Register to reply
Dark Matter Chemistry For Mind?
by Palmutil
Tags: chemistry, dark, matter, mind
Share this thread:
Palmutil
#1
Jun21-05, 09:06 AM
P: 3
http://noeticcenter.tripod.com
http://noeticcenter.tripod.com/ periodictableofpersonalities/
MIND MATTER
Condensed from Noetic Journal Vol.4 No.4, October 2003 351
_________________________________________________________________
Abstract. Dark matter may be just as real as visible matter, but a subtler form of matter. The physical (and chemical)
properties of dark matter are unknown. Devoid of electrical charges, the dark matter permeates the visible matter without being detected. Will charge-less particles form dark atoms? Will they then interact strongly with each other and with ordinary matter? If subtle dark matter chemistries exist, they may yield subtle bodies and may give us a theoretical basis for the subtleties of the mind. Then, the possibility exists for dark atom structures and chemistries which are parallel
to ordinary structures and chemistries, but undetectable. That sounds like the mind stuff. It is conceivable that the
confirmation of a chemically active dark matter will have a greater impact on science in this century than quantum
mechanics, information theories, and DNA in the previous century. Mind is admittedly mystifying. It is invisible and undetectable, but is coupled to the physical body, in and through which mind operates. However, a mystery per se need not be metaphysical or mystical.
Keywords: Consciousness, Dark matter, Mind, Phonons, Resonance, Spin coupling
_______________________________________________________________________ _______________________
1. Mind Matter
Wave function collapse is universal, but complex mental
phenomena are unique to humans. So, the mental world
must have sources other than wave function collapse. Jung and Pauli (See Meier, 1992) suggested a thought-field with its own elementary particles. Since thoughts are invisible any such field and particles must also be imperceptible. It must be a hidden physical field parallel to that of the ordinary material realm. The dark matter realm may fill the bill.
Present data seem to indicate that ordinary (baryonic) matter constitutes only about ten percent of all matter. Both theoretical physics and cosmological models predict the possibility of existence of certain type of exotic particles (nonbarionic), which are strands of localized energy in space, with very low mass and no charge.
2. Dark Matter Realm
Current speculations about the Big Bang do not conclude that all forms of matter began at this event (Trefil J. 1993; Silk, 1989). Dark matter may have been present even before the presumed Big Bang event. Luminous matter is what is claimed to be formed during this singular event.
Axion Atoms
Presently it is assumed that axions exist apart from ordinary matter and interact very weakly with it. If a symmetry breaking process produced cosmic axions before matter and anti-matter recombined, the number of axions will be comparable to the number of photons in the universe. It is estimated that there must be more than 10 trillion axions for each proton and neutron in the cosmos, making them a major part of dark matter. ............It is inane to think that such dark matter are afloat carrying information and solving the mind-body problem. It is not free floating subatomic particles, but a structured configuration that constitute ordinary matter. So also, corresponding structured configurations of dark atomic particles of very low mass and capable of dark chemistry seem to be an interesting prospect. Toward that goal, the following assumptions are made:
1. Axions of very low mass are confined to the dimensions of ordinary subatomic particles. They occupy the same space that the fundamental particles occupy, but with masses several orders less than one electron volt.
2. They will permeate the visible particles and atoms in an isomorphic manner, and become indistinguishable from the latter.
3. They may form axion atoms possessing bonding properties, through spins and configurations of constituent units.
4. Specific axion dark atom exists corresponding to each known ordinary atom. This relationship will be similar to that between objects and their signs.
5. Certain elemental relations exist which govern the axions such as spin, gravity (exchange of gravitons), resonance, entanglement or an yet to be determined bonding force.
6. Coupling of these dark atoms to the ordinary atoms is possible.
7. Associated with every axion particle is an undetectable charge "C" that can be plus or minus similar to electrical.
A hydrogen atom may have a dark counterpart existing parallel to it. Its one proton and one electron (and no neutron) may each have its shadow axion form condensed within its dimensions and permeating it. Similarly all known atoms will have their protons, neutrons and electrons isomorphously suffused by their shadow axion forms.
For dark chemistries to occur, these are confined to the ordinary atomic dimensions, with their wavelengths condensed to those of ordinary atoms. If these axions must interact with physical energy and be coupled to physical particles, that should be through mechanisms that are logical and relevant to the physical realm. In the visible realm of ordinary (baryonic) particles, electric charge is the bonding force between them. No such charge exists in the extraordinary non-baryonic matter. However there are such physical forces as spin, gravity (graviton exchange), resonance, entanglement or an as yet undetermined force, which may bond these dark particles together and or bind them to the visible particles. [There are many non-falsifiable theories afloat such as axion fields, spin fields, microleptonic fields, heterogeneous physical vacuum, torsion fields etc]. Then, such invisible axion bodies may form the substrate extraordinaire for the mental realm.
Dark chemistries parallel to and coupled to ordinary chemistries, will involve electrically charge-less components of dark matter atoms and their reactions through some kind of bonding. Spins and configurations of electrons lead to chemical bonding in ordinary matter. Same phenomena may occur in these axion atoms also. It could be through an intrinsic angular momentum (spin) with clockwise and anticlockwise directions (positive and negative signs). Then spin-spin coupling between dark particles may facilitate dark chemistries parallel to normal chemistries. The spin-charge coupling of dark and ordinary matter may lead to coupling of the ordinary subatomic particles to their dark counterparts. In addition, there is the possibility of resonance, entanglement and graviton exchange, which may be facilitating factors for interactions that lead to possible dark atom chemistries occurring parallel to ordinary chemistries.
............ As already stated, different axion atoms with different but negligible mass, and zero electric charge, may be held together by a binding force other than electromagnetic. The binding force may result from configuration, spin, resonance, gravity, entanglement or an as yet unknown force. Then we need to consider:
1. Dark atomic structures similar to those of the ordinary atoms.
2. Bonding between dark atoms, through spin and configurations as in ordinary matter.
3. Coupling of dark atoms to the ordinary atoms.
The first two aspects have to address the prospects of electrically charge-less components of dark matter atoms, and their reactions through some kind of bonding. Spin and configuration, entanglement [coupling of the two such that the state of the one determines the state of the other] or an yet to be determined force, may be involved. The asymmetries of structure or forms may also be pertinent factors here. The third question of dark matter coupling to ordinary matter may involve resonance and gravity (exchange of gravitons).
Spin Coupling Quantum Coupling Resonance Coupling ...............
Extraordinary Chemistry .............
It must be noted that the electric charge is a property of the luminous matter, not a thing in itself. So is spin. When charged bodies interact, that interaction is between properties. We know the role that spins play in chemical interactions. Besides, there may be other charge-equivalent properties enabling charge-less dark matter to interact and lead to dark chemistries and dark physiology at the cellular level. Graviton-exchange, resonance, spin, entanglement or an as yet unknown force may enable them to interact between themselves, couple to and resonate with the ordinary physical world. Surprisingly, modern chemistry somehow has so far omitted dark matter for any such considerations.
The Axions of Mind: Microleptons
...... Thus, thoughts and feelings are material, according to the micro lepton concept. ..........These axions must be in a structured form.
These dark atoms may combine to yield dark chemistries. The mediator, in the quantum depiction of this process may be as elusive as graviton. It is not necessary to totally rule out an intrinsic angular momentum or "spin" for these particles, which could be clockwise (+) or counterclockwise (-). These spins may facilitate dark interactions and dark chemistries via bond forming configurations. These processes analogous and parallel to their luminous counterparts. We assume that micro dark atoms could be formed through these forces, much the same way as ordinary atoms, according to rules similar to the Auf-Bau principle of atomic structure. The resonance between the dark and visible bodies offer a new approach to explicate mental phenomena.
Alternatively, the micro proton may have a positive attractive force of +f; the micro-electron may have a negative attractive force of -f. The micro neutron has zero f, where f is an undetermined force factor. For convenience, the micro electron, micro proton and micro neutron are respectively named emoton, psychon (McCulloch and Pitts, 1943) and neumaton. Collectively they may be given the term noumenon, though not necessarily in the Kantian sense. The noumenon here is a permeating axion that isomorphously condenses within an ordinary subatomic particle.
Since all life forms are made of the same matter, certain structural and functional similarities at the basic level of the cell components can exist in the different phyla. However, there is a sharp delineation into plant, animal and human, from the inanimate world. The DNA information, both dark and ordinary, is a causal factor here. The ordinary and the dark DNA code seem to differ in content of information in plants, animals and humans.
There seems to be genetically determined different subsets of subatomic particles and their dark counterparts in plants, animals and humans. The information associated with the dark matter is different in the animate and inanimate realms; so also are the dark chemistries in each realm. Plants have only emotons; animals have emotons and psychons but no neumatons. Humans have all the three. These differences and/or selectivity are genetically ordained. [See McCulloch and Pitts, 1943 for use of the term psychons]
Plant cells have (electron + Emoton), proton and neutron, where proton and neutron are also suffused with axions which are not confined within them and do not enter into any dark reactions. Alternatively, all the three elementary particles may have the dark counterparts. In either case, the plant genetic materials (both dark and visible) have information that determines the nature and functions of the plant cells. Animal cells have (Psychon + protons), (electron + emoton) and neutron. The dark matter permeates the neutrons in animal cells but have no dark atom chemistries, because the axions are not confined within their neutrons. Then again, all the three elementary particles of animal cells may have the dark complements. In either case, the animal genetic materials (both dark and visible) have information that determines the nature and functions of the animal cells. Humans have all the three subatomic particles permeated with the axions. Human genetic materials, made of both ordinary and dark matter, have information that determines the nature and functions of the human cells.
Resonance & Consciousness
Resonance has a relational character. Two or more apparently different things or phenomena are linked. They can selectively communicate being integrated into a systemic whole. The links that unite the visible physical objects and the dark-matter processes have their source in the process of resonance. ..........Specific energies may be associated with specific feelings, inner states, information, ideas, etc.
Then science need not accept and entertain spooky notions and make quantum leaps in to the bizarre to explain consciousness. The resonance between the luminous structural forms and their nonluminous forms made of dark matter is a physical phenomenon, making one recognize the other. This enables us to shift the problem of sentience and consciousness to this subtle body and leave the operational functions to the visible body, and offers a conceptual basis to work from. A dark matter body may be wrapped up in us without being detected. That seems like the mind stuff. But it is physical.
Self-awareness is a recognition problem. In the resonance of the parallel structures, each structure is programmed to identify its resonant forms. Recognition is a resonance phenomenon. Resonance between the ordinary and dark matter system act as a body/mind transducer. Consciousness stays as long as the ordinary energy form is connected to the dark matter energy forms. When the body disintegrates, the axion forms remain in a dormant state. It will require enormous energy to awaken this state and re-entangle with the visible forms of matter............
Paradigm Shift
In a general sense, the physics of the brain and the dynamics of conscious mind are related through invisible quantum entities. Neurons are made of semi-local waves of matter in "vacuum" space enveloped by non-local waves. These semi-localized waves collapse into stable structures in the cosmic expanse permeated by "all the non-local waves", as well as some unknown dark matter waves. Thus, a neuron is semi-locally structured piece of the quantum-vacuum continuum, interfacing "matter" and the "vacuum". In this flow of matter-energy quanta, there is an invisible resonance mechanism that generates, store, transfer and recognize information. Dark-matter structures may provide a base for this dark mechanism.
At the primary level of reality, the perceptible physical universe itself may be a manifestation of thought. ....The phenomenon of subjectivity is "an imagining spun out by this mind stuff" (Edington (1928) in resonance with the perceptible physical counterparts. .............
The relation between dark and luminous matter forms may be similar to the semiotic relation between objects and their signs.
Conclusion
Human consciousness is evident but not physically detectable. A non-material thing can be purely physical, such as the photon, neutrino, energy, field, space, time etc., but it makes no such sense to suggest that non-material mind can be physical. The only physical mind that science recognizes is the brain. Axions, and possibly axion atoms made of axion fundamental particles, make it plausible that the invisible mind stuff is physical. Due to the absence of electrical charges in dark matter, other forces such as resonance, spin, graviton-exchange, entanglement or an as yet undetermined force may enable them to interact between themselves, couple to and resonate with the ordinary physical world. Spin and configuration may play important roles here, as in ordinary chemical bonds. The mind-body problem will putatively shift to this invisible internal physicality. A model of consciousness could be developed on the basis that the resonance of a dark soma made of quantum coherent axion like Bose-Einstein Condensate (BEC), with its corresponding ordinary body. Resonance makes each body recognize the other. Recognition is awareness.
Acknowledgments
Heartfelt thanks to my sons, Ivan, Evan, Bevan and Cyril, for the many helps, observations and stimulating discussions.
References
Phys.Org News Partner Physics news on Phys.org
New approach to form non-equilibrium structures
Nike krypton laser achieves spot in Guinness World Records
Unleashing the power of quantum dot triplets
Register to reply
Related Discussions
Will dark energy overcome dark matter? Cosmology 1
Superb overview of contemporary research/observations in dark matter, dark energy Cosmology 0
Review of Dark Matter and Dark Energy by M. Kamionkowski Cosmology 5
Dark energy = dark matter*speed of light squared? Astronomy & Astrophysics 14
Dark matter doesn't (or what's the matter with dark matter? or pick your lame pun) General Physics 4
