What formula would I use to find the horizontal force?
The discussion focuses on calculating horizontal force and velocity in physics problems involving a dragster and a swimmer. To find the horizontal force exerted on the driver of an 850 kg dragster accelerating to 27.0 m/s in 0.59 seconds, the formula F=ma is used, resulting in a force of 3117.28 N. For the swimmer stepping off a 10.4 m tower, the final velocity upon hitting the water is calculated using the formula v² = u² + 2as, yielding a velocity of 14.5 m/s. These calculations illustrate fundamental principles of dynamics and kinematics.
  • Understanding of Newton's Second Law (F=ma)
  • Basic knowledge of kinematics equations
  • Familiarity with acceleration and its calculation
  • Concept of gravitational acceleration (9.8 m/s²)
  • Study the derivation and applications of Newton's Second Law
  • Learn about kinematic equations and their use in solving motion problems
  • Explore the concept of free fall and its implications in physics
  • Investigate the effects of air resistance on falling objects
Students and enthusiasts of physics, particularly those interested in dynamics and kinematics, as well as educators seeking to reinforce foundational concepts in motion and force calculations.
slyguy
Hey guys,
I am kind of new to this physics thing, and I need some help. Any advice you can give me is more than welcome. :)
1. An 850 kg (1878 lb) dragster, starting from rest, attains a speed of 27.0 m/s (60.5 mph) in 0.59 s.
A. Assume that the driver has a mass of 68 kg. What horizontal force does the seat exert on the driver?
11. A 66 kg swimmer steps off a 10.4 m tower. What is the swimmers velocity hitting the water?
What formual would I need to use to find this out?
If you guys can give any help it would be most appreciated. I know this must be really simple to you guys, but I am stuck on it.
F= ma leaps to mind. You are given m and know how to find a.
You know the acceleration don't you? What's the relationship between acceleration and speed?
To find the horizontal force, you would use the formula F=ma, where F is the force, m is the mass, and a is the acceleration. In this case, the acceleration would be the change in velocity divided by the time, or a=(27 m/s - 0 m/s)/0.59 s = 45.76 m/s^2. Plugging in the mass (68 kg), the horizontal force would be F=(68 kg)(45.76 m/s^2) = 3117.28 N.
To find the swimmer's velocity hitting the water, you would use the formula v^2 = u^2 + 2as, where v is the final velocity, u is the initial velocity (in this case 0 m/s since the swimmer is starting from rest), a is the acceleration due to gravity (9.8 m/s^2), and s is the distance (10.4 m). Solving for v, we get v=√(2(9.8 m/s^2)(10.4 m)) = 14.5 m/s.
I hope this helps! Remember, physics can be challenging at first, but with practice, it will become easier. Don't be afraid to ask for help when needed. Good luck!
11K
13K
