How to Convert Volume in Feet to Acre-Feet
  • Thread starter Thread starter Enos
    Volume
The discussion revolves around converting an area of 26 km² with a depth of 2 inches of water into acre-feet. Participants are exploring the relationship between area and volume, specifically how to perform unit conversions involving these measurements.
  • Mixed
  • Participants discuss the conversion factors needed for the calculation, including the definitions of acre and acre-foot. There are attempts to clarify the process of unit conversion and the importance of maintaining unit consistency throughout the calculations.
Some participants have shared their calculations and expressed uncertainty about rounding and significant figures. There is ongoing exploration of the correct approach to unit conversion, with some guidance provided on how to set up the conversions properly. Multiple interpretations of the problem are being considered, particularly regarding the use of units.
Participants note that this inquiry is not part of formal homework, and there is a mention of using a textbook for self-study. There are also indications of potential confusion regarding the application of significant figures in the context of the problem.
Enos
The question is about converting 26km^2 with 2 inches of water into acre-feet. I know the answer is 1100 acre-feet but stuck in converting feet into acre-feet.
1 acre = 43560ft^2
1 acre-foot = 1 acre of land and one foot depth.
I might be posting here often and just wondering if it's ok. This isn't homework for college or school and I bought a textbook by haliday (7th edition) so I can learn physics at home.
Thanks for any help.
1 acre = 43560ft^2
An acre is a unit of area. An acre-foot is a unit of volume. Start by writing the volume of the water in the units given. Once you have that, unit conversion is accomplished by multiplying by factors equal to one to replace unwanted units in favor of desired units. For example, you might want to multiply your original quantity by one of the two factors:
[tex]\frac{1 ft}{12 in}[/tex]
or
[tex]\frac{12 in}{1 ft}[/tex]
Both factors are equal to 1, so multiplication will not change the value of the quantity, but will change the units in which that quantity is expressed. Any factor equal to one can be used in this manner. Unit conversion often involves multiplying by several such factors.
I think I got the right answer. I just disagreed with the textbook because I forgot to round the number to two significant figures. the answer I got was 1070 and the answer in the textbook was 1.1x10^3
All I did was 26x1000^2x3.281^2x(1/12)/43560
Actually, what you did was
[tex]V = 26 km^2 \cdot 2 in \cdot \left[ \frac{1000\ \ m}{km} \right]^2\cdot \left[ \frac{3.281\ \ ft}{m} \right]^2 \cdot \left[ \frac{1\ \ft}{12\ \ in} \right] \cdot \left[ \frac{1\ \ acre}{43560\ \ ft^2} \right] = 1071\ \ acre-feet[/tex]
Besides leaving out all the units, you left out the 2 in your posted equation. Writing the units is always a good idea and will help you keep track of what you are doing.
Whoops, meant to put (2/12) in my posted equation rather than (1/12). I'm starting to get a hang of this stuff.
9K
12K
