How Accurate is the Freezing Point Calculation for Ethanol at 1000 atm?
The freezing point of ethanol (46 g/mol) at 1000 atm is calculated to be approximately 11.8956°C using the rearranged equation dt=(dp*t*dfusV)/dfusH. The latent heat of fusion for ethanol is 8.68 kJ/mol, and the change in molar volume on melting (dfusV) is determined to be 4.875399e-6 m³/mol. The standard temperature of 273.15 K is utilized in thermodynamic calculations to maintain accuracy and consistency across various scientific disciplines.
  • Understanding of thermodynamics, specifically phase transitions.
  • Familiarity with the concepts of latent heat and molar volume.
  • Knowledge of the Kelvin temperature scale and its application in scientific calculations.
  • Proficiency in using equations related to pressure and temperature changes in phase changes.
  • Research the properties of ethanol under high pressure, focusing on phase diagrams.
  • Learn about the application of the Clausius-Clapeyron equation in phase transition calculations.
  • Explore thermodynamic tables for various substances to understand freezing points at different pressures.
  • Study the relationship between pressure, temperature, and volume in thermodynamic systems.
Chemists, physicists, and students studying thermodynamics, particularly those interested in phase transitions and the behavior of substances under high pressure.
koomanchoo
ethanol 46g/mol freezes at 3.65degC density changes from 0.789g/cm-3 to 0.801g/cm-3 latent hear of fusion 8.68kJ/mol. freezing point at 1000 atm.
i calculated the ansfer from an example and just want to verify if its correct.
dp/dt=(dfusH)/(t*dfusV) rearanged to dt=(dp*t*dfusV)/dfusH
where dfusV: change in molar volume on melting
okay, with the rearanged equation i changed 1000 atm to pascals = 101325 kPa dfusV was calculated to be 4.875399e-6 m3/mol
i came to a change in temperature of 15.54deg hence final freezing point is 11.8956degC.
could anyone plese help me and tell me if this is correct
also.. in the equation t=273.15K was used.. could anyone please tell me why this was the case?
thanks
patrick.
I don't know the freezing point, but you can probably find a table that gives you that data so you can check your answers.
Also, you use t = 273.15 Kelvins because that is, in basic terms, the accepted unit of temperature in chemistry/physics, etc. You will use Kelvins in the gas laws, thermochemistry and thermophysics, and pretty much everything else.
Your calculation looks correct to me. In the equation, t=273.15K is used because it is the standard temperature at which most thermodynamic calculations are performed. This temperature is equivalent to 0 degrees Celsius or 32 degrees Fahrenheit. It is important to use a standard temperature in thermodynamic calculations to ensure accuracy and consistency.
  • · Replies 131 ·
11K
9K
  • · Replies 17 ·
