You know, sometimes its good just to keep your mouth shut. Unfortunately for me that doesn't work in math: better to get in trouble if that's what it takes to get the problem straight in my head. I now believe the top hemisphere of the function is symmetrical with the bottom part in which case the analysis above WOULD work.
Can someone please provide another opinion about this? I'd like to see the problem completed not to mention attempt to solve it numerically and compare the results.
Alright, go ahead, say it:
[tex]g(x,y,a)=g(x,y,-a)[/tex]
I'm outta' here . . .got some french toast to make . . .
Thanks saltydog. Then, I have 0 ∫ 2pi 0 ∫ 1 (r^4 + √ 1-r^2) (√1 + 4r^2) r dr dθ. Is this correct? If it is correct, any tips on how to solve this integration?
"[ tex ] \int_0^{2 \pi} \int_0^1 \left( r^4 + \sqrt{1 - r^2} \right) \left( \sqrt{1 + 4r^2} \right) r \; dr \; d \theta [ /tex ]"
[tex]\int_0^{2 \pi} \int_0^1 \left( r^4 + \sqrt{1 - r^2} \right) \left( \sqrt{1+4r^2} \right) r \; dr \; d \theta[/tex]
edit to add link: https://www.physicsforums.com/showthread.php?t=8997&page=1
[tex]r^4 = \left( x^2+y^2+z^2 \right) ^2 \neq x^4+y^4+z^4[/tex]
Here's my attempt, which is different from saltydog's:
[tex]\left( x^2 + y^2 + z^2 \right) ^2 = x^4 + y^4 + z^4 + x^2 \left( y^2 + z^2 \right) + y^2 \left( x^2 + z^2 \right) + z^2 \left( x^2 + y^2 \right)[/tex]
Spherical substitution:
[tex]\begin{align*} &x=R \sin \theta \cos \phi \\<br /> &y = R \sin \theta \sin \phi \\<br /> &z = R \cos \theta \end{align}[/tex]
Which gives us:
[tex]\begin{align*} x^4 + y^4 + z^4 &= \left( x^2 + y^2 + z^2 \right) ^2 - x^2(y^2+z^2) - y^2(x^2+z^2) - z^2(x^2+y^2) \\<br /> &= R^4 - 2x^2y^2 - 2x^2z^2 - 2y^2z^2 \\<br /> &= R^4 \left( 1 - 2 \sin^4 \theta \cos^2 \phi \sin^2 \phi - 2 \sin^2 \theta \cos^2 \theta \cos^2 \phi - 2 \sin^2 \theta \cos^2 \theta \sin^2 \phi \right) \\<br /> &= R^4\left( 1 - 2 \sin^4 \theta \cos^2 \phi \sin^2 \phi - 2 \sin^2 \theta \cos^2 \theta \left( \cos^2 \phi + \sin^2 \phi \right) \right) \\<br /> &= R^4\left( 1 - 2 \sin^4 \theta \cos^2 \phi \sin^2 \phi - 2 \sin^2 \theta \cos^2 \theta \right) \end{align}[/tex]
So [tex]g(R, \theta, \phi ) = R^4 \left( 1 - 2 \sin^4 \theta \cos^2 \phi \sin^2 \phi - 2 \sin^2 \theta \cos^2 \theta \right)[/tex]
And the integral we want is
[tex]\int_0^{2 \pi} \int_0^{\pi} g(1, \theta, \phi) dS = \int_0^{2 \pi} \int_0^{\pi} \left( 1 - 2 \sin^4 \theta \cos^2 \phi \sin^2 \phi - 2 \sin^2 \theta \cos^2 \theta \right) \sin \theta \; d \theta \; d \phi[/tex]
Just to be sure, you did mean
[tex]\iint_S x^4 + y^4 + z^4 \; dS[/tex]
and not
[tex]\iint_S x^4 \hat{i} + y^4 \hat{j} + z^4 \hat{k} \; dS[/tex]
right?
Guys . . . I got:
[tex]\frac{12\pi}{5}[/tex]
I mean, if I'm wrong I want to be right Ok. What did you get?
My calculator tells me its
[tex]\frac{13 \pi^2}{16}[/tex]
but it's old and the batteries are low, so it could be wrong.
Oops! I entered it wrong! The answer is more likely to be
[tex]\frac{17 \pi}{5}[/tex].
I don't know Rachmaninoff. Suppose I'll go over my work. How about you Defang? I just converted the integral to polar coordinates and plugged it into Mathematica and multiplied by 2.
okay... what's your final integral look like? mine was derived above.
-rachmaninoff
-rachmaninoff
Here it is:
[tex]\int_0^{2\pi}\int_0^1(\frac{r^5Cos^4(\theta)}{\sqrt{1-r^2}}+\frac{r^5Sin^4(\theta)}{\sqrt{1-r^2}}+\frac{r(1-r^2)^2}{\sqrt{1-r^2}})drd\theta[/tex]
That's just the top part. Multiply by 2 to get the answer I got (via Mathematica)
Well, I hate to be a pain but I request some closure in this matter. Now:
Rachmaninoff said:
[tex]\frac{17\pi}{5}[/tex]
Now, I'm pretty sure mine is correct. So sure, I'd bet a dollar. But Rachmaninoff feels otherwise and I've followed his other postings; he's very good so I'm worried. Can someone supply a third opinion?
Thanks,
Salty
Indeed, after what looked like endless calculation, I have finally got an answer: 12pi/5 (still learning this LaTex program). 2 0 ∫ 2pi 0∫1 [ r^4 (3/4 + 1/4 cos4θ ) + (1-r^2)^2 ] 1/(√1-r^2) r dr dθ. saltydog & rachmaninoff, thanks for your help!
  • · Replies 27 ·
