Convolution Code and Error Correcting Capability
The discussion focuses on calculating the error correcting capability of convolution codes, specifically addressing the fixed number of correctable errors, denoted as e, for a convolution code with a rate k/n. It is established that the correctable error count can vary based on the location of the errors; for instance, a convolution code may successfully correct three errors that are spaced apart but fail to do so if those errors are adjacent. The conversation highlights the urgency of understanding these concepts quickly, suggesting resources for further reading.
  • Understanding of convolution codes and their structure
  • Familiarity with error correcting codes and their principles
  • Knowledge of coding theory terminology
  • Basic mathematical skills for analyzing code rates
  • Research the mathematical foundations of convolution codes
  • Study the relationship between error location and correctability in coding theory
  • Explore the resource "A Commonsense Approach to the Theory of Error Correcting Codes" by Benjamin Arazi
  • Examine practical applications of convolution codes in communication systems
Engineers, computer scientists, and researchers involved in coding theory, particularly those focused on error correction in digital communications.
chingkui
Anyone know how to calculate the error correcting capability for a convolution code? My boss basically is giving me pressure to come up some answer by the end of this week... I won't have time to read things deep...
My first question is: For a particular convolution code with a rate k/n, is there a fixed number e of errors that the code can correct and that when the number of errors exceed e, the code cannot be corrected? Does the number of error correctable depend on the location the error occurs? (e.g. will it be the case that a convolution code can correct 3 errors that occur far apart from each other, but cannot correct 3 errors that are next to each other?)
Please let me know asap, thanks. It will be a frustrating week... :frown:
For a quick crash course on Error Correcting Codes,
try this: A Commonsense Approach to the Theory of Error Correcting Codes by Benjamin Arazi (MIT press 1988 England)
This might get you through the difficulty of trying to learn in a few days what normally takes a lot longer!
  • · Replies 21 ·
10K
