What materials make the best mirrors?
  • Context: High School
  • Thread starter Thread starter ssj5harsh
    Mirror Surface
The discussion revolves around the differences between mirrors and white surfaces, specifically focusing on the materials that make effective mirrors and the optical properties that allow for image reflection. Participants explore concepts related to light reflection, color perception, and the characteristics of various surfaces.
  • Some participants describe mirrors as reflecting light to form clear images, while white surfaces reflect light diffusely, leading to less distinct images.
  • There is a discussion about the role of surface polish in image clarity, with some suggesting that polished white surfaces can reflect images but not in their true colors.
  • One participant proposes that the reflection coefficient of white surfaces varies with light intensity, affecting color perception in reflections.
  • Another viewpoint suggests that all materials that make good mirrors are metallic, while others question whether glass can also serve as a good mirror under certain conditions.
  • Some participants note that the color of a surface does not necessarily determine its ability to reflect images clearly, as even polished black surfaces can show more colors than white surfaces.
  • There is a mention of the importance of angle in reflection, with mirrors reflecting light at equal angles compared to white surfaces scattering light in multiple directions.
Participants express differing views on the characteristics of mirrors versus white surfaces, with no consensus on whether non-metallic materials can effectively serve as mirrors. The discussion remains unresolved regarding the correlation between surface color and reflective quality.
Participants highlight various assumptions about light reflection, the role of surface polish, and the intensity of light affecting color perception, but these aspects remain unresolved within the discussion.
This discussion may be of interest to those studying optics, materials science, or anyone curious about the properties of reflective surfaces and their applications.
ssj5harsh
What is the difference between a mirror and a white surface?What I know is:
1. A mirror reflects light such that an image is formed. The angles of reflection and incidence are equal. It reflects all wavelengths of light.
2. A white surface reflects all visible wavelengths of light. It causes the light to be diffused.
This list, I think, is right, though not complete.
What I'm wondering about is: Why can't one see his image in a polished white surface. We do see an image, but it does not have the same colours as the object.
Science news on Phys.org
A mirror reflects light at "equal angles": that is, a beam that comes in at 30 degrees to the mirror will be reflected at 30 degrees. A white surface will reflect most of the incoming light, equally at all frequencies, but at many different angles.
I think I've already mentioned that.
Have you seen an acrylic whiteboard. Its white, polished and one can see one's image in it, but it doesn't reflect colours properly. White is supposed to reflect all visible wavelengths of light.
this is a guess but anyway...white surfaces absorb most of the light incident on it but reflect equally well for all frequencies(I think the term involved here is the reflection coefficient. The reflection coefficient of a white wall is the same for all visible frequencies). For example if I keep a flashlight with the light having a yellow colour next to the wall I would see the yellow colour reflected from the wall, since the intensity of light from the flashlight is high, so the intensity of reflected light of the flashlight is still higher than the intensity of the 'usual' white light reflected. But if I tried to see the image of, say, my red shirt, I couldn't because the light incident from my shirt is simply of too low intensity. If the surface is highly polished, you may be able to distinguish images in the surface, but the light reflected showing the red shirt would probably have only a slightly higher intensity than the intensity of the reflected white light, so the image is not in its 'proper' colour. However mirrors hardly absorb any light. So the images are seen in their 'proper' colours.
At any rate I don't think it is technically right to say that white surfaces are perfect reflectors. They reflect most, but not all light.
Each part of a mirror reflects light in one direction.
Each part of a white surface scatters light in all directions.
The frequencies don't enter into this aspect of it.
I'd think that the reason you can vaguely see your reflection in a whiteboard is because, as you say, it's got a shiny smooth surface. The fact that it's white doesn't come into play, (you can't see your face in a sheet of A4), - because it's polished it will generally reflect light at equal angles (as explained by HallsofIvy).
Do you see your image reflected in it, or do you see merely a silouette of yourself? A silouette is simply the grossest, most highly contrasty elements reflected (such you unlit face blocking a bright-walled room.)
Not into this aspect of it. Definitely a polished white surface will give a sharp image. But if a surface is white does not mean that it will neccessarily scatter light in all directions.
But when you say 'white' you mean that it is reflecting all colours of light towards you. So why isn't your image as clear as in a mirror? You only faintly see the colours, the contrast depending on the intensity of reflected light. I think that's what ssj5harsh's question was.
What is common to all materials that make good mirrors ? Do any of these materials ever look white ? Can you pick out a possible correlation there ?
Yes, this was what I intended to ask.
Well, one correlation is that it is not simply lustre, but the greyish shiny colour that makes metals good reflectors. I, for one, haven't seen a white mirror and I doubt one can be made. As for the correlation, I see none(except for the colour). I would rather like to ask why such a correlation exists.
For that matter, I should also mention that my experience indicates that all surfaces which are highly polished show images, irrespective of their colour. But even a black surface(which supposedly absorbs all frequencies), shows more colours than a white surface in the image.
Further, why don't frequencies enter into this aspect of it.
You have the keyword there - "metal". Essentially, it appears that no matter what the polish, you can make a good mirror only out of a metal. Do you concur ?
Could I not also make a good mirror entirely out of glass? For example, a right angle prism or similar shape which has the effect of internally reflecting the light.
But maybe that's off the topic.
  • · Replies 24 ·
17K
  • · Replies 26 ·
