How do I properly set up a telescope mount for accurate tracking and viewing?
  • Context: Stargazing
  • Thread starter Thread starter Integral
    Telescope
The discussion focuses on setting up a German equatorial telescope mount for accurate tracking and viewing. Key points include the necessity of aligning the mount with Polaris for proper Right Ascension (RA) and Declination (Dec) settings. The user is advised to ignore the fiducial marks on ring A and to keep ring B fixed at their local latitude (~45 degrees). Additionally, using a star atlas and a low-power viewfinder is recommended for effective navigation and observation.
  • Understanding of German equatorial mounts
  • Knowledge of celestial coordinates: Right Ascension and Declination
  • Familiarity with polar alignment techniques
  • Basic astronomy tools such as star atlases and viewfinders
  • Research "German equatorial mount setup" for detailed instructions
  • Learn about "polar alignment techniques" for improved accuracy
  • Explore "star-hopping" methods for locating celestial objects
  • Investigate the use of "low-power viewfinders" for enhanced observation
Astronomy enthusiasts, amateur astronomers, and anyone interested in optimizing their telescope setup for accurate celestial tracking and viewing.
Integral
Staff Emeritus
A few months back my brother dug this telescope of his garage and brought over to mine. I have had it out and was able to get a good look at the last quarter of the last moon, and a good look a Jupiter, with 2 moons visible. Somewhat to my surprise I was even able to resolve a couple of bands (pretty faint) on Jupiter.
Here is the telescope
http://home.comcast.net/~integral50/Telescope/telescope.JPG[/URL] [/PLAIN]
now for my question, I am having some trouble setting up the mount so the co-ordinate system is correct. Could someone give me some guidance.
First of all have I got the telescope in the correct orientation?
http://home.comcast.net/~integral50/Telescope/mount.JPG
I am having trouble locating the fiducial mark on ring A, I may have to make one, but that fiducial will be pointing North.
I have ring B set to my local latitude (~45) and believe that it should remain fixed there, is that correct?
Rings C & D should be Right Ascension and Declination but I am not sure how to align them.
Any pointers or direction to a web page with a complete description of this sort of mount would be appreciated.
Astronomy news on Phys.org
This[/URL] is a typical commercial German equatorial mount. As for orientation, you will have to align the mount every time you take the scope outside. Luckily, for visual observations, this is pretty fast and easy.
The markings on ring A are of no consequence. Since the mount is on a portable tripod, it will have to be re-aligned every time you set it up. Just ignore those marks.
If the place where you set up the tripod is absolutely level, and you set up the same way every time, it's a fair approximation. The scale is only a rough guide, though.
Ring C is the right ascension circle. It is numbered 1 through 24 for the 24 hours in the day. The shaft running through this ring is called the right ascension axis, and it needs to be aligned so that it is parallel to the Earth's axis of rotation. Making this axis point at Polaris is a good enough approximation for visual observations. You can turn the right ascension worm gear ever so slightly as objects drift out of your view, so you won't have to constantly fiddle with re-acquiring objects. If you want to align a bit more carefully, here is a guide:
http://www.mindspring.com/~jeffpo/polar.htm
You can find others by Googling on "German equatorial" and "Polar alignment" - be sure to use the quotation marks for best results.
If I may give you some advice: Your most useful accessories will be an atlas (Peterson's Field Guide to the Stars and Planets is a great starter) and a low-power or zero-power viewfinder. Learn to star-hop from bright easily-found objects to the fainter ones, and forget about those setting circles. They are far too small and imprecise to be useful. An old pair of 7x50 binoculars can often help you find interesting things to look at with the 'scope, too.
A tip about mechanics: If the 'scope is properly balanced, you can often clutch a German equatorial mount "just enough" to allow you to slew to an object by hand, then use the RA knob to keep the object in view while observing. You'll have to get a feel for it, but it makes observing effortless once you get it right.
Please feel free to ask for clarification if I haven't answered your questions.
Thanks a lot, you have given me enough to get on the right track.
  • · Replies 18 ·
  • · Replies 27 ·
  • · Replies 35 ·
11K
  • · Replies 30 ·
